best and safest 3 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kourtny14, Apr 6, 2015.
  1. Apr 6, 2015 at 11:58 PM
    Kourtny14
    Kourtny14 [OP] Member
    kourtny
    GA
    10 Prerunner double cab
    3 inch lift 285/75/R16
    I am looking at buying a 3 inch front lift and 1 inch rear lift. My buddy has a 3 inch front and 2 inch rear. I went to Savannah tire and the salesmen said I needed a 1 inch rear bc of rollover hazard.. is this true or was he trying to upsell? Any ideas on the best lift for me? I really want it for style but I always want to be safe! Thanks
  2. Apr 7, 2015 at 12:14 AM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I don't know what that guy is talking about, rollover hazard??
    There is a ton of questions you need to ask yourself before you go down this road. How much $$$ you want to spend, what kind of ride quality do you want, percentage of off roading you will be doing?
  3. Apr 7, 2015 at 12:17 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    The salesman was trying to pull one over on you Kourtny.
  4. Apr 7, 2015 at 12:25 AM
    Yota64
    Yota64 Professional Threadjacker
    Normally I would say he is pushing product but he only said you needed 1 inch less of spacer in the rear... To me that's almost downselling. If he said something like you needed a certain product he had in stock then I would say forget him, but he may legitimately be trying to be safe, perhaps a previous accident?
    Either way, you'll be fine lifting the rear. There are guys here that lift the rear 5 inches.
  5. Apr 7, 2015 at 12:43 AM
    Warputer
    2011 TRD Off Road
    Yup....like mine. :headbang:
  6. Apr 7, 2015 at 12:52 AM
    Yota64
    Like Warputer. :cool:
  7. Apr 7, 2015 at 7:17 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    Never heard of the rollover issue and I did tons of research before pulling the trigger on my lift. It all depends on how you plan to use the truck and how much you are willing to spend.
  8. Apr 10, 2015 at 2:32 AM
    Yota64
    We can't recommend a lift until we know what you do with the truck and what your budget is. Once that's out of the way, the hard parts done. Lol
  9. Apr 10, 2015 at 2:41 AM
    Clearwater Bill
    Billy
    Largo Florida
  10. Apr 13, 2015 at 7:35 PM
    Kourtny14
    kourtny
    GA
    Thanks for all the replies. I think he was trying to pull one on me because he was also trying to get me to buy a bigger rim size... I think ill go with the two inch lift, nothing too big because I honestly just wanted bigger tires! Thanks for all the answers!!
  11. Apr 13, 2015 at 8:22 PM
    Pigpen
    Dan
    Northwest Montana
    Kourtny, you have a prerunner, so you have the option of a spindle lift. Look into this option and question folks who have them. You can go WAY up on a 2wd really easily and run any size tire your heart desires.
