Best Battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Oct 18, 2009.
  1. Jan 10, 2018 at 3:55 AM
    #241
    LastoftheGen2
    LastoftheGen2 Well-Known Member
    Mighty Mo
    NY & Vermont
    2015 Taco TRD Off Road
    Fab 4 Bumper with 9,000LB Winch. Prefy high lift rear bumper, All-Pro rock sliders, steel skids, expedition leaf pack and U-Bolt flip kit, King shocks with 700 lb springs, BFG AT KO2's 265/75, Safari snorkel, rear diff breather mod.
    Hello all
    I was doing some research on a possibly dual battery upgrade. Not positive just toying around.
    On one of the sites the manufacture mentioned that they do not sell or recommend Optima batteries and they only sell Odyssey batteries.
    Now I do not know a lot about batteries and have never herd of Odyssey.
    Let me know what you think.
    Thank you
  2. Jan 10, 2018 at 6:29 AM
    #242
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
  3. Jan 10, 2018 at 8:27 AM
    #243
    LastoftheGen2
    Mighty Mo
    NY & Vermont
  4. Jan 10, 2018 at 9:44 AM
    #244
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Just replaced a 6 year old Duralast Gold from Autozone for another. Works for me.
    lynyrd3 likes this.
  5. Jan 10, 2018 at 4:12 PM
    #245
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So, picked one up, are you using the side terminals? The internet tells me it's 3/8? coarse thread, but an actual "battery bolt" is suggested due to the soft metal.
  6. Jan 10, 2018 at 4:56 PM
    #246
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I'm using the side terminals for my winch on the starting battery. I'm pretty that the side terminal bolts are a specific thread and pitch for that application only .
  7. Jan 10, 2018 at 5:06 PM
    #247
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Cool, I was planning for the winch there as well. I’ll head down to the parts store and see what I can come up with, thanks.
  8. Jan 10, 2018 at 6:49 PM
    #248
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    The soft metal is lead or a lead alloy. The other reason is a mismatch of metals will corrode.
  9. Jan 11, 2018 at 5:32 AM
    #249
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    A deep cycle battery is better suited to winching applications than a starting battery. If a deep cycle battery is used for starting an engine, insure that it will produce the recommended vehicle manufacturer's CCA requirements.
  10. Jan 11, 2018 at 7:17 AM
    #250
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Northstar AGM 27F FTW
    MolonLabeTaco, Raincity and Atomic47 like this.
  11. Jan 11, 2018 at 9:12 AM
    #251
    Atomic47
    Atomic47 Well-Known Member
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Leveling kit, AAL, air-ride, Rear diff breather mod, Illuminated 4wd Switch, 4 more D rings, fog lights anytime, 7 pin relocate, Coca-Cola mod, TRD Off-Road hook, Weathertechs, secret custom cargo light, 09 lower dash panel, heated seats, 2013 oem touch screen radio, reverse camera added into Pop'n'Lock locking tailgate handle, black powder-coated TRD Sport rims, 32" light bar in custom fabricated mount, aux reverse lights in rear bumper
    Glad to hear this. I just bought on on Monday. :thumbsup:
  12. Nov 24, 2018 at 4:39 PM
    #252
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So, mine shit the bed in less than a year, it stopped holding a charge for more than a few days. Took it out for warranty and it was swollen, dude at Sams tried to convince me it was a marine and not intended for this application. Got the same one but may take it back and get the starting one, which unfortunately doesn’t have the side terminals so I’ll have to do a bunch of rewiring.
  13. Nov 24, 2018 at 5:41 PM
    #253
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I too bought the northstar but must have got an old or possibly defective one because it started to have issues with holding a charge after 2 months. After researching on TW and needing a replacement quickly I went back to the yellow top optima. Really bummed about it but couldn't afford another. Then as if it were meant to be I was given another yellow top, same group size and only a few months difference in manufacturer's date. So I ran the lines and relays and and whatnot so now I have dual battery setup. My last yellow top gave me about 8 years so...fingers crossed.
  14. Nov 24, 2018 at 5:45 PM
    #254
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    A best battery thread started in 2009 from NJ?
    See the Odyssey batteries listed down below for $300. Buy one of them.
    Somebody 10+ years ago told me that they last for 15 years.
  15. Nov 29, 2018 at 4:48 PM
    #255
    Tacos_allday
    Tacos_allday Member
    Inglewood, Ca
    2018 White Tacoma TRD OR
    I'm assuming this fits in a 3rd gen? Looking to upgrade my OEM battery, been getting a lot of toys for the trick .Thinking it's time for a little more juice...
  16. Sep 17, 2019 at 9:07 PM
    #256
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    What size did you go with? My battery died tonight and am thinking about getting a Duralast Gold tomorrow as a replacement.
  17. Sep 17, 2019 at 10:02 PM
    #257
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    The 27F.
