Best air down methods?
Discussion in 'Recovery' started by Natenite, Aug 11, 2019.
  1. Oct 28, 2019 at 10:02 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Ive seen the Boulder Tools kit before. Seems like the best bang for the buck. Obviously theyre not going to be as quick as an ARB or anything else that pulls the core, but might be easier to do all 4 at once.
    How long you had them?
  2. Oct 28, 2019 at 10:10 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    A few years now. Definitely best bang for your buck, imo. They are a little finicky to setup, but once you get them set up, there's nothing to worry about.
    It sounds like there are some newer ones out there (mentioned above) that are quicker, but of course more expensive, too. With those newer ones, when to consider that you're doing all 4 tires at once, they may even be faster than the ARB style, even when you remove the core because you're only doing one at a time..
    SR-71A[QUOTED] likes this.
  3. Oct 28, 2019 at 10:13 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    @Shellshock has a good write up on a kit.
    that’s what I use
    tonered likes this.
  4. Oct 28, 2019 at 10:58 AM
    Shellshock
    Iowa
  5. Oct 28, 2019 at 11:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @Shellshock 's setup friggin' rocks and has more uses than just dropping air. A friend is building one now after seeing it in action.
  6. Oct 28, 2019 at 12:08 PM
    Shellshock
    Iowa
    I used it to steal air from my other trucks tires to fill up a flat when I didn’t have my compressor with me
  7. Oct 28, 2019 at 12:14 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    200IQ
  8. Oct 28, 2019 at 12:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A local company makes an donor hose for motorcycles:
    https://bestrestproducts.com/shop/tire-repair-accy/donor-hose/
    They're good folks, but their prices are on the #expedition side. That is about half of what I got into building your kit. :rofl::rofl:
    The emergency siphon instructions at the end are precious.
  9. Nov 20, 2019 at 9:32 PM
    CMScheid
    CMScheid Well-Known Member
    Cody
    NorCal
    2017 Silver Tacoma TRD Off-Road
    Front: ADS 2.5 Coilovers JD Fab LT 2.25" LCA Pivot Rear: ADS 2.5 Coilovers 3 Linked Armor: Hot Metal Fab custom Rear Bumper Hot Metal Fab custom Skids & Sliders BAMF Front Bumpers
    HMM likes this.
  10. Nov 21, 2019 at 2:28 PM
    SR-71A
    Zack
    Southern Maine
    Thats cool in theory, but way too much kit to carry just for airing down. Classic ARB deflator weights what, 1 lb at most? Also, myself and a lot of others I know run a bit higher pressures in the front to account for more weight up there.
  11. Nov 21, 2019 at 2:41 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
  12. Nov 21, 2019 at 2:42 PM
    CMScheid
    Cody
    NorCal
    I completely understand; The price point is also high...
    With that said, the air-chucks are unlike anything I've seen before...they're always 'closed' until they're a valve, what does that mean? You can air up (or down) 1 to 4 tires at a time...so running higher pressure in the fronts, you'd simply pull off the back 2 chucks and the air source can still do its job.
  13. Dec 1, 2019 at 3:59 PM
    jbrandt
    Justin
    I can think of a lot of things that it would make more sense to spend $180 on. Currently, it only takes me like a minute or 2 per tire to inflate from 18-35 psi with my 400p. IMO, the cost/benefit just isn't there for a system like this (for me).
    The kit does say you can have different front/rear pressures. But overall I agree, this is quite a bit of extra "stuff" to carry around with you all the time.
    I can already deflate all my tires at once (stans type), and the time it saves by inflating all 4 at once is likely counteracted by the time it takes to set up and break down this system.
  14. Dec 4, 2019 at 8:12 AM
    uploadadventure
    Dixon, Mo
    Do you guys have Colby Valves?
  15. Dec 4, 2019 at 8:26 AM
    #35
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    All air chucks I’ve seen are always closed.
  16. Dec 5, 2019 at 10:56 AM
    #36
    jbrandt
    Justin
    Yeah, but the Colby's you can install from the outside.
    I saw this youtube guy a while ago that found this ancient tool from ~WWII. A big brass conical tube that would push (via air pressure) a conventional valve stem into a rim from the outside. A pretty cool tool for sure, but with the advent of things like the Colby valves, kinda useless now.
    WarFab Armor[QUOTED] and SR-71A like this.
  17. Dec 5, 2019 at 10:57 AM
    #37
    SR-71A
    Zack
    Southern Maine
    I carry a pack of those Colby valves just in case. Never had to use one tho
  18. Dec 5, 2019 at 11:01 AM
    #38
    jbrandt
    Justin
    Yeah, me either. Better to have and not need than to need and not have.
    For some things that are large or heavy and/or expensive, you kinda have to do the mental calculus as to whether it makes sense to carry it. But these things are kind of a no-brainer, IMO.
  19. Dec 5, 2019 at 11:12 AM
    #39
    jbrandt
    Justin
    So how do you get the valve in? from the inside, or do you have a magic trick?
  20. Dec 5, 2019 at 1:25 PM
    #40
    sidetracked
    sidetracked Well-Known Member
    Folsom, CA
    1 of each
    i've used the colby valves before, they are handy. Hadn't seen that little tool before, that's sweet. I think i'll pick one of those up.
    uploadadventure and WarFab Armor like this.
