Best Aftermarket Swabar Linkage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Feb 5, 2020.
  1. Feb 5, 2020 at 8:27 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Hey guys,
    My swaybars links are a little loose and I'm gonna replace them. The cheapest OEM I could find was $115 apiece. Does anybody know a great aftermarket option for 4wd access cab? Maybe one that's possibly cheaper than OEM or am I dreaming?
  2. Feb 5, 2020 at 8:34 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I too irked at the price of oem. I went with mevotech. Seems decent and has zerk fittings for regular maintenance.
    2009Access4x4[OP] likes this.
  3. Feb 5, 2020 at 8:35 AM
    2009Access4x4
    Shane
    Did you install them yet? So far so good?
  4. Feb 5, 2020 at 8:36 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Yes I've had them on for a few months now. No issues, I went offroading a few times as well and they held up fantastic. I will be doing a few pumps of grease this weekend when I look over all of my suspension.
  5. Feb 5, 2020 at 1:26 PM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    I have moog on mine. No complaints, but deciding factor was availability.
  6. Feb 5, 2020 at 1:32 PM
    2009Access4x4
    Shane
    So you need to grease them a few months after usage?
  7. Feb 5, 2020 at 1:46 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    I greased then when I initially installed, just enough for a bit to come out of the seal. I have habitually greasing them every other oil change. I had a really bad loose/clunking feeling on bumps before I got new endlinks and found my own ones had torn boots and alot of play. I've been happy with the mevotechs and even replaced my ball joints with them.
