Best All Terrain For Hauling.
Discussion in 'Wheels & Tires' started by Brothers, May 9, 2019.
  1. May 9, 2019 at 5:51 AM
    Brothers
    Brothers [OP] Member
    15 TRD Tacoma
    Looking for a safe tire (Stock Wheels) 2015 Tacoma TRD to run with a camper. The camper wet is around 1000 pounds (Slide in)
    The truck will see Airbags soon.
    Any recommendations on size and brand would be helpful.
    Thanks.
  2. May 9, 2019 at 3:23 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    There are many solid all-terrain tires that are available depending on which size tire you need. I see your 2015 Tacoma came with stock sizes from 15-inch to 18-inch tires. Can you let us know what trim level and stock tire size is on your truck?. Also, where do you live and what type of terrain do you drive in?
  3. May 20, 2019 at 7:38 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    I swapped out my stock bfg 8 plys for P rated Firestones and with the shell and all the gear it has about 1000lbs in it loaded. Lots of Arizona / Utah type dirt roads with 0 issues. I'm running Air Bags with the poly cups to let them flex better. Might not be as durable as the 8plys, but with 90% street use they are way more comfortable! And yes, lots of those BLM roads are done at speed, not crawling.
