Best carbon fiber hood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badger, Aug 15, 2015.
  1. Aug 15, 2015 at 10:35 AM
    badger
    badger [OP] Well-Known Member
    07 SR5
    I would like to hear from any of you that have experience with carbon fiber hoods and companies. I'm looking to pick the best hood and supplier. I would also like to know about how the hoods behave at speed and any info you might have about weight savings. Thanks guys!
  2. Aug 15, 2015 at 10:44 AM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    I have one on my S4, sebon is the company I think, it fit perfect and behaved like a normal hood. The clear coat breaks down over time if you don't add UV protection or paint over it. It saved about 25 or so pounds over the old hood.
  3. Aug 16, 2015 at 6:19 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just curious - my hood is dented from acorns to the point it looks like a red golf ball - any opinion as to whether acorns would dent the carbon fiber hood ?? Thanks for any reply. Curious George
  4. Aug 16, 2015 at 7:30 AM
    badger
    07 SR5
    No. It won't ever dent. It takes a lot to damage it, but carbon fiber does have one weakness. A serious chip, like from a rock could cause the CF to delaminate under stress. It's much more fragile than fiberglass in that regard. Actually, one of the best laminates out there is still hand laid fiberglass, but for whatever reason you hardly ever see it. CF is much sexier :). The fiberglass that gets sprayed from a chopper gun is heavy and weak for it's weight.
  5. Aug 16, 2015 at 7:33 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I love the look of a carbon fiber hood. Not especially on our trucks but they have their place. My main concern with a carbon fiber hood is there are no crumple zones built into them (as far as I know) like the factory hood. During a accident I'm not sure how they would react.
  6. Aug 16, 2015 at 7:41 AM
    badger
    07 SR5
    I doubt there is any danger since the hood is so light. Not likely it would penetrate the windshield. If the hood were flexed to the breaking point it would most likely exploded into a million pieces. Just look at the body panels on Nascar wrecks for a clue.
    thewarriordinghy likes this.
  7. Aug 16, 2015 at 7:51 AM
    RearViewMirror
    Craig Christ
    Good point. But I think you mean F1 / Indy cars. Nascar still uses aluminum IIRC?
  8. Aug 16, 2015 at 9:49 AM
    badger
    07 SR5
    That is a great idea DD ! A short deflector made of polycarbonate would do the trick!
  9. Aug 16, 2015 at 9:56 AM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    NASCAR is using composite bodies these days. Here is a pic of Denny Hamlin's hood during practice at Indy a few weeks ago. Crew forgot the hood pins & you see what happened.
  10. Aug 16, 2015 at 10:22 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How do they hammer out the dents in the fenders ? or is that a thing of the past ?
  11. Aug 16, 2015 at 11:05 AM
    RearViewMirror
    Craig Christ
    Most of the rest of the car is still aluminum though correct? I'll admit NASCAR is not my thing.
  12. Aug 16, 2015 at 11:05 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    unclip busted panel ---- clip in new panel
    Wish I could do that on my Tacoma...busted ass work truck.
  13. Aug 16, 2015 at 11:11 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I think he was asking about NASCAR since he pointed to a photo of NASCAR.
  14. Aug 16, 2015 at 11:15 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And how much do we think this would cost? I could get a skewp!
    ChadsPride likes this.
  15. Aug 16, 2015 at 11:18 AM
    RearViewMirror
    Craig Christ
    If you could figure out a way to induct it into your supercharger that would be sweet!
  16. Aug 16, 2015 at 11:22 AM
    ThomasMore66
    I know, right?!
    Didn't even know a CF hood could be an option. $100k Tacoma before you know it.
    RearViewMirror likes this.
  17. Aug 16, 2015 at 11:29 AM
    RearViewMirror
    Craig Christ
    LOL... tell me about it.
  18. Aug 16, 2015 at 4:09 PM
    george3
    New Jersey
    Thanks for the reply.
  19. Aug 16, 2015 at 4:11 PM
    george3
    New Jersey
    Thanks for the reply and information.
  20. Aug 16, 2015 at 4:36 PM
    ThomasMore66
    Did we ever get an answer to best place?
