Best Cold Air Intake for a 2012 4.0L engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harlesmon, Jun 12, 2012.
  1. Jun 13, 2012 at 10:37 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    40-45 degrees?? Towing?? Semi's??? :laughing:
  2. Jun 13, 2012 at 10:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yeah, you think he's embelishing a bit? :rolleyes:
    So he's probably only holding 3k RPM but that got exaggerated to 4,500 RPM.
  3. Jun 13, 2012 at 10:43 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    What's the reason you want a new CAI? Show, go, dough?
  4. Jun 13, 2012 at 10:45 AM
    The Traveler
    SoCal
    Of course...that's where the "gains" are supposed to be that are a result of the mod in question. LOL
  5. Jun 13, 2012 at 11:21 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I like the sounds of this, I love the sound of the Gibson!
  6. Jun 13, 2012 at 11:41 AM
    harlesmon
    harlesmon [OP] Harlesmon
    Port Orchard, WA
    '12 TRD 4x4
    I do appreciate all of the responses to my question. For now, I am going to stick with stock and install a cleanable filter.
    And now I will start plotting my next change!
  7. Jun 13, 2012 at 3:16 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    :infantry:Assohole! :brianr:
    Get outta here with your fancy intake and exhaust :jerkoff: lol
  8. Jun 14, 2012 at 5:33 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    AFE!!!!!!
  9. Jun 14, 2012 at 5:59 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have ebay intake (K&N knockout) which I bought for $70 shipped. If you want intake just for cool sound like I wanted, ebay intake is the way to go...
  10. Jun 14, 2012 at 8:56 PM
    blackpearl11
    blackpearl11 Well-Known Member
    2010 tacoma
    Sounds smart, I was going to get a cold air to at one point, but after reading threads it seemed like a waste of 2-300 dollars, plus the trd intake I believe has an issue of running lean which is definitely not good for an engine
  11. Jun 14, 2012 at 9:00 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    I would say URD just because its a toyota product.
  12. Jun 14, 2012 at 9:01 PM
    BlueTaco07
    Cody
    Looking
    TRD* thanks didnt see that.
  13. Jun 25, 2013 at 4:44 PM
    liguy
    liguy Active Member
    Massapequa, NY
    B2600i
    Working on installing VOLANT CAI in my 2013 Tacoma...
    THE AIR PUMP MOUNTING HOLES IN THE VOLANT AIRBOX ARE MISALIGNED.
    After moving the rubber mounting plugs from the Tacoma bracket into the VOLANT airbox, the next step is re-inserting the pump onto the airbox.
    NO GOOD!!! The outer mounting hole for the rubber plug is misaligned... causing the plug to pop out of the airbox once the air pump is fitted.
    Even the company video shows the misalignment... see still-shot attached.
    I called VOLANT tech support in hopes of passing along some friendly feedback... got someone who could care less.
    CAVEAT EMPTOR!!
  14. Jun 25, 2013 at 5:00 PM
    SierraExp
    SierraExp Its the Journey, not the Destination Vendor
    Sierra Expeditions
    Mesa, Arizona
    I can attest that unfortunately URDs claim that the intake is not affected by rain is incorrect. While I had the tCAI installed on my 2008 Tacoma I was twice caught in the rare but non the less very intense Arizona Monsoon and on both occasions the truck actually hydrolocked itself while traveling into the face of the storm down the freeway. Of course it turned over almost immediately after but the second time this happened it died 3-4 times within a matter of a few minutes forcing me onto surface streets. Both instances the filter was absolutely drenched even with the "hydroshield" prefilter sock. I should also note that I am running a Grillcraft Grill and would have added the shield had it ever shipped with my order...
    Needless to say I pulled the intake the same day and went back to stock and have had zero issues to date on the stock intake and paper filters. That being said, having run TRD, Airaid, Volant and URD intakes on my truck of the 4 I listed I was the most pleased by the performance results of the URD. Truck most definitely seemed to breathe better and was a little peppier on the butt-dyno than the other intakes I tried however none of them are worth the investment over stock and if you intend to wheel your truck whatsoever the URD is not the best option. For a street or boosted truck of course they are the frontrunner.
    my $.02
  15. Jan 10, 2014 at 7:51 AM
    #35
    IanN
    IanN Well-Known Member
    Ian
    Medford, OR
    2013 DCLB TRD Sport
    TRD exhaust
    This.
    Hahaha so true. Sometimes I miss CA.
  16. May 27, 2014 at 1:03 AM
    #36
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
  17. Aug 28, 2014 at 4:15 AM
    #37
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
    Hello, Just wondering if you still have the Volant CAI in your truck. If you do, and since some time has passed since your original post, do you still love it? Pros? Cons? I it worth the $$$? Or is stock the way to go? Also did you feel the need for a URD MAF Sensor Calibrator? Thanks, Gil
  18. Aug 28, 2014 at 5:42 AM
    #38
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Stock unless you have a S/C
  19. Sep 11, 2015 at 10:54 AM
    #39
    Voodoo Actual
    Voodoo Actual Well-Known Member
    2015 TRD Pro
    Gotta love people on the interwebs telling you how you should use your truck.
  20. Sep 11, 2015 at 10:55 AM
    #40
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    F it, just take the filter out of the stock box.. no restriction = 100hp.
    R242, addicus24 and Ninj like this.
