Best center support bearing for 2002 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Amandavei82, Oct 13, 2020.
  1. Oct 13, 2020 at 6:19 PM
    Amandavei82
    Amandavei82 [OP] Member
    Amanda
    2002 Toyota Tacoma TRD
    None - but hoping!
    Hello, I was noticing a noise from my drive shaft and an inspection of the undercarriage showed a slight hang in my center support bearing for 2002 Tacoma. I am able to lift and move the drive shaft. was wondering if anyone had some suggestions on a good quality replacement part and if it's safe to drive at the moment?
    Thank you.
  2. Oct 13, 2020 at 6:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Oct 13, 2020 at 6:24 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I got a Timken on Amazon which is also good. I think you have to go on their website to get the part #
    Amandavei82[OP] likes this.
  4. Oct 13, 2020 at 6:28 PM
    Amandavei82
    Amanda
    None - but hoping!
    Thank you guys. I will look into them. I believe the spicer will not fit my vehicle. I am a 2wd Amazon said it wouldn't fit my vehicle. I'll Google the brand.
    Thanks again for the quick replies!
  5. Oct 13, 2020 at 6:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    2wd prerunners (your truck) and 4wd use the same carrier bearing.
  6. Oct 13, 2020 at 6:35 PM
    eon_blue
    Azusa, CA
    Don't go off what Amazon says fits/doesn't fit, they're known to be inaccurate
  7. Oct 13, 2020 at 6:41 PM
    Amandavei82
    Amanda
    None - but hoping!
    Ah okay good to know. When I put in my truck specs on Amazon it stated that one did not fit. I am looking now. How about the safety of the vehicle? Seems like it might just be the rubber gasket (hope that's the terminology).
  8. Oct 13, 2020 at 6:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  9. Oct 13, 2020 at 6:42 PM
    Amandavei82
    Amanda
    None - but hoping!
    @eon_blue thanks another good fact to know.
    @Dalandser Oh thanks I will be doing it myself. That was going to be my next task.
  10. Oct 13, 2020 at 6:42 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah it’ll work until it doesn’t work but you’ll get vibes before it blows out
  11. Oct 13, 2020 at 6:47 PM
    Amandavei82
    Amanda
    None - but hoping!
    Okay. Good to know. Thank you.
  12. Oct 13, 2020 at 6:48 PM
    goldentaco03
    Liam
    NJ
    Mine was making really bad squealing noises and that’s when I replaced it. There’s supposed to be some play in the rubber bushing. IIRC it’s like 1/2” up or down. The carrier bearing is basically a traditional roller or ball bearing set into a piece of rubber if that helps you visualize it.
    toyoBen and Dalandser like this.
  13. Oct 13, 2020 at 6:50 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What’s the noise? Did you check the ujoints also?
  14. Oct 13, 2020 at 6:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He didn’t say anything about a noise in the OP - said there was play in the CB
  15. Oct 13, 2020 at 6:53 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If that's the original, it's time no matter mileage to change it.
    That's a lot of old rubber. Nearly 20 yrs.
    Dalandser likes this.
  16. Oct 13, 2020 at 6:55 PM
    Amandavei82
    Amanda
    None - but hoping!
    @goldentaco03 it's pretty much resting. I tried to add a video but I can't save it in any format then a mp4. And it won't accept that. I only have a clanking when I move out of park. Then it's fine after that.
  17. Oct 13, 2020 at 6:56 PM
    Amandavei82
    Amanda
    None - but hoping!
  18. Oct 13, 2020 at 7:04 PM
    JKO1998
    Utah
    Oh, misunderstood
    Dalandser[QUOTED] likes this.
  19. Oct 13, 2020 at 7:06 PM
    Amandavei82
    Amanda
    None - but hoping!
    @JKO1998 I only have a clanking when I move out of park. Then it's fine after that.
  20. Oct 13, 2020 at 7:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    :anonymous: Scary part is I purposefully reread it before quoting you.
