Best Battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Oct 18, 2009.
  1. Feb 12, 2016 at 6:49 AM
    #161
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Just put in an X2Power 24F from a local Batteries+
    It's a rebranded Northstar. Website says $275, however I was charged $233. 60 month warranty (5 years) full replace. 840 CCA
    Fits in the factory tie down, though it's tight (not a bad thing). Comes with a spacer but didn't need it.
    Can't back it up, but read on another forum that Northstar was founded by a few original Odyssey engineers, hence the similar design. Supposedly some connections inside are beefier though. Once again, that's all hearsay though.
  2. Feb 12, 2016 at 7:47 AM
    #162
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I really like my Northstar
  3. Feb 12, 2016 at 8:04 AM
    #163
    OZ-T
    Peter North
    British Columbia
    Get a Northstar 27F
  4. Feb 12, 2016 at 8:10 AM
    #164
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    I have a conundrum. I work out of town for 3 weeks every 3 weeks (21 days on shift, 21 days off shift). This winter I've noticed that my truck battery dies while I'm at work. First winter with the vehicle. My truck has an Ultra-Gauge and a CompuStar Auto start running off the stock Toyota battery. Is there a battery that can hold a charge in 0-15F temps after sitting for 3 weeks? Normally I would just have my roommate start the truck up once a week, but he's not really all that reliable and throwing it on a trickle charger for a few hours when I get home is getting annoying.
  5. Feb 12, 2016 at 8:28 AM
    #165
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Disconnect the autostart for long shutdown periods.
    doublethebass likes this.
  6. Feb 12, 2016 at 8:44 AM
    #166
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    About to get the same one for my wifes pilot. Best bang for the buck.
    Dont forget the $25 gift card, think they are running a promotion.
  7. Feb 12, 2016 at 9:09 AM
    #167
    OZ-T
    Peter North
    British Columbia
    What did it cost you for the 27F ?
  8. Feb 12, 2016 at 9:18 AM
    #168
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Tell me more... size? my diehard group 31m is dieing.... The fridge isn't running like it use too and its having lots of trouble starting on cold mornings
  9. Feb 12, 2016 at 9:28 AM
    #169
    OZ-T
    Peter North
    British Columbia
    Interesting , I was just wondering because at the current exchange rate , at the place I got my Northstar 27F from up here , it would be $266 USD for the Northstar 27F including free shipping anywhere in Canada
  10. Feb 12, 2016 at 9:31 AM
    #170
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Assuming that you have a healthy battery and charging system and the battery is fully charged when you park, here are some simple solutions to offset the parasitic drain and natural self discharge of long term parking/storage. If you have access to AC power where you park, use a small temperature compensated smart battery charger with a quick disconnected while you have the vehicle parked to keep the battery fully charged. Examples of chargers are Battery Tender Plus, BatteryMinder, etc. If you do not have access to AC power, then you will either have to use a minimum of 15 watt Solar panel to keep the battery charged, add enough capacity to your existing battery, or use a battery disconnect switch. Disconnecting the battery by removing the negative terminal will work, but is not very practical. For more information, please see the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  11. Feb 12, 2016 at 9:35 AM
    #171
    Mademan925
    Nick
    Discovery Bay, CA
  12. Feb 12, 2016 at 9:36 AM
    #172
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Exide AGM for the win
  13. Feb 12, 2016 at 11:00 AM
    #173
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Thanks for the tips. I usually only work 2 week rotations, but they changed me up March of 2015 to May 2016. After then I won't have to worry about it. Think I'll just disconnect the battery. Easy fix, and if anyone needs to borrow it, they just have to pop the lead back on the terminal. I have a battery tender I used to use on my motorcycle, but I park the truck outside and the unit isn't rugged enough for long term weather exposure. Was just curious of a beefier battery would solve my issues. I should just follow the KISS acronym (Keep It Simple Stupid).
  14. Feb 12, 2016 at 11:05 AM
    #174
    OZ-T
    Peter North
    British Columbia
    930 / 195
  15. Feb 12, 2016 at 11:22 AM
    #175
    Mademan925
    Nick
    Discovery Bay, CA
    If I pick up a dual battery tray and two new optima batteries. Can I daisy chain them till I get an isolator and everything installed?
  16. Feb 12, 2016 at 6:59 PM
    #176
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Chris, there are a number of variables that affect the parasitic (key off) load, natural self discharge, and the service life of a lead-acid battery. If the combined load on your battery averages 300 ma, 7.2 amps is consumed every 24-hours. Assuming that you have a healthy and fully charged wet Group 24F battery which produces approximately 60 amp hours at 77 degrees F, then it would lose one half of it's charge within approximately five days. A fully charged wet Group 31 battery will produce approximately 100 amp hours. With a 300 ma load, it would be 50% discharged within nine days.
    Now the question becomes what is the ambient temperature you are trying to start your engine with a wet battery with 50% State-of-Charge? At 80 degrees F, the battery could easily produce the 300 amps to crank the engine. However, at 0 degrees F, it would be problematic for the battery to produce 500 to 600 amps that would be required. One of the challenges with disconnecting the battery is that it will reset the Emission Control Unit to the defaults. If the engine has any other problems like a dirty MAF sensor or clogged air filter, it might be even more difficult to start. Another challenge is that the the battery could freeze when the battery drops below a 25% State-of-Charge at 0 degrees F.
    In other words, temperature matters! This is clearly demonstrated in the following diagrams from Exide and Interstate, respectively.
    doublethebass and 1madmnky like this.
  17. Feb 12, 2016 at 7:06 PM
    #177
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    So are there any differences between 24/27/31 batteries, or are those just names for that exterior size? I know the cca and all those are different from battery to battery, just trying to figure it out.
    And, do all three of those sizes fit in the stock location or do you have to modify things?
    I am wanting to replace my OEM battery so I can leave the fridge running 24/7. Truck is driven daily, and down the road, a winch might be the only other thing to pull power. I have lights and small stuff, but I dont use them when the truck is off.
  18. Feb 13, 2016 at 8:06 AM
    #178
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Thanks for the explanation and diagram. I only have 2 more shifts before I'm back to working in town. I live in the area marked "extremely cold" with the shortest battery life. Guess I'll just have to harass my roommate to start and run the truck every week. With two week rotations I never had a problem, but these three weekers are proving to be problematic.
  19. Feb 15, 2016 at 8:40 AM
    #179
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Typical OEM design is for two weeks "airport parking". Actually extremely cold has the longest battery service life. In hot climates you are lucky to get three years because the higher temperatures accelerates negative grid corrosion.
    If you decide to increase the capacity by installing a second battery wired in parallel, be sure that it is identical to the first one for longer battery life for both batteries and to keep both of them fully charged when the temperature drops below 0 degrees F to prevent freezing. For the same battery type, Group 34R typically has least CCA performance and amp hour capacity. Group 24F has more followed by 27F and 31 respectively. The weight of the battery is an easy way to tell what which battery will have more capacity with the heaviest with the most. In some Tacomas, the battery tray should be replaced when upgrading from 24F to 27F. Group 31 will probably require modification. If you have a lot of off roading vibration, then an Flat Plate AGM is a better choice than a wet battery. For extreme vibration or military applications, a Spiral Wound AGM is normally better choice. When replacing a wet battery with an AGM, you might need to increase the OEM charging voltage to keep the battery fully charged. Premature AGM battery failures is a whole other discussion.
  20. Feb 15, 2016 at 8:47 AM
    #180
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    My 2011 has the original Toyota battery--the larger tow package one, not sure what group size that translates to.
    It started just fine the other night when it hit about -22°F, but I figure I'll preemptively replace it before next winter. Went with a DieHard Platinum for my Outback and loved it, but sounds like they may not be as good as they used to be.
