Best clutch kit?
Discussion in 'New Members' started by Dieseltoynzcan, Oct 6, 2020.
  1. Oct 6, 2020 at 7:37 AM
    Dieseltoynzcan
    Dieseltoynzcan [OP] New Member
    Bruce
    872L2wd 17trdoffrdtaco
    Hello, one of my trucks is an 87 pickup rwd 2.4l diesel and it needs a new clutch... anyone know which kit is the best one for reliability and quality?
    Black DOG Lila likes this.
  2. Oct 6, 2020 at 8:21 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard Bruce
    Where are you located?
    buckhuntin-tacoma likes this.
  3. Oct 6, 2020 at 8:31 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If it's just a stock replacement I'd get an Aisin kit personally. The one for my 1991 was something like $125 for pressure plate, friction disk, throwout & pilot bearing. Good stuff, too, what Toyota would have put in at the factory.
    The only reason I'd not go that way would be if you're rock crawling it. When I went to Marlin gears I used his clutch, I only did 1,200 lbs holding even, to keep it from slipping at ridiculous low-low. For daily use though it's too much, your left leg will get tired in traffic and it'll probably wear out crankshaft thrust bearings faster, too.
    https://www.marlincrawler.com/clutch/heavy-duty
  4. Oct 6, 2020 at 9:44 AM
    Dieseltoynzcan
    Bruce
    Thanks, I’m located in Edmonton Alberts Canada
  5. Oct 6, 2020 at 9:46 AM
    Dieseltoynzcan
    Bruce
    Thanks Dave, I don’t rock crawl with the 87 it’s only 2wd .. I’ll check out the Aisin kit it should fit the bill.
    DaveInDenver likes this.
  6. Oct 6, 2020 at 1:27 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  7. Oct 6, 2020 at 1:56 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
  8. Oct 9, 2020 at 11:43 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
