best affordable lift kit?
Discussion in 'Suspension' started by fkli222, Oct 31, 2011.
  1. Oct 31, 2011 at 1:37 PM
    fkli222
    fkli222 [OP] Active Member
    moving to the snow with my 2wd taco and would like to put a 3 inch lift with 33 inch snow tires? good idea?
    what would be the best affordable lift kit 2.5-3 inches that wouldnt damage the diff in the long run?
  2. Oct 31, 2011 at 1:40 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Use the "search" feature and you will find what you are looking for.
  3. Oct 31, 2011 at 1:49 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  4. Oct 31, 2011 at 1:54 PM
    fkli222
    thanks guys!
  5. Oct 31, 2011 at 1:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    FWIW, a lift kit on a 2wd with big ol fat tires would be about the worst thing you could do for snow performance. Keep the suspension where it is, go one series taller with the tires and keep them narrow and snowflake rated. If you want the lift for looks, great but it will not help you in the snow.
  6. Oct 31, 2011 at 2:04 PM
    fkli222
    what do you mean 1 series taller? should i just get 1 inch blocks or leafs?
  7. Oct 31, 2011 at 2:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    we need to know what kind of truck you have before we can relly tell you anything.
    the more information you give us the more we can give you.
  8. Oct 31, 2011 at 2:11 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    This.
    Fink
  9. Oct 31, 2011 at 2:18 PM
    Pugga
    Massachusetts
    Where are you moving to, are you talking about a couple inches of snow or several feet a year?
    Also, ZombieRunner is correct, we need some more info, what do you do with the truck, do you off road, are you doing the lift just for looks or are you looking to improve functionality in the snow? Don't do blocks...
  10. Oct 31, 2011 at 2:21 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    do you have a 5 lug or a 6 lug? what year?
  11. Nov 1, 2011 at 8:32 AM
    fkli222
    Sorry I have 08 taco double cab with extended bed. I am moving to new York and I don't off road. I was thinking of a small lift just for looks and so I can put bigger tires for the snow.
  12. Nov 1, 2011 at 8:35 AM
    Fink
    Orlando, FL
    I understand the looks thing, but you don't need bigger tires for the snow.
    I ran 265's in Arkansas during the worse winter on record and I did just fine in 2WD with careful driving just about everywhere I went.
    I would spend your money on a really good set of tires and be done with it. If you really just want to lift it, then go that route, but I wanted to be sure you weren't spending your money erroneously.
    Fink
  13. Nov 1, 2011 at 8:53 AM
    fkli222
    thanks everyone for all your help.
    is the readylift kit considered a block lift? if not, is that one good for the price? I was thinking if I did do it only like a 2 inch lift, nothing dramatic.
  14. Nov 1, 2011 at 8:57 AM
    Fink
    Orlando, FL
    I think it depends on which ReadyLift you are talking about.
    All of the ReadyLift products I have seen are leveling kits, which are front coil spacers.
    If that is what you are looking at, I would suggest saving your money for a true suspension lift (new coils, shocks, leafs, etc...).
    Here's a link to what I found.
    Fink
  15. Nov 1, 2011 at 8:58 AM
    Pugga
    Massachusetts
    I believe readylift is a spacer kit. They work as a cheap lift but they're far from the best option and can hinder ride quality.
    Also, Fink is right about the tires/lift. Go one series taller on the tires, keep them narrow, get good tires and you'll have no issues in the snow. I grew up in NY and had 2wd pickups from the time I was 16 - 22. I usually put a 'digger' on the back, a good ribbed pattern tire on the front, some weight in the front of the bed and good to go. Studded snows might not be a bad option depending on where in NY you're heading and what your commute is like.
  16. Nov 1, 2011 at 9:14 AM
    fkli222
    sounds good i will do that in the mean time and save up for a lift in the future. i have heard people go bilstein lift kit with 5100's all the way around and leafs? is that a good way to go?
  17. Nov 1, 2011 at 9:17 AM
    Fink
    Orlando, FL
    5100s by themselves are not going to lift you, they will level you out in the front, but they aren't going to give you a full lift.
    If I were you, I would just get the TSB rear leafs (assuming this is an option for you still), run 5100s up front at .85 and be done with it.
    Fink
  18. Nov 1, 2011 at 10:12 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    5100's set at 1.75 to level him out as he sits now. he could throw the next size tire on with that and im sure thats what he is looking for anyways.
  19. Nov 1, 2011 at 10:16 AM
    Fink
    Orlando, FL
    Thanks for the correction - I thought it was .85 to level.
    Fink
  20. Nov 1, 2011 at 10:20 AM
    fkli222
    thanks! so all i would need is 5100's and rear leafs? i want the back and front lift to be even. is there anything else i need in the front or back?
