"Best Battery" for OEM Replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beriman10, Jul 27, 2018.
  1. Jul 30, 2018 at 6:54 AM
    #61
    beriman10
    beriman10 [OP] Well-Known Member
    Omar
    Orange County
    2019 Jeep Wrangler Unlimited Rubicon
    Fox 2.5 Suspension 2 in Lift
    Ended up picking the Costco battery but had to go 15 miles farther then the closest Costco because apparently they don't stock very much of these batteries. Checked autozone but the price was 160 for the Duralast Gold which had a similar warranty to the Costco battery that was 90!
    BillsSR5 likes this.
  2. Jul 30, 2018 at 6:55 AM
    #62
    Namrog456
    Namrog456 Well-Known Member
    2022 TRD Pro Tundra
    2018 TRD Pro DCSB AT - SOLD 2017 TRD Pro 4Runner - SOLD 2020 SR DCSB - SOLD 2022 TRD Pro Tundra
    Can't go wrong with a long warranty! Make sure you test it around 34 months (if it lasts that long).
  3. Aug 21, 2018 at 1:45 PM
    #63
    John Mc
    John Mc Well-Known Member
    Vermont
    2009 Tacoma SR5 4x4 Access Cab
    Added trans & engine oil coolers. (No factory tow pkg)
    Need to replace my battery. Looking an Interstate from Costco for $90. Interstate's web site says $132 at other dealers. Are these the same batteries, or does Costco get some cut-rate version?
    I checked Walmart, their web site says they have Group 27, but not the 27F. I've heard the cables will not reach on at 27, is that correct?
  4. Aug 21, 2018 at 1:55 PM
    #64
    Namrog456
    2022 TRD Pro Tundra
    Compare the specs of the battery (Amps, CCA, etc); that's the only way to know if you're getting the same thing. 27 is a standard-pole battery, 27F is reversed. Your cables will (likely) not reach with a standard 27- not worth the risk.
    Brie and beriman10[OP] like this.
  5. Aug 23, 2018 at 1:29 PM
    #65
    John Mc
    Vermont
    I know how to compare the specs. The specs don't really tell you much about durability.
  6. Aug 23, 2018 at 1:44 PM
    #66
    Namrog456
    2022 TRD Pro Tundra
    Durability is going to be all in the manufacturing process, the lead plate thickness, and even the build date/shelf life of the battery. If you're looking for unwavering performance, you have to go to AGM.
  7. Aug 23, 2018 at 2:00 PM
    #67
    John Mc
    Vermont
    Hence my question on whether the Costo version of the Interstate 27F battery is the same as what is carried at other Interstate dealers.
    I agree AGMs are great batteries. I have an Optima Yellow Top in my tractor, and it has been working well for several
    years now. However, prices have doubled since I bought it, and I've heard bad things about Optima's quality starting at the time they moved production to Mexico. I don't know if they have resolved the issues yet. (I do like the fact that Optima recommends the same charging and float voltages for their AGM batteries as are standard for flooded lead-acid batteries. That's not true of most AGM batteries, so their life is shortened slightly if you don't use an AGM-specific charger.)
  8. Aug 23, 2018 at 2:02 PM
    #68
    Namrog456
    2022 TRD Pro Tundra
    Understood. Unfortunately, I can't say for certain, but I'd say it's unlikely they're the same product. However, with the warranty from Costco you may want to take that risk.
  9. Aug 23, 2018 at 2:43 PM
    #69
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I gave up on Costco's cheap 24F batteries - used in an '06 Avalon. Went thru 3 of them in about 2 yrs. time approx. There is a reason why they cost $90. Thank God they don't hassle you about a return like my local Auto Zone does. Switched to Walmart's Maxx whatever battery. Problem solved.
    Questions asked above about the Costco Interstate being the same as what you get at an Interstate dealer. I am not able to answer that question, but will say...I doubt it.
    Brie likes this.
  10. Aug 23, 2018 at 2:56 PM
    #70
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    The Autozone Gold is a pretty decent AGM. Is the Costco AGM with the same specs?
  11. Aug 23, 2018 at 3:28 PM
    #71
    Tacomax4
    Tacomax4 Well-Known Member
    2012 DCLB TRD Sport 4x4
    I’ve always had good luck with the Napa batteries, and I live to where it drops to -40C in the winter
    Rsmallw2 and MolonLabeTaco like this.
  12. Aug 23, 2018 at 4:59 PM
    #72
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    This says a lot. Cold is what kills batteries but they die in the heat. Weird, I know.
    Neat fact, -40 degrees Celsius is also -40 degrees Fahrenheit!!!
    Brie, Jake1530 and Tacomax4[QUOTED] like this.
  13. Aug 23, 2018 at 5:01 PM
    #73
    John Mc
    Vermont
    Unfortunately, I want a 27F, and Walmart does not carry that type.
  14. Aug 24, 2018 at 3:15 AM
    #74
    Namrog456
    2022 TRD Pro Tundra
    To clarify: Batteries degrade due to heat, not only that coming off your engine, but also ambient temps... the symptoms of a dead/depleted battery only become visible in winter when full power is needed.
    Check your batteries in fall, people. It'll save you the headache in the winter.
    BC Hunter, Kolter45 and Stryker420 like this.
  15. Aug 24, 2018 at 6:06 AM
    #75
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    You may be correct. I was going off this phrase:
    “Then when winter comes, “Temps don’t have to fall far to make starting a car too hard for a heat-weakened battery. Cold kills car batteries. And heat is its accomplice,” adds Interstate.”
  16. Aug 24, 2018 at 6:19 AM
    #76
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    ever wonder why it mounted in the front?
    to keep cool in summer
    exhaust, radiator, engine, AC can keep temps up high in the engine compartment
    On most trucks, a finned trans pan wont do much for cooling since the air going to it is already hot.
    Even the rear diff don't benefit much from cooling fins because of the engine heat but they look cool like a jeweled butt plug
  17. Aug 24, 2018 at 8:13 AM
    #77
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    My dealer in Virginia Beach usually has a sale on the OEM 27F battery for $90 installed.
    84 months warranty and 24 months roadservice for <$100.
    Fritz
    Kolter45, r1200gs4ok and Stryker420 like this.
  18. Aug 24, 2018 at 8:18 AM
    #78
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Then get a 24f, problem solved. Walmart should stock those.
  19. Aug 24, 2018 at 5:55 PM
    #79
    John Mc
    Vermont
    24F has lower reserve capacity
  20. Aug 25, 2018 at 7:58 PM
    #80
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I have a Wal Mart battery because that's where I was when it died. Came out after shopping and truck wouldn't start. Thankfully, I had a few tools under the back seat.
    20 minutes later, I was rolling back down the road with a new battery. Thank God it decided to die where it did.
    I didn't even get a warning 'slow start', just BAM, nothing.
    Kolter45 likes this.
