Best Bang For Your Buck 4 Cylinder Mods
Discussion in '4 Cylinder' started by 4x4Banger, Nov 19, 2014.
  1. Aug 30, 2016 at 12:25 PM
    #121
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    thanks greg it looks like the header will be my next performance mod and probably retain the stock exhaust at least for now thanks for doing all the research i understand it's for your benefit primarily but sharing it is a great thing to do for the rest of us who don't have access to a dyno
    TownvilleTim likes this.
  2. Aug 30, 2016 at 6:21 PM
    #122
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    It's my pleasure. :)
    I sold enough 2.7 Tacoma and 1.5 Yaris tooters to cover all of the dyno testing expenses so it basically cost me nothing.
    Greg
    TownvilleTim and Casper66 like this.
  3. Sep 6, 2016 at 7:34 PM
    #123
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Thank you also, for blazing the trail. Your various posts on various threads have outlined the "formula", as well as the break-down of what the various ingredients in the "formula" are worth by themselves, in making up the end result. You did a lot of good investigative footwork, to get the results that you did in presentable format.
    I'm looking for a bit of usable torque on grades, to return.. so an LCE it will be, in a continuation of your experiment. It's either that, or it's a borderline need to re-gear to 3.73 (ouch!) with a new 3rd member. That is running 16x7's on LT225/75R16's -29.3" vs 215/70R15 - 26.9".. A happy compromise between preserving fuel efficiency, and hauling utility. It does otherwise fine on flat grades, and i'd rather try this route first, than go the much more expensive re-gear with a replacement 3rd member route the 5-lug 5-speeds need to go, to run much higher than 30". I actually like the marginally improved fuel economy of the present gearing with it turning lower RPM's at highway speeds.. but i've got a few highway bridge grades, that keep you rowing from 5th-4th-3rd-4th just to maintain velocity.
    Incidentally, i also have a freshly warrantied catalytic (nice clean, unrusted bolts!) assembly, and a 22" Magnaflow already squirreled away, as per some of your testing. The stock muffler wasn't rusty enough to replace ... yet.
    Interesting, parallel paths.. my trade-in for the econo-Tacoma, was the 2007 Yaris 3 door hatch. Fun little Mario-Kart. Mine came with the bigger alloy Toyota Accessories rims, with the low-profile sport tires.
  4. Nov 24, 2016 at 2:33 PM
    #124
    KaosTsoc
    KaosTsoc Well-Known Member
    Ft. Hood Tx
    06 Prerunner
    I have read this whole thread. a lot of good info here. and for what's it's worth I have done some of the upgrades mentioned on here. I have the LCE headers, kept the two cats, and put in the LCE exhaust from the back of the cat. I also put in the AFe stage two cai. Now when I was talking to gadget from URD he said to get the best result and any true performance out of any cai you need to use a MAF calibrater. which I have but have not installed it yet. because the calibrater has a blank map I have to map it myself. But as of now the performance I'm getting is good and noticed a nice I crease of speed an TQ. so to the OP I hope this helps you out.
    Casper66 and HackD like this.
  5. Nov 27, 2016 at 6:26 AM
    #125
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    How has all of this affected the fuel economy? And the LCE long tube bolted right in place up to the factory cats?
  6. Dec 2, 2016 at 6:53 PM
    #126
    Sitnlow4life
    Sitnlow4life Member
    Detroit
    1996 T-100 3RZ
    LCE header , magnaflow high flow cat.
    Any one do a Big bore throttle body ?
  7. Jun 23, 2021 at 9:04 AM
    #127
    Clearwater Bill
    Billy
    Largo Florida
    Thread started in '14, last post above yours was '16.
    Zombie hunter you are. :infantry:
    PintSize and 4x4Banger[OP] like this.
  8. Aug 19, 2021 at 8:30 AM
    #128
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    using 91 octane fuel
  9. Aug 20, 2021 at 3:14 AM
    #129
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Unused URD MAF calibrator available.......
