Best Bang For Your Buck 4 Cylinder Mods
Discussion in '4 Cylinder' started by 4x4Banger, Nov 19, 2014.
  1. Dec 9, 2014 at 2:21 PM
    #61
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Yes. Correct.
  2. Dec 10, 2014 at 10:41 AM
    #62
    4x4Banger
    4x4Banger [OP] Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    So coil spacers of about 2 inches are fine you just dont want a top plate spacer? And the preloading spring is fine? You just wont have anymore travel then stock.
  3. Dec 10, 2014 at 10:52 AM
    #63
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    should be fine, like I said the bilsteins work by adding preload to the spring also so no difference. I have the top plate spacers on mine and have been good for the most part but I have blown a strut twice now, but I do tend to have a pretty agressive driving style while off roading and can tell you the exact hits that blew the struts so I dunno if they would have held up any better without the spacers.
  4. Jan 8, 2015 at 1:15 PM
    #64
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Does anyone have any good suggestions on off road tires for the 4bangers.... so they don't get weighed down to much but still have decent size aggressive tires
  5. Jan 8, 2015 at 4:20 PM
    #65
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    I'm gonna be going with some 315/70/17's shortly but not sure what tire exactly yet
  6. Jan 9, 2015 at 8:15 AM
    #66
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Boom! That will be nice. When I upgrade I want to go with a larger more aggressive tire, but have read on hear that the weight of the tire plays a big role with these 4 bangers. Let me know what you end up doing please
  7. Jan 9, 2015 at 8:39 AM
    #67
    numbah57
    kahai
    Maui, Hawaii
    I went with a larger heavier tire, re geared to help this lil motor push them
  8. Jan 9, 2015 at 9:07 AM
    #68
    Indy
    Indy Master of all I survey.
    I put a set of treadwrights on mine, 5 31's for about 400 shipped. 2nd or third rig I've run them on. I haven't regeared yet, need to. The tires worked amazingly well in the snow and ice while elk hunting, crawled up things I really didn't expect to make even with momentum.
  9. Jan 9, 2015 at 9:13 AM
    #69
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    But how much does the re-gearing cost
    They look good but how do retread tires work? Any complaint from anyone? Would they have as much structural integrity as a norm none retreaded tire?
  10. Jan 9, 2015 at 9:42 AM
    #70
    numbah57
    kahai
    Maui, Hawaii
    The re-gear is pretty costly unless you can do the work yourself, which I can't.
  11. Jan 9, 2015 at 9:43 AM
    #71
    michaelrussell
    Michael
    belleview,FL
    Will do if I have to many issues I'll regear with some 4.88's detroit locker I seen trail gear has a full third member for right around a grand if I remember right
  12. Jan 9, 2015 at 10:09 AM
    #72
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Which tread wrights did you buy? And like I said are they just as strong as new tires?
  13. Jan 9, 2015 at 10:40 AM
    #73
    michaelrussell
    Michael
    belleview,FL
    I didn't buy tread wrights that was him ^^^ but I myself wouldn't buy retreads I've ran on trailers and they didn't last very long
  14. Jan 9, 2015 at 10:45 AM
    #74
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    hahahahaha my bad :anonymous: ! But thank you for your input on the the retreads! That must be why they are so cheap
  15. Jan 9, 2015 at 10:48 AM
    #75
    michaelrussell
    Michael
    belleview,FL
    Not a problem
  16. Jan 10, 2015 at 9:05 PM
    #76
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    So you can break the shock with a top plate spacer (full compression), nice. An extended bump stop would elevate this issue?
    And a coil spacer will over extend the shock (full droop). A limit strap would elevate this issue? (prolly not really needed unless your jumping your rig :eek:)
  17. Jan 11, 2015 at 8:46 PM
    #77
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    I have a 2011 access cab. Im using 265/75/16 goodyear duratrac wranglers. They're an all season tire. Forget the weight of them, but they have a nice aggressive tread, with some teeth on the side wall too. Very happy with them. White writing out!!
  18. Jan 12, 2015 at 9:56 AM
    #78
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Cool, thanks for your input guys!
  19. Mar 12, 2016 at 5:27 PM
    #79
    Kwik
    Kwik Well-Known Member
    Kyle
    Seattle
    2011 Tacoma 4x4 2.7L
    Did you also replace the cats as well? I know they are expensive so would it even be worth it? Thanks!
  20. Mar 12, 2016 at 5:42 PM
    #80
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    That header looks good, albeit for a 2nd gen which should be included as there are many 1st gen guys looking to acquire gains.
    I can only speak of the shorty header for the 1st gen... nothing gained whatsoever except lower under hood temps... I've posted this many times, at least that's my experience.
    OP, stick with a FRAM for the stock air box, cheap, available everywhere and no MAF cleaning required.
    Hope this helps you.
    4x4Banger[OP] likes this.
