Best Circuit(s) to tap power for LEDs
Discussion in 'Lighting' started by 11TRDTX, Mar 1, 2013.
  1. Mar 1, 2013 at 8:58 PM
    11TRDTX
    11TRDTX [OP] Tennessee's whitest Puerto Rican
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    5100's with eibach 2.5 coils, 285/75R16 BFG KO's, OME N182 nitro chargers, wheeler's HD progressive AAL, 3/8" poly top plate spacers, 1/4" poly top plate spacer on driver's side, Toytec 3* axle shims, cab mount chop, swaybar delete, custom prerunner bar, micro-suede arm rests, plasti-dipped rear bumper, red toyota emblem, painted (red/black) engine cover, red dash rings, red/black painted dash trim, red/black shifter trim, Blue Sea Aux fuse box & 100A breaker, ultragauge MX1.3, 2 Tuff LED 51W spots, 2 Rigid Industries Dually amber floods (retrofitted into stock fog lights location), Cobra 19 cb, 4' firestik II with spring, Rugged Ridge receiver hitch shackle, smittybilt 3"x30' recovery strap, Demello Offroad bed cleat bar, derp'd badges, 6 OTRATTW switches, 2 Avec LED pods (rear facing), dual car seat mod.
    Whats up all...
    I'm planning on running a few pairs of duallys/dually d2s/rigid LEDs (going to have to add pairs over time), and been looking into aux fuse blocks. I'm wondering which circuits, that only have power with key on, are ideal to tap power from to run to a fuse block without drawing excessive amps from any one particular circuit. Been trying to find wiring diagrams to help, but haven't had much luck.
    I already have a pair of procomp 130's (with a relay) that a friend helped me wire in. forgot what they're tap into, but its a 25A circuit. would like to keep future lights away from them since they are pulling so many amps to begin with.
    any input is much appreciated.
  2. Mar 2, 2013 at 1:34 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    I would not want to run an entire AUX fuse block using an oem circuit as the main source, it kinda defeats the purpose of the block if it's piggybacking and adding amp draw to an existing circuit. I would have the fuse block hard-wired to the battery, and run the switch/relay coil to an OEM circuit so the lights turn off when the key is off.
  3. Mar 2, 2013 at 4:08 PM
    11TRDTX
    Memphis, TN
    Cool! thanks man:thumbsup:
