Best axle for SAS????
Discussion in 'Solid Axle Suspension' started by LBFD2005, Feb 28, 2013.
  1. Mar 21, 2013 at 5:53 AM
    #41
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Diamond axels.
  2. Mar 21, 2013 at 12:30 PM
    #42
    Curt7088
    Curt7088 ship jumper extraordinaire
    Curtis
    Jacksonville
    '15 Jeep JKU
    rubi sliders, 3.5" lift, HID headlights 35" nitto terra grapplers and the best... spider web shade
    max-4 wins...
  3. Mar 21, 2013 at 4:50 PM
    #43
    87FoRunner
    87FoRunner MallTaco
    Cameron
    Memphis, TN
    05 TRD 4x4
    ARB. M8000. OME 886. Mickey Thompson Classic Locks. 285 Pro Comp XMT. Pioneer x930bt. Memphis SQ comps. Memphis S class 10. Kragen HIDs.
    The weakest axle and the highest credit card bill :confused:
  4. Mar 21, 2013 at 5:18 PM
    #44
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
  5. Mar 21, 2013 at 6:01 PM
    #45
    Curt7088
    Curtis
    Jacksonville
    '15 Jeep JKU
    joke big guy!
    and i was meaning the most improbable... how many people sas with rockwells still intend to keep it streetable?!@? :p
  6. Mar 22, 2013 at 4:13 AM
    #46
    KiltedRonin
    KiltedRonin Poor Impulse Control
    Ronin
    Silver Spring, MD.
    2011 access cab, MGM, leer 180.
    Unimog portals.. Unless you don't wanna go full width, then look for some Volvo truck portals...
    Then theres rockwells...
    Problems are gears, you end up real limited there...
    Though, in terms of chromoly shafts, there are some available for rockwells now.. They're freaking huge!
  7. Mar 22, 2013 at 8:53 PM
    #47
    87FoRunner
    87FoRunner MallTaco
    Cameron
    Memphis, TN
    05 TRD 4x4
    You can put oversun eng. rockwell 47 spline gun drilled shafts in Dana 80 centers nowadays...
  8. Apr 15, 2013 at 9:37 PM
    #48
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    ford 9 inch center with dana 60 outers. best weight to performance ratio. not exactly as cheap as a yanked d60 though....
  9. Aug 6, 2013 at 6:21 PM
    #49
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    There are a lot of factors to deciding which axle is "best" for a SAS. Tire size, links or leafs, steering type (hydro or steering box), budget. For 40's your should really step up to tons but I would argue that 37's on toy axles will give you the same ground clearance with less weight, cost, and headaches. Unless you have done it you don't really know what it takes to fit 40's and make them work from stuff to full droop and lock to lock, all while keeping a reasonable COG.
    Portal axles are tough to package and keep low without serious frame mods, the gearing is also stupid low unless you are running huge tires. The same goes for top loading 2.5 tons which makes both a non starter for me.
    Ford 9" have very low pinions and the stock third member castings are weak. If you are building axles from scratch they are a reasonable option but if you are piecing together a junkyard axle you are chopping up a Dana 60 for the knuckles out which is going to account for most of the cost of the assembly. I don't see what a junkyard 609 buys you over a D60 except for weight and the drop out third.
    If I were to build a set of axles for a SAS they would be 9.5" FJ80 based. 64" WMS, plenty strong for 37's, and reasonably lightweight.
  10. Aug 7, 2013 at 1:21 PM
    #50
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Holy thread revival.
    Dana 35 hands down
  11. Aug 7, 2013 at 2:38 PM
    #51
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You can throw that Dana 35 in the trash, along with its cousin...Dana 30.
    Dana 44's MINIMUM (or bigger) for any solid axle swap. :D
  12. Aug 7, 2013 at 4:12 PM
    #52
    Slodgetto
    Slodgetto Über Posre
    Silas
    He was joking. :rolleyes:
  13. Aug 7, 2013 at 4:50 PM
    #53
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
  14. Aug 7, 2013 at 6:12 PM
    #54
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    14 bolt with rockwell outers and 8 lug/disc conversion?
  15. Aug 9, 2013 at 7:15 AM
    #55
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    There was a rig at KOH that had that axle setup. So burly!
