Best choices for bed stiffeners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Biggums, Aug 8, 2018.
  1. Aug 13, 2018 at 5:47 AM
    #41
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    Orco59, riz_atx and At The Helm like this.
  2. Aug 13, 2018 at 6:41 AM
    #42
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I’ve never seen a report or picture of the composite bed failing from extensive abuse offroad or heavy toppers and RTTs.
    It’s a solid theory and I’m sure works well but I haven’t seen anything that suggests they are needed.
    Tons of people offroad, have toppers, and RTTs without bed stiffeners and no reports or pics of failure.
    BRFab, hotrodder636, honda50r and 4 others like this.
  3. Aug 13, 2018 at 6:44 AM
    #43
    Rocinante75
    Rocinante75 Well-Known Member
    2018 TRD Pro Cavalry Blue
    RokBlokz Mud Flaps, TufSkinz tailgate lettering, OV Tuned (1.05!!!)
    I just like the idea of the extra tie downs some of the stiffeners offer. The "stiffening" aspect would be a bonus.
    trazerr likes this.
  4. Aug 13, 2018 at 7:00 AM
    #44
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    No offence, but that ^^ isn’t my experience at all. The composite bed has proven to be exceptionally durable, which is why you never see posts here about people damaging their composite bed, or having issues with it being under-engineered. In my experience, the composite bed is far stiffer than a metal bed, and way more durable. Not sure what you are getting at. Maybe explain further. Thanks.
    CREM_808, hrivera007 and shakerhood like this.
  5. Aug 13, 2018 at 7:47 AM
    #45
    JoeCOVA
    Joe
    Colorado Springs
    Create a need/gap in the market, provide product that fills that need/gap. Make lots of money.
    grogorat and Stocklocker[QUOTED] like this.
  6. Aug 13, 2018 at 8:34 AM
    #46
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    When you load the bed rails with a RTT or Bed Rack you are creating a great load on the factory bed. This will increase gaps at the tailgate and eventually crack the sheet metal or composite bed. Throw in off-road use you'll be looking at problems down the road. It could be 2 months of crazy abuse or 2 years before issues arise.
    We did build these out of NECESSITY. We had a 2nd Gen Tacoma where the bed got rattled to pieces and damaged the taillights, bedsides, and tailgate. It pretty much fell apart on itself. This was after LOTS OF ABUSE, but was the original inspiration for the bed stiffener. Years later here we are!
    Think of it like preventative maintenance :)
    $159.65 + 30 minutes of your time will save you lots of hassle down the road (especially if you plan on using the truck off-road)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  7. Aug 13, 2018 at 8:51 AM
    #47
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    Yeah.
    I've had a small RTT on a mid-height rack on my 2nd gen and now on my 3rd gen. Never noticed a problem with the bed, but the rack and RTT are only about 150 pounds. With me and the dog in the tent, that goes up to close to 400 pounds, but that is a static load. I never really worried about it. On my new rig, I've added mounts for a HiLift, axe, shovel, and a 5 gallon fuel can. That adds another 100 pounds or so of dynamic load. So, I started to worry.
    I went with the Total Chaos stiffeners. A bit more expensive than some of the others, but they come up a bit further on the sides than some others, they have an antenna mount and extra tie down locations, and they work with the OEM bed mat (which I wouldn't have minded cutting, just didn't have to). Easy to install, and I've already used the tie downs. I even combined the install with the diff breather relocation behind the left tail light. I would probably be fine without them, but peace of mind is a good thing.
    02Duck likes this.
  8. Aug 13, 2018 at 12:04 PM
    #48
    Sungod
    Sungod Well-Known Member
    St Augustine
    I am not seeing how the bed would flex with the tail gate up. I could see needing these if you ran without a tailgate or an old school net. Seems to me that a better design would be to fit inside the bed by removing the tail lights. Then you don't have that extra material, but I guess that would mean that you would be buying something like this for actual purpose and not look.
  9. Aug 13, 2018 at 12:32 PM
    #49
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    I saw a friend's fiberglass topper on a 2nd gen that cracked on top while off-roading. No bed stiffeners. No RTT, but he did have gear on top. Nothing crazy. He put bed stiffeners on and had to use them to bring the bed sides back into alignment.
    NuckTrutz, AKGSD and tonered like this.
  10. Aug 13, 2018 at 12:40 PM
    #50
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    The tailgate latches will allow for side-to-side flex, at least to a point. They don't really brace it. It might help a little. Think of breaking a pull-tab off of a can -- you keep bending it back and forth, and it gets easier and easier until it breaks off. That is what I imagine happens over time, although I doubt you'd ever see a complete catastrophic failure on a truck bed. Just mainly getting more and more flexible over time.
  11. Aug 13, 2018 at 2:22 PM
    #51
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    I’m sorry to hijack, but the only real good bed “stiffener” is a hot wife in lingerie next to you.:bananadance:
    BC Hunter, 50Buck, Reggie4x4 and 20 others like this.
  12. Aug 13, 2018 at 2:58 PM
    #52
    Rocinante75
    That is an appropriate hijack sir.
    50Buck, ImBAVID, itzryyster and 7 others like this.
  13. Aug 13, 2018 at 3:02 PM
    #53
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    There are plenty of pictures of 2nd gens with this problem if you look in the 2nd gen threads. Most of which are ranging from just bedrail bar use to heavy ass fiberglass topper+RTT. The pictures do exist.
    Seeing as the 3rd gen bed is no different except for taller bedsides and a re-engineered tailgate, I’m sure there is potential for the same issue for 3rd gens who have weight on the rails or heavy off-road flexing
    kalieaire and tonered like this.
  14. Aug 13, 2018 at 3:07 PM
    #54
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If I buy yours (I'm going to anyway), does it come with a sticker? :anonymous:
    50Buck and Toyojo like this.
  15. Aug 13, 2018 at 3:24 PM
    #55
    Gator352
    Leesburg, Florida
    Lol, well a few different places! Can get one from Russia (not recommended), borrow one from a friend (not recommended either), or use match.com like I did 10 years ago!
    BC Hunter and ScootARoot like this.
  16. Aug 13, 2018 at 4:39 PM
    #56
    TOTAL CHAOS
    Corona, CA
    Of course it does :thumbsup:
  17. Aug 14, 2018 at 4:04 AM
    #57
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I got a bunch of stickers, a catalog, and a poster! I'd say about $150 worth of brackets and $9.65 in marketing material, LOL :D
    Solid product, though. Poster is hanging in the garage.
  18. Aug 14, 2018 at 4:11 AM
    #58
    s.e.charles
    s.e.charles Well-Known Member
    probably a strong bracket, but those would look good if a guy made them in his shop on sunday afternoon, not for a commercial product. they do not look "finished".
    ImBAVID and hotrodder636 like this.
  19. Aug 14, 2018 at 4:20 AM
    #59
    s.e.charles
    somebody has been binge-watching Mad Men!
    polaris202 and Sand Dog like this.
  20. Aug 14, 2018 at 5:17 AM
    #60
    JoeCOVA
    Joe
    Colorado Springs
    I guess I have a reason to now
