Best CB Antenna Configuration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPORT, May 16, 2011.
  1. May 16, 2011 at 12:20 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Mine is mounted right here NMO style. No SWR issues, and no alternator noise issues either. The wire is dual shielded and goes straight into behind the firewall.
  2. May 16, 2011 at 3:52 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    In general:
    The bigger the antenna, the better.
    The higher the antenna, the better.
    For a ground plane antenna, the center of the vehicle is the best place for uniform coverage in all directions. For a pickup truck, that's the roof of the cab.
    If you don't mount in the center, you will have the best coverage in the direction where you have the most ground plane metal. For example, if you mount on the rear bumper, your coverage will be better towards the front of the truck than the rear.
  3. May 16, 2011 at 4:10 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I have the exact same setup and it works great. I wasted a lot of money on firesticks and other fiberglass antennas of this type including wilson, k40 ect.. Nothing gives you the range and clarity of a roof mounted ground plate steel whip antenna.
  4. May 16, 2011 at 4:35 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Similar to this one but I want it to fill in the corner and not be as far out into the bed. Also I want it to be able to mount in the channel of the bed rail, using the bolts that hold the rail to the bed.
  5. May 16, 2011 at 4:43 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have a uniden cb and a lil wil mag mount and it works pretty good and cheap too
  6. May 16, 2011 at 4:50 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    rightchannelradios.com
  7. May 16, 2011 at 5:22 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
  8. May 16, 2011 at 8:49 PM
    ninja90177
    ninja90177 Well-Known Member
    Kenney
    Las Vegas
    '09 AC 4x4 Off-Road
    Icon 2.5 C/Os, Wheeler's AAL, OME N182, 265/75-16 KM2s, Murdered Emblems
    Agree with MrGrimm. Had one on my last truck.
    I went with the K40 on this truck. No pics, but it's a huge SOB, and can/will hit stuff. Also kind pricey, but it's a great antenna.
    SWR on that mounted on the driver's-side front area of the bed off of the rails netted 1.2 SWR. Un-modded Cobra 29. If I did it again, i'd get the Wilson 1000 and put it on the roof, but I may be selling soon, so not in a rush to drill through anything I can't repair.
  9. May 17, 2011 at 3:30 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    my swr readings are ch1-0, ch19-1,ch40-0 Uniden with lil wil
  10. May 17, 2011 at 10:58 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    That's some awesome install Dean-what other rigs are you running in there:)
  11. May 17, 2011 at 11:49 AM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Larsen NMO 2/70 going to a Yaesu 8800R. I will get some pics up of the interior setup once it is complete. CB for close range vehicle to vehicle comms. HAM for long range comms.
  12. May 17, 2011 at 12:35 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Very nice! I haven't gone for a ticket yet (still on the fence) but I do run two Icom HF comm rx's as a hobby-an r71a and an r75 off a 100' longwire on the roof here. So I am into that much of the HF scene anyway-plus I run a scanner in the truck off a glassmounted tribander.
    You have a very respectable mobile IMO just sayin:)
  13. May 17, 2011 at 5:07 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    Nice. I want to get into HF in a few years. For now VHF/UHF/CB works for my needs. I did ALOT of research when I decided on a radio. Snagged it for $225 used that was a plus.
  14. May 18, 2011 at 2:50 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I have tried 2 different setups.
    - A 4 foot firestick mounted on the bed rail with a grounded mount.
    - A Lil Wilson magnet mounted antenna in the center of the roof.
    The Wilson in the center of the roof gave me much better transmission distance and reception quality.
  15. May 18, 2011 at 6:39 AM
    #35
    ratfink504
    ratfink504 Well-Known Member
    Paul
    New Orleans
    RIP 06 Tacoma Two Tone TRD Sport 4x4
    x2
    On the front of my truck is a 2m firestick, on the hood is a 2m/440, on the back is a 9' fiberglass whip for my ft-100d. I'm going to add another hi gain 2m/440 on the other side if the 9' whip when I get back home. I would have mounted them on top of the truck but I'm going to get a roof rack and also I have to park in a parking garage
  16. May 18, 2011 at 9:29 AM
    #36
    Ridgerunner
    Frank
    Rocklin, Ca.
    Cool:) that 2m/60cm mobile of yours-how many miles out can you hit a repeater with it? I always wondered about the real range on them-like how many miles can you talk "simplex". I have heard some guys can activate a repeater with 3 watts from 25 miles-but that was from mountaintop to mountaintop. Sorry about the threadjack.
  17. May 18, 2011 at 9:50 AM
    #37
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I have had alot of good luck with roof mount Wilson (Lil Wil). they are tunable, and swing pretty good for a none boosted setup. I would also reccomend the Cobra 75 just to save space. I still have my Black Faced Johnson lying in wait of a huge truck to put it in. It's a relic and way too big for a Tacoma. Good Luck.
  18. May 18, 2011 at 10:12 AM
    #38
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    Best ground is had with flat copper strap. If you must use wire even No 6 keep it as short as possible. Round wire tend to radiate RFI. Remember RF rides on the outside of the wire called skin effect.
    One asked about an antenna that did not require a ground plane, that would be a half-wave. At 11 meters it would get pretty long, double the 8 foot whip for full size. I am sure there are some coil loaded ones around.
  19. May 19, 2011 at 3:17 PM
    #39
    ratfink504
    Paul
    New Orleans
    Where I live the highest mountain is monkey hill at the zoo and that's 14' above sea level lol. With a 3-5 watt ht I can get into a repeater about 40 miles away. Right now I'm up in Arkansas and with a 50 watt mobile I can get into the local repeater about 15 miles with me driving on a hill. With simplex it depends. In New Orleans you can easily talk from mobile to mobile about 20-40 miles using simplex if there is nothing in between ya'll but if the city is between you and them it really gets hard because of the buildings. My call is W2XXX 73's
  20. May 19, 2011 at 3:48 PM
    #40
    Ridgerunner
    Frank
    Rocklin, Ca.
    Nice! That is some good simplex range-very crucial in emergencies! I gotta get a ticket. My r75 can go mobile if I need access to HF comm nets in an emergency but it would be way helpful if I could actually communicate with others when the shit comes down. I honestly believe there are no HF hams in my area and a handful of 2m-and UHF none. Not a good scenario.
