Best Air Filter Filtration wise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaFloppa, Sep 8, 2025 at 8:00 AM.
  1. Sep 8, 2025 at 8:00 AM
    TacomaFloppa
    TacomaFloppa [OP] Well-Known Member
    Tl;dr from California where everything is dusty and dry, causing me to suck in a bunch of dust. Pretty sure I killed my MAF sensor doing it but that's a story for another time. That's just the reason for why I'm even posting.
    I do have a snorkel so a dust sock is an option too.
    Thought about getting a k&n filter but heard they're worse than the AFE ones. I've also heard cons about the AFE ones giving more "performance" at the cost of letting more dust and for the oiled ones, oil into the throttle body.
    Is my best measure just to buy a couple stock air filters and a dust sock and call it a day? I'm not looking for improved air flow, I just want the best filtration that's possible.
    Edit: Will be tearing apart the throttle body and IACV to clean. Is there anything else I should be doing while I'm there? Is there any mods that I'm able to do?
  2. Sep 8, 2025 at 9:06 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    I travel alone over a lot of heavy, dusty off-roads in the deserts of eastern Nevada and southeastern Utah. Not wanting mechanical breakdowns 30 miles up some washed-out, two-track laden with roots, rocks, and ruts in the middle of nowhere, I change the oil when it looks dark, keep my U-joints well-lubed, shake out the air filter after each off-road experience, and replace the spark plugs every 50,000 miles. I just installed my third set of LBJs, and I'm on my third steering rack.
    My truck has never so much as coughed during the last 27 years.
    I recommend using nothing but Genuine Toyota Parts when replacing anything on the engine, suspension, or drive train. Why take a chance by saving a few bucks?
  3. Sep 8, 2025 at 9:12 AM
    JR_Roams
    JR_Roams Well-Known Member
    2002 Tacoma TRD-OR EXC 5MT
    WIX air filters stop the most particles and have the least flow. If you want filtration you have to sacrifice flow, but we aren't building race cars it's ok.
    skeezix and WheelinDev like this.
  4. Sep 8, 2025 at 2:28 PM
    TacomaFloppa
    I wouldn't be saving a few bucks, I'd be buying a $90 filter in hopes they clean better than OEM.
  5. Sep 8, 2025 at 2:29 PM
    TacomaFloppa
    Alright, I appreciate it, thank you.
  6. Sep 8, 2025 at 2:46 PM
    Squirt
    Squirt Pepsi > Coke
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Good paper filter > Dry filter (such as AFE Pro Dry S) > Oiled (K&N)
  7. Sep 8, 2025 at 2:47 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    K&N is the worst thing you could do. They don’t filter enough. Snorkel is good because because the intake is up high where you’re picking up less dirt. High quality paper filter is best. https://www.youtube.com/watch?v=sJ3L-E-ufYo
  8. Sep 8, 2025 at 2:49 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Frequency of changing a paper filter in those conditions is probably more important than brand.
    skeezix and Wulf like this.
  9. Sep 8, 2025 at 2:59 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    You can get the Denso one off Rockauto for a good price, and my UOAs from my Mazda (used to drive it through dust clouds from heavy construction all the time) show good air filtration.
    But more important than which one is how often you change it.
  10. Sep 8, 2025 at 3:27 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    I don't think you are going to do better than an OEM Toyota air filter. I have to live life having faith that they (Toyota engineers) have tested and likely improved them over the years and spent a lot in research and trials to be the best possible under all conditions, extremes, or otherwise.
    I can easily find them on the Toyota Parts website from a dealer in my area for around $20 when they are on-sale. They also run free shipping at times or no charge pick-up at the dealer's parts counter. I change them out once a year in the fall which works out to about 15k miles per year for me.
  11. Sep 8, 2025 at 3:34 PM
    TacomaFloppa
    Think I'm just gonna buy a wix filter, $36 so not bad. Read some old forum posts and general consensus is that they're good.
    23MGM and Squirt[QUOTED] like this.
  12. Sep 8, 2025 at 3:35 PM
    TacomaFloppa
    Yep.
    Almost thinking of buying one of those snorkel heads where it has a dust filter.
    Too bad they look ugly
    23MGM[QUOTED] likes this.
