best brake pad rotor combo
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Apr 18, 2010.
  1. Apr 18, 2010 at 8:01 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    Experiencing some front end vibrations when braking. It's about time to change out the pads, but should change out the rotors as well, as they have been turned a couple times already.
    What's a good combo for the 1 st gen tacomas?
  2. Apr 18, 2010 at 9:06 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I love the PowerSlot slotted rotors and Hawk LTS pads! It helped alot in my stopping ability bc of my 33's.
    Not sure If the group buy on them is still going on though.
  3. Apr 18, 2010 at 9:58 AM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    I always go OEM for pads and rotors. If something is going to go wrong with my brakes i want it to be toyotas fault.
    Mush Mouse and char211 like this.
  4. Apr 18, 2010 at 1:11 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Def OEM on rotors. I didn't for pads though because I bought an aftermarket loaded caliper and the pads haven't worn yet.
  5. Apr 18, 2010 at 3:04 PM
    4421.frank
    Southside chicago
    hmmm, a couple of yeah's for OEM parts and one for the Powerslot slotted rotors and hawk pads.
    well, what's up with the powerslots evertaco?
  6. Apr 18, 2010 at 3:09 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    EBC slotted and dimppled rotors with EBC greenstuff pads great product
    Dj Suisav and thecoz like this.
  7. Apr 18, 2010 at 4:19 PM
    ETaco23
    Evan
    PNW
    The OEM's are good. But I needed something better bc of my larger tires. My pads and Rotors were suffering. So I would say If you dont have the need for upgraded Rotors, dont bother with it. The OEM Rotors and a good pad like the Hawks will do just fine, If not better then stock
  8. Apr 18, 2010 at 4:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i like my s/p slotted rotors and hawk lts pads way better than the stock setup i once had.
  9. Apr 18, 2010 at 5:05 PM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    X2. This us what I am going to run once my oem's need to be replaced.
  10. Apr 18, 2010 at 5:12 PM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    For lifted weighted Tacomas I was reading about a Tundra Caliper & rotor swap.
    Better breaking + uses OE Toyota parts.
    Only requirement was 16" wheels and a slight modification to your oe banjo bolt.
    http://www.tacomaterritory.com/forum/showthread.php?t=51597
    Being that I'm stepping up to 35's and will tow my boat to and from the lake around town ~ The Tundra Caliper / rotor swap got my attention.
    I'm in the middle of a frame swap & 6" lift + fixing PO's crash damage. So I'm at least 1 month + another $1k from driving mine.
  11. Apr 18, 2010 at 6:03 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    If OEM rotors stick to OEM pads, the rotors will thank you. If you wanna get replacement rotors then Brembo blanks are a great replacements and there is also PowerSlots.
  12. Apr 19, 2010 at 5:39 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    centric rotors and ebc yellow stuff pads. ....that's the best combo i've come up with.
    the stock pads and rotors are complete crap.
  13. Apr 19, 2010 at 8:06 AM
    Fuzzyman81
    Fuzzyman81 The New Guy
    Jax, FL
    04 PreRunner TRD
    Ok - noobie question here so please dont flame - I am looking at rotors myself - when I am looking I am asked Engine size (I got that down - 3.4L V6 ) but I am being asked my Chassis ID (VZN 15 , VZN 17, VZN 19 ) how can I tell???
  14. Apr 20, 2010 at 6:11 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    what site are you trying to order from?
    all you need to know is year modle, engine size and if it's a 4x4 or not.
  15. Apr 20, 2010 at 9:18 AM
    Fuzzyman81
    Jax, FL
    04 PreRunner TRD
  16. Apr 20, 2010 at 9:44 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Cross-Drilled and Slotted Rotors. They Stay cooler and help prevent rotor warpage. Combine those with a good pad like the Porterfields and you will have better stopping power as well.
    http://www.wheelersoffroad.com/tacomabrakes.htm
  17. Apr 20, 2010 at 9:44 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    i just checked it out. ...it says the part is guaranteed to fit no matter which chassis id i pick. ...so apparently it's a non issue.
  18. Apr 25, 2010 at 9:39 PM
    4421.frank
    Southside chicago
    Ok , so it's been a while but just wanted to give some feed back.
    I figured with the ending of one job it would give me some time in between that one and the next to do the brakes. But Nooo!! After getting laid off from power plant I was called out to another. Good for me and my wallet but, bad for the brakes. In the end I decided to drop the truck off at a shop where a friend worked. I ordered Hawk pads and was waivering on rotors but finally decided to go with OEM after some thought.
    So i dropped it off after they recieved botht he pads and the rotors. They told me two hours tops to work it out. So I stopped by two hours before I had to leave for work in the late afternoon. I waited around, after an hour or so, the mechanic came in. H talked to the guy behind the counter and there was some talk, son after the guy behind the counter came up to me. He said the rotors dont fit. I told him that I did not order the rotors, only the pads, the rotors were ordered by the shop. There was some discussion and it was confirmed by the owner that this was the case. In the end they discovered someone ordered rotors for a 2002 TUNDRA!!! there was some apologies and promise to have the part up to their shop in an hour but that still left me very late to work. I told them there was no time to spare. So the owner of the shop very graciously gave me one his "loaner cars" and told me everything would be done by tomorrow and to just take the loaner and head to work. So I did. The next day I came into pick up the truck before work and *poof* I was presemtly surprised to find they only charged me for the parts( the rotors and the broken pin in the caliper).
    Everything worked out well. The understanding of people making mistakes and accepting them came in handy, I was rewarded with generosity that was very unaccepted, but non the less grateful for.
  19. Mar 3, 2011 at 12:10 AM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
  20. Mar 3, 2011 at 12:12 AM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I've heard great things about these rotors and pads they sell.
