Best brand of projectors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheSmash133, Sep 5, 2012.
  1. Sep 6, 2012 at 4:28 PM
    #41
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    what year is your truck btw?
    just curious......
  2. Sep 6, 2012 at 4:31 PM
    #42
    TheSmash133
    TheSmash133 [OP] Cruise
    Orange County
    2006 Toyota Tacoma Access Cab SR5
    X-D Series Black Rims 12 in sub Amp Super 44 Flowmaster Dual exhaust K&N airfilter Tint Tanneua Snug top Side Steps Blacked out Emblems and lower valence Bright white interior lights Blue dome light Retrofitted Mini H1's and morimoto X-B Halo.....
    2006
  3. Sep 6, 2012 at 4:32 PM
    #43
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The best kit they stock is most likely the LS460 projector. If you're doing the install yourself, I wouldn't even attempt it. The Morimoto Mini kit, either the H1 or D2S kit, are great little projectors and are easy to install. The next step up is the FX-R projector kit and is a little more difficult to install but has a better (wider) light pattern and will take a 55W HID kit (morimotos will but it's not advised since they're a smaller projector).
    For a good, solid kit that you can install yourself, I'd go for the Morimoto D2S kit. Pick which ever shroud strikes your fancy and whatever bulb color you want (I wouldn't go higher than 6000K, 4300K is optimum), get some resealing glue and you're off to the races. Call them if you want and Matt or Andrew can set you up with everything you need.
  4. Sep 6, 2012 at 4:35 PM
    #44
    AsianAnts
    AnT
    :thumbsup:
  5. Sep 6, 2012 at 4:37 PM
    #45
    TheSmash133
    Orange County
    Alright thanks guys, Im just gonna call them. Im leaning towards the 6k fxr's and the white halos.
  6. Sep 6, 2012 at 4:39 PM
    #46
    AsianAnts
    AnT
    cool cool... lotsa threads out here in TW on people doing FX-rs and write-ups.. research some before you pull the trigger.
  7. Sep 6, 2012 at 7:33 PM
    #47
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Why?
    Less usable light.
    Factory is 4300k, 5000k is still pretty white.
    6000k starts getting to be too blue.
  8. Sep 6, 2012 at 7:36 PM
    #48
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    X2 the optimum amount of light output is 4,300K
  9. Sep 6, 2012 at 7:38 PM
    #49
    Rich91710
    Rich
    Los Angeles
    08 Base
    People get the impression that HIDs are blue because of the color distortion at the cutoff, which is what you normally see when a vehicle is approaching with properly adjusted projectors.
    Last year, the rage in my area was YELLOW headlights.
    I think the cops put the hammer down... haven't seen any in a long time.
  10. Sep 6, 2012 at 7:42 PM
    #50
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    OP, if u want to match the halo's with the projectors get 5k...5k is white, still a hint of blue...6k is more blue, and like the other guys said, less light output
  11. Sep 6, 2012 at 7:42 PM
    #51
    TACOMABOSS
    96 SR5 4x4
    I dont see why you would want either. I would rather have the most light output available
  12. Sep 6, 2012 at 7:53 PM
    #52
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Why is it do hard to install the LS460 projectors?
  13. Sep 6, 2012 at 8:05 PM
    #53
    TheSmash133
    Orange County
  14. Sep 6, 2012 at 8:12 PM
    #54
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'm not sure the FX-R projectors would fit in the Protuning housings.
    Edit... on 2nd look, it might be difficult to get anything larger than the Mini-H1 into that particular housing. There's not a lot of room between the projector and the marker light/reflector.
  15. Sep 6, 2012 at 8:12 PM
    #55
    Large
    Large Red
    Not sure what thread / person you are referring to but not in my case.
    Incorrect. Andrew chimed in the thread to let everyone know that he was "handling" the situation but nothing more happened beyond that point. And I am / was a paying customer. My rant only got worse after the fast that I bought my items and went 2 weeks without headlights due to their screw up.
    Sorry to thread jack good luck bud.
  16. Sep 6, 2012 at 8:12 PM
    #56
    TheSmash133
    Orange County
    Yes^^ I want to buy a completely new set of headlights (angel eyes). I want to install TRS HIDS in them
  17. Sep 6, 2012 at 8:13 PM
    #57
    TACOMABOSS
    96 SR5 4x4
    hmmm... What? lol angel eyes are not part of the headlight housing
  18. Sep 6, 2012 at 8:14 PM
    #58
    TACOMABOSS
    96 SR5 4x4
  19. Sep 6, 2012 at 8:15 PM
    #59
    TheSmash133
    Orange County
  20. Sep 6, 2012 at 8:17 PM
    #60
    TACOMABOSS
    96 SR5 4x4
    Those have projectors in them already
    Edit: and they have angel eyes (halos)
