best clutch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Nov 3, 2021.
  1. Mar 21, 2023 at 10:38 AM
    Red_Eye_Jedi AKA Yota13
    Red_Eye_Jedi AKA Yota13 New Member
    Gaelen
    Wht 2006 Tacoma TRD Sport
    So it sounds like the URD stage 3+ clutch , heavyweight flywheel and hydroTOB seems to be satisfying the needs of those who are running that set up. I am currently replacing my TOB in my 06 sport and the clutch is getting strung along to get a replacement since I’m in there. I had the chirp real bad but then I’m also at 296,000 miles or some such number on the original which was LUK clutch. Had the chirp probably since about 175k-200k and the thing just kept going. Must have been an Energizer TOB. I never had much problem with the OEM clutch in any terrain or driving condition but things can always be improved upon yes? Unless anyone is running the URD set up and has any qualm? That seems to be the ticket………
  2. Apr 19, 2023 at 6:48 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Reviving this thread. Any updates? Leaning towards the URD State 3 w/ flywheel myself.
  3. Aug 28, 2023 at 2:13 AM
    jjgandarillas
    jjgandarillas Well-Known Member
    joseph
    Anc, AK
    SPORT DCSB MT
    ICON 2.5 VSRR, icon 2.0 ext travel, UCA’s, Ray 10 17x8.5 -12, 285/70r17 BFG Ko2
    I love reviving old threads, this information is so important. I think the factory clutches are the worst from any clutch in any vehicle I have ever driven but I still love them.
  4. Aug 28, 2023 at 3:48 AM
    jpdeuce
    jpdeuce Well-Known Member
    James
    Houston
    2008 DCSB OR-6MT
    Lift, Bumpers, Sliders, Odds and Ends
    What is TOB and what is hydro TOB that is being referenced in this thread?
  5. Aug 28, 2023 at 3:53 AM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    SD CA
    happy with the parts so far.
    Went URD stage 2, flywheel, CM HydroTOB. Didn’t know much about tilton one at the time. Got the fitment kit just in case I ever have to make the switch.
    knock on wood it’s doing fine. Stopped squeaking. The minimal DOT4 drip it had from the bleeder stopped.
    Correct me if I’m wrong but stage 3 has pucks and stage 2 is a full face material disc.
    Full material is for a vehicle driven every day.
    Pucks are for a 700hp B5 S4 with poor driveability.
    stage 2 rating can probably handle a supercharger.
    DesertRatliff[QUOTED] likes this.
  6. Oct 19, 2023 at 9:42 AM
    KonaCoffee
    KonaCoffee Well-Known Member
    Massachusetts
    2019 SR5 Ext Cab, 4WD, Auto, 3.5, 80k
    Throw Out Bearing
  7. Jan 8, 2025 at 6:31 PM
    Pigpen
    Dan
    Northwest Montana
    Thoughts on Uni Clutch? Available in US through NAPA. Seriously considering being a guinea pig.
    Edit: bought the clutch. Dropping the truck off for installation on 2/10.
  8. Feb 11, 2025 at 5:05 PM
    Pigpen
    Dan
    Northwest Montana
    Marc70 likes this.
