Best alignment with SPC UCA and 33” tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrankTheTank858, Dec 30, 2022.
  1. Dec 30, 2022 at 11:59 AM
    FrankTheTank858
    FrankTheTank858 [OP] Well-Known Member
    Frank
    Murrieta, CA
    2006 Tacoma DCSB 4WD
    Hey guys, I recently bought this truck and it came with the SPC upper control arms already installed.
    The truck had badly cupping cooper MTs when I bought it and I just bought some 285/70r17 Falken wildpeak instead (loved them on my old truck).
    The truck rides smooth now but I have an obvious alignment issue, a slight pull and off center wheel.
    I’m curious for those that have experience with the SPC, which position have you found best with bigger tires and are there any specific caster/camber specs that you have done and are happy with.
  2. Dec 30, 2022 at 12:51 PM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    I have stock LCA’s and SPC uppers, but I’m on 325/75r16 tires. My uppers are set to the middle position D (+2.0°) because I wanted a higher caster angle but still fit big tires.
    I’d say your best bet is to find a reputable alignment guy near you and don’t settle till the numbers and steering wheel look right. Just be aware a lot of shops will charge extra and look at you stupid when you ask them to adjust the uppers, even if you give them the SPC alignment sheet. http://www.spcalignment.com/instructions/25480-INS_WEB.pdf
  3. Dec 30, 2022 at 12:59 PM
    FrankTheTank858
    Frank
    Murrieta, CA
    Thank you for your input. Was there a reason you wanted higher caster?
    im hoping to set the uppers myself before I take it to the shop so I don’t have to have them mess with it.
    ImMrCrash[QUOTED] likes this.
  4. Dec 30, 2022 at 1:11 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Personally I’ve found that a higher caster number tracks better; doesn’t wander, doesn’t follow road crown, doesn’t turn on potholes. The good news with the SPC’s is that D is the recommended setting to start and they have the added bonus of being designed with 2° more caster than stock uppers. You could also go higher for more caster but doing that to the upper will cause the tire to move closer to the cab mount and risks rubbing.
    Yep, I did as well, it was too much of a headache getting shops to do anything right when I first installed them.
  5. Dec 30, 2022 at 1:34 PM
    FrankTheTank858
    Frank
    Murrieta, CA
    Do you have any rubbing with this setup?
    I’m assuming you have a massive lift with those tires. I’m only running about 3” myself.
    when you took it to the shop, did you say to just set your camber and toe? Or did you even have to say anything
  6. Dec 30, 2022 at 1:46 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    I do have a slightly noticeable rub in reverse full turn as well as stuffed, mostly due to the 1.25” wheel spacers causing a wider scrub radius.
    Nope, just 2.5” lift but a heavy cab mount chop and fiberglass fenders.
    Yes, I didn’t say anything about the uppers, but I did ask them for 0° Toe, 0° Camber, and as much caster as they could get. Alignments are a balance of the 3 so the tech has to bounce between them to get it right but a good tech can do it without question, might just take them longer
  7. Dec 30, 2022 at 3:19 PM
    FrankTheTank858
    Frank
    Murrieta, CA
    Nice, taking a look at your alignment sheet again, it looks like everything is almost exactly in spec. Do you know if those scales are based off of what a stock Tacoma should be?
  8. Dec 30, 2022 at 3:22 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Yep, they will always bring up your vehicle in their system and then in my case it was also modified for the caster
  9. Dec 30, 2022 at 3:31 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    I have a 6" lift with SPC UCA and caster was set at 3.4deg + (setting E on spc spec sheet)passenger side and 3.5deg + drivers side(also setting E). The truck was pulling to the right. Vehicles will tend to pull to the side with the least amount of positive caster so I set my driver's side to setting F. After a slight toe adjustment the truck drives straight as arrow. Good alignment shops will set less caster on driver's side than the passenger side to compensate for road crown.
  10. Dec 30, 2022 at 3:43 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a tricky thing, you want the most caster you can get from the lower arms, without adding more with the upper arm.
    Lower caster pushes the wheel forward. Upper caster, creates more caster, but pulls the top of the wheel rearwards.
    The idea behind SPC is to lower the camber thats created by maxing out the lower arms.
    TLDR. Follow the manual, set it to the lift height you have. Max out lowers.
  11. Dec 30, 2022 at 3:49 PM
    MA_TACO
    Wesley Chapel, FL
    That's another thing I forgot to mention. I installed DK LCA and maxed them out (rears all the way out and front all the way in) since I'm running 35's and used the SPC UCA to adjust the camber and caster. I don't mess with the LCA for anything. I even told the alignment shop to don't touch them.
  12. Dec 30, 2022 at 4:44 PM
    FrankTheTank858
    Frank
    Murrieta, CA
    When you adjusted the uppers yourself before bringing it in, where in the slot did you have the setting for the camber?
  13. Dec 30, 2022 at 10:15 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Oh, good catch. I set mine almost all the way out toward the edges of the vehicle, maybe a half inch in.
