Best coilover for lightest tacomas?
Discussion in 'Suspension' started by PreRunner, Feb 8, 2010.
  1. Feb 8, 2010 at 8:55 PM
    PreRunner
    PreRunner [OP] Well-Known Member
    Im trying to research which coilover to buy for my 2010 prerunner. I see stiffness as being a complaint at times. I was thinking, i have the regular cab 4 cyl so im the lightest. maybe many of the coilovers are for heavier trucks and have stiffer springs. which coilovers should i be looking at? thanks.
  2. Feb 9, 2010 at 5:59 AM
    PreRunner
    any ideas? my order submission finger is getting itchy :)
  3. Feb 9, 2010 at 8:55 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    go Kings...
    they are user rebuildable and you can customize your shock oil, valving, and coil spring rate...
  4. Feb 9, 2010 at 9:31 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    And really, the stiffness aspect really comes into play with how YOU like your truck to ride. Of course if you have a coilover maxed ouut it's gonna ride a bit stiff, but if you go up halfway, it will be half as stiff and so on, you know?
    That being said, i absolutely LOVE my ICON CO's! I would recommend them to anyone wanting to lift their truck.
    I vote ICON all the way!
  5. Feb 9, 2010 at 10:37 AM
    PreRunner
    thanks guys. sounds like both kings and icons are a safe bet. but do you think, since i have a light reg cab 4 cyl, i would benifit from using a 2.0 vs a 2.5 shock? anyone know about this? im just trying to match this suspension the best i can, since it's going to cost an assload of money. :eek:
  6. Feb 9, 2010 at 11:31 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    2.5 won't heat up as much, so your shock will last a bit longer... most of the coilovers are 2.5 although Fox I think makes a 2.0...
  7. Feb 9, 2010 at 2:25 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Icons are super stiff. That's why I took mine off.
  8. Feb 9, 2010 at 2:44 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    I've got a 500# spring rate coil designed perfectly for the 4cyl regular cab!!! This coil over gives you the freedom of lifting 0-3.5 inch's.
    comes with a Life Time Warranty also!!
    Plus, a forum discount!
  9. Feb 9, 2010 at 2:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would say this ^^^^^
  10. Feb 9, 2010 at 4:00 PM
    PreRunner
    Thanks alot guys. I decided to go with the icons. Wheelers said they could special order extended icons valved for my specific truck (4cyl-reg cab). I got those, camburg UCA's, the 3-leaf AAL, and bilstien 5100's. :D
