"Best Battery" for OEM Replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beriman10, Jul 27, 2018.
  1. Feb 14, 2024 at 7:01 AM
    #181
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    No common sense - a exercise in stupidity - my 2000 frame rusted out - my 2008 looked different but it rusted out too - so they just keep doing the same thing expecting different results.
  2. Feb 14, 2024 at 7:18 AM
    #182
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    :rofl:Haha I’m sure Toyota has corrected the issue.
    They sell and hold value at least.
    I don’t consider them long term vehicles any more.
    Not in the rust belt at least.
  3. Mar 23, 2024 at 12:05 AM
    #183
    StinkFu
    StinkFu Well-Known Member
    Pacific Northwest
    2022 Tacoma TRD Pro MT
    AJT Design Tacoma 4x4 Knob AJT Design Tacoma Climate Rings AJT Design Tacoma Door Handle Covers All-Pro Off-Road HD Rock Sliders Alu-Cab Tilting Fridge Slide Aluminum Radio Knobs Android Auto Cable ARB Twin Air Compressor AWE 0FG Exhaust with BashGuard - No Tips Badland Jack Mounts Badland Off-Road Jack Baja Design Rock Lights / Scene Pods Black Door Handle Covers Bolton Velocity Off-Road Kit Cali Raised AC Drip Relocation Cali Raised Center Console Molle Panels Cascadia 4x4 45W Panels & Controller Ceramic Coating CourseMS Phone Mount Desert Does It Seat Blocks & Panel Diode Dynamics Ditch Lights Diode Dynamics Stealth Light Bar Kit Dual Circuit Breaker Battery Tie-Down Expedition Essentials Panel Bracket Factor 55 HitchLink Flag Stickers Glove Box Letter Inserts GloveBox Organizer Hella Supertone Horn Kit Icon 1.5 Inch Lift Rear Expansion Pack Interior LED Light Kit Interstate AGM 24F Battery KC Hilites Under Hood Light Krazy Beaver Shovel and Cover License Plate Frames Magnuson Supercharger MAXTRAX Xtreme MAXTRAX Xtreme Mounting Pin Meso Customs Gasshole Meso Customs Vent Ring Kit MESO Overhead HexRack - Sunroof Mishimoto Radiator MMRAD-TAC-16 Nilight 3PCS 60 Inch Bed Light Strip Nitto Ridge Grapplers 285/70R17 Quick Charge 3.0 Dual Charger Socket RedArc Dual Input + 40 Amp Fuse Kit Rhino Rack Stow It Utility Holder Rhino Rack Stow It Utility Holder Rhino Sunseeker 2.0m Awning Rhino USA D Ring Shackles Rhino USA Trailer Hitch Lock RSI SmartCap Evo Sport RSI SmartCap Platform Rack SDHQ Battery Terminal Kit Seven Sparta Grill Led Lights Shift Knob Adapter SmartCap EVO Security Screen - v2 Smartcap MOLLE Panel Steering Wheel Cover Steering Wheel Emblem SumoSprings Front SumoSprings Rear Supreme Suspensions Front Tow Hooks Switch-Pros 9100 Switch-Pros Power Tray Wiring Bundle Tacoma Door Clean Up Kit Tacoma Door Sills Tacoma Lifestyle Sequential Turn Signals Tacoma Tailgate Inserts Tail Gater Tire Table Total Chaos Bed Stiffeners Toyota Cargo Net Toyota TRD Pro Shift Knob TRD PRO 17 Matte Black Alloy Wheels TRD PRO CAI Box & Accelerator TruckVault - Utility Height Uptop Alpha Rack - 38" Extreme LEDs Uptop TracMOUNT Vinyl Letter Decals for Tailgate Handle Vinyl Letter Decals TRD Pro Bedside Vinyl Letter Decals TRD PRO Grille VLEDS Dual Output Front Footwell Kit VLEDS VTAILS Taillight Conversion Kit WeatherTech Bug Deflector WeatherTech Rain Guards Wescott Tacoma Fox TRD PRO Lift Kit
  4. Mar 23, 2024 at 4:25 AM
    #184
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Silver Tacoma Limited
    32in Tire
    It would. Agms require higher charging voltages than floodeds. 2nd gens you can fool the alt s circuit to get more voltage. But the 3rd gens it's controlled by the ecu. Can you run it without it? Yeah, but what @crashnburn80 talked about, you won't be charging it enough to keep it healthy. So, you will kill the battery faster.
    StinkFu[QUOTED] likes this.
  5. Mar 23, 2024 at 11:29 AM
    #185
    StinkFu
    Pacific Northwest
    Got it. thanks for such a thorough answer. More stupid questions, if I am running the cascadia 4x4 solar panels on my truck, is that enough to keep the AGM topped off without doing an ECU tune or using a trickle charger? Also, how much battery degradation would occur if I just drop a 24f in there and use it as is? Are we talking cutting the lifespan in half, or 3/4?
  6. Jan 24, 2025 at 5:44 PM
    #186
    Truckinkoots
    Truckinkoots Member
    2011 Tacoma TRD Off-Road
    Contributing to this thread as I just replaced the Battery in my truck for the first time since purchasing it in May 2021.
    Started looking into batteries when my truck was struggling to start on a few cold mornings recently.
    Went with an Interstate MTP27F as I have the tow package and the battery that I was removing was a 27F.
    The most time consuming part of the replacement was getting all the battery corrosion off of the metal hold-down bracket. It required some soaking in a "warm water baking soda solution" and some scraping but I eventually got it all off.
    First couple start-ups since the replacement have been quick and smooth with fewer turnovers than with the old burnt out battery.
    koditten likes this.
  7. Jan 25, 2025 at 3:07 AM
    #187
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I don’t know about the x2 battery but I can tell you that I just replaced my 10 year and 1 month old Die Hard platinum 24f AGM. Never used a voltage booster and no wall charger. And yes, it lasted that long. The single digit temps this past week were low enough to drain it to the point of not having enough juice to start but still had lights etc. oh and that was after sitting for 12 days while I was out of the country. Jumper pack on it and it fired right up. But I knew it was probably on its last leg anyway so I replaced.
    point being, drop the 24f in there and call it a day.
    StinkFu[QUOTED] and steelcity2 like this.
  8. Jan 28, 2025 at 1:24 AM
    #188
    StinkFu
    Pacific Northwest
    Great to hear! Thanks so much for the info, I appreciate it.
