Best car battery brand?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma4Ewa, Feb 23, 2018.
  1. Feb 23, 2018 at 1:55 PM
    Tacoma4Ewa
    Tacoma4Ewa [OP] Active Member
    2004 Toyota Tacoma Pre-runner Double Cab
    None
    When I was living at home with my parents, I had a covered garage, so my car battery would last about 5 years, sometimes longer. Ever since I moved out on my own, closer to the ocean and salt water in the atmosphere, and also no covered car port or garage I notice the average life of my car battery has been about 3.5 years. I usually go with Interstate or Die Hard, should I invest more and buy an OPTIMA? I have a 2004 Toyota Tacoma Pre runner double cab, V6 engine. Also what are AGM batteries? I was told that places like Nevada and Arizona are lucky if car batteries last 1 year, is the heat really a factor?
  2. Feb 23, 2018 at 2:12 PM
    GR8APE
    GR8APE Well-Known Member
    Automobile batteries are strange things sometimes. I've had good luck with with some and bad at other times with the same brand. I have a 17 yr old john deer lawn tractor that had the same battery for 11 yrs., since then I've had 1 of the same brand and 2 of other brands. Last summer I had to replace the battery in my 2016 Tacoma OF yet I have a 2010 Highlander that's still running the original battery even though it only has 25000 miles on it. I have always kept my my batteries serviced so I guess the charging systems and the quality of manufactor are the biggest factors in how long they last. I used to think the weather had a lot to do with it but I live in Alabama where temperatures range from 100 degrees to down in the teens. I usually try to buy the right cranking amps and reserve with the best warranty. I know I probably haven't been of much help but this has been my experience.
    Tacoma4Ewa[OP] likes this.
  3. Feb 23, 2018 at 2:16 PM
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    Heat is a major factor, but to the other reply, it's all relative to how well it was made. There is a reason the automotive industry has tests for all new car parts and it's called "Arizona Testing"... if whatever part you make can handle that heat and sun, it's good.
    Heat just wears stuff out faster and cold reduces/slows the chemical reaction so you get less power to the starter. That's about all that I know on batteries. Salt environments are bad on everything, so that doesn't help any.
  4. Feb 23, 2018 at 2:43 PM
    Tacoma4Ewa
    None
    Thanks for the reply. GR8APE, what do you mean by keeping your batteries serviced? Is there something additional I can do to make my battery last longer? I thought most batteries were maintenance free now days?
  5. Feb 23, 2018 at 3:15 PM
    SimplexFish
    SimplexFish Well-Known Member
    Mahaff
    Houston, Texas
    2004 Tacoma Double Cab PreRunner TRD
    Optima or Odyssey...
    QMEDJoe likes this.
  6. Feb 23, 2018 at 3:29 PM
    GR8APE
    Some batteries not many these days have caps on the top that are removable to be able to check the water level. I usually added distilled water to keep the level acceptable. Most batteries these days have sealed tops. I also routinely remove and clean the terminals to keep away any corrosion. About twice a year , especially if the vehicle has not been used much I will have a load test done to check the battery's condition.
  7. Feb 23, 2018 at 3:33 PM
    SimplexFish
    Mahaff
    Houston, Texas
    ^^^ I havent seen a battery like that in years!
  8. Feb 23, 2018 at 3:44 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I just put this in on Monday. It says X2 but it is a NorthStar has 5 year full replacement. We will see how good it is.
    Kiloyard and Tacoma4Ewa[OP] like this.
  9. Feb 23, 2018 at 3:46 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    I have good experience with Optima battery.
    mcharfauros and Tacoma4Ewa[OP] like this.
  10. Feb 23, 2018 at 4:05 PM
    GR8APE
    You're right, you won't see many these days however that's the type of battery that is in my 2010 Highlander and it's the original oem that it came with new. Doesn't help the OP much though, I just hope he can find one that's been as good.
  11. Feb 23, 2018 at 4:11 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    I have heard that Optima’s quality has been hit or miss the past few years due to a change in ownership. Most people nowadays are recommending Northstar as the agm go-to. That being said, my optima red top from 2010 (before the change in ownership) is going strong after 8 years in the northwest.
    GR8APE and Tacoma4Ewa[OP] like this.
  12. Feb 23, 2018 at 4:17 PM
    SimplexFish
    Mahaff
    Houston, Texas
  13. Feb 23, 2018 at 4:28 PM
    Tiedie
    David
    WFOY
  14. Feb 23, 2018 at 7:02 PM
    evanimpreza
    evanimpreza Well-Known Member
    Evan
    Joplin, MO
    White 2012 TRD Offroad DCSB
    Icon Stage 6, SCS Ray 10s, 33s, Rigid Lighting
    Optima or Interstate.
  15. Feb 24, 2018 at 1:27 PM
    Glamisman
    Glamisman Well-Known Member
  16. Feb 24, 2018 at 2:36 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I like Toyota Tru-start batteries. And most of the time to have it installed is gonna be cheaper than most auto part store brands. Prices of batteries have seemed to skyrocket since the mid 2000's.
    oldtimertoyota likes this.
  17. Feb 24, 2018 at 3:57 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I've had good luck with Interstate so I stick with them. Like motor oil, there's no such thing as a "best" battery in this day and age. They're all pretty damn good.
  18. Feb 24, 2018 at 4:01 PM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    I have been buying INTERSTATE batteries for years, best I ever had and long lasting! Well, my 03 Taco died, went to Interstate and they said my bat was 10 years old, so I said give me another and the manager said the new ones won't last that long, no matter what brand I buy due to hazmat recycling, all batteries are made from recycled parts and luckey if it lasted 5 years! New plastic housing, recycled Inners, depressing...
    QMEDJoe likes this.
  19. Feb 24, 2018 at 4:14 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I've had an Optima yellowtop for about 2 years now and so far so good. I'm going to buy the Optima battery charger and also going to be adding another battery for offroad lighting/winching in the not too distant future.
  20. Feb 24, 2018 at 4:23 PM
    3_TACOS_NEVER_ENOUGH
    3_TACOS_NEVER_ENOUGH Well-Known Member
    Various Locations: TX, CA, NC, AL, MS, and FL
    I am a OPTIMA RED TOP guy, in my 2nd Gen I had one for 10 years (REALLY), 10 years
    I have one in my 1st Gen as well.
    When my 3rd gen needs a new battery its getting another red top
