Best Aftermarket door handles
Discussion in '1st Gen. Tacomas (1995-2004)' started by CrippledOldMan, Mar 19, 2020.
  1. Mar 19, 2020 at 7:06 AM
    CrippledOldMan
    CrippledOldMan [OP] Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Well from all the posts that I've read on TW, my door handles are a problem waiting to happen. I'm not paying Toyota $100.00 bucks a piece for door handles. So I'm looking for the best after market ones, that TW members have actually installed, and have been somewhat "happy" with the purchase they made. Yes I've searched the forum, but thought I'd post this question.
  2. Mar 19, 2020 at 10:11 AM
    ToyotaJim
    ToyotaJim Well-Known Member
    Jimmy
    1999 Tacoma SR5
    https://www.ebay.com/itm/2Pcs-Door-...18281?fits=Year:1999|Model:Tacoma|Make:Toyota
    $6 a piece. They all break in the same place with the same cheap plastic.
  3. Mar 19, 2020 at 10:47 AM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    OEM are still the best
  4. Mar 19, 2020 at 10:56 AM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    My drivers side broke on my 03 - in a moment of weakness I bought an aftermarket set off of ebay and it lasted for 3 more years until I traded the truck in. No problems, no weakness. It didn't feel QUITE as dead solid as the OEM passenger side, but it never failed. Luck of the draw!
  5. Mar 19, 2020 at 11:01 AM
    eon_blue
    Azusa, CA
    Dorman.
    I went through so many OEM handles that kept breaking, finally said F it...not going to keep buying expensive ones if they're going to break, might as well break cheap ones.
    To my surprise, the cheap Dormans have lasted me over 2 years completely problem free. I went through 4 OEM handles in the span of ~ 6 months before that.
    The Dorman handles have a bigger lip on the back that engages the rods inside the door that open it. I was curious and compared the two brands (OEM vs Dorman) before installing them. Identical except the Dorman's bigger lip on the back doesn't allow it to slip like the OEM one does.
    Now, if the plastic handle itself breaking is your issue then I don't know what to say, I doubt the Dormans are made of better material. They are a better design though IMO.
    OneWheelPeel likes this.
  6. Mar 19, 2020 at 11:03 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Hot and Cold weather cycles is what hurts these door handles the most I think.
    GQ7227 and ToyotaJim like this.
  7. Mar 19, 2020 at 11:09 AM
    eon_blue
    Azusa, CA
    Yeah, my very first broken OEM handle (original one) happened when we camped in the mountains over winter and it froze/snowed overnight. Went to open my truck and the plastic cracked.
  8. Mar 19, 2020 at 11:28 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The vast majority of people don't have a problem with the handles.
    IF you break a handle, sure, go down this road, but it's honestly a waste of time and money to fix a "problem" you may not even have.
    Hoots Magoon and ToyotaJim like this.
  9. Mar 19, 2020 at 11:32 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have survived 23 years without breaking one in mid west freezing rain, snow encrusted and frozen water after hosing my truck off and parking in non-heated garage at night with dropping temps, i have had to access the driver door through the passenger side on occasion. it takes some finesse but mine will likely break at some point IDK
    perhaps be a bit more gentler!
  10. Mar 19, 2020 at 9:50 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Dumb Question, but does a DC use the same door handle front and rear.
  11. Mar 20, 2020 at 9:13 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I think the housing is different and doesn't have the key mech. The handle might be the same. I wonder if it's cheaper to buy the OEM DC rear door handles and swap them over if that's the case.
  12. Mar 20, 2020 at 1:06 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I've had the best luck with the cheap chrome ones to be honest. I've got about 3 and 4 years on the current set that I picked up at autozone.
    I've broken about 3 pairs of the black ones. I hate changing that handle it's such a pain.
