Best cold air intakes for 2017 Toyota Tacoma 3.5 ??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lennarguywithtruck, Oct 19, 2019.
  1. Oct 19, 2019 at 12:56 PM
    lennarguywithtruck
    lennarguywithtruck [OP] Member
    2017 Toyota Tacoma
    None
    Can anyone help looking for 2017 cold air intake for a Toyota Tacoma 3.5 that could help improve my gas Mileage and advise ?
    Junkhead likes this.
  2. Oct 19, 2019 at 12:58 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    None you already have one.
    END THREAD/
  3. Oct 19, 2019 at 12:59 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You'll get more performance gains from the sticker that comes with it than the intake itself.
  4. Oct 19, 2019 at 2:16 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Keep it stock.
    Wilking, Hoff, GillyLink and 7 others like this.
  5. Oct 19, 2019 at 2:19 PM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Just picked up my ‘18 dclb sport today. Will be getting the TRD intake this next week. Have one on my 2nd gen and absolutely love it. Paired with the TRD exhaust, the combo sounds perfect. I noticed a difference in throttle response. No difference in fuel economy. Enjoy!
    AMC_Unlimited, JCVD and VaToy like this.
  6. Oct 19, 2019 at 2:26 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    A Cold Air Intake is better suited for performance enhancement (the opposite of fuel economy). And, just doing a Cold Air alone will give you negligible increases in performance. To take full advantage of a Cold Air System, you would need to do a complete Stage 1 performance upgrade. IE: Cold Air Intake - Engine Tune / Modifications - Exhaust Modifications. And your fuel economy will go \/ \/ \/.
    Just my $0.02
  7. Oct 19, 2019 at 2:29 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    OP...Right-foot throttle control directly affects your MPG sir. And stock intake already is pulling cooler ambiant air from outside of engine bay through the passenger wheelwell...
    Huang618, Malvolio and Chew like this.
  8. Oct 19, 2019 at 2:37 PM
    PhenixFord
    Randy
    Arkansas
    So really all he would need is a K&N. But really, I don't think the OE system is exactly the same as a true CA intake system. Maybe if you could redesign the airbox and find a smooth plenum? But then, It would probably be easier to just go buy one. :)
    wolf2600 likes this.
  9. Oct 19, 2019 at 3:07 PM
    Mr.Hustler
    It's a secret
    If taking intake designs from cars or other tuners, the intake pipe ahead of the airfilter/box would drop near the bottom of the engine or directly front-facing in the airdam/grill...also to add what you already stated to inform OP, more air will naturally require more fuel to burn for the gains in HP but less MPG...but really, there wont be an increase in HP to make a difference...maybe just enough to run the AC compressor without it leeching power from the motor--negating the draw.
  10. Oct 19, 2019 at 5:32 PM
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    If you run a K&N put a off road sock on it. They suck dirt and really don’t add HP. Look it up.
  11. Oct 19, 2019 at 5:36 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You get nothing from it on this truck, someone on here ran the truck on the dyno and it made no difference between having a filter and no filter at all.
    GillyLink and GreyBaldTaco like this.
  12. Oct 19, 2019 at 5:40 PM
    PhenixFord
    Randy
    Arkansas
    Agree. That pretty much what I said in post #6.
    GillyLink and shakerhood[QUOTED] like this.
  13. Oct 19, 2019 at 5:53 PM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
  14. Oct 19, 2019 at 6:02 PM
    PhenixFord
    Randy
    Arkansas
    That is why a good quality CA Intake will try to get it's air from outside the engine bay (front grill or hood). But cooling the air is only part of the job of a CA Intake system. The other part is streamlining the airflow. That is why the plenums are smooth instead of accordion style. And the filter in the air-box is placed in a fashion to allow a direct entry / exit of airflow. And that is why a CA Intake System is completely different than the OE system.
    specter208, 44-16 Taco and Mr.Hustler like this.
  15. Oct 19, 2019 at 6:53 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Cold air intakes don’t cool the air. The air outside the car is cooler then the hot air around the engine.
  16. Oct 19, 2019 at 6:59 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Oh my. And on Saturday. Be nice you savages.
    Welcome to TW!
    Spend your money elsewhere and spend some time reading. Wear a life-jacket.
    TW is a great place but there's sharks in the water.
    Malvolio and Mr.Hustler like this.
  17. Oct 19, 2019 at 7:00 PM
    PhenixFord
    Randy
    Arkansas
    Err - ya. That's why a good system will get the supply from "in front of the grill / hood scoup / or somewhere outside "the engine compartment". "The best that they can achieve is "ambient". And like the video above proves, the temperature probably makes very little difference. The streamlining of the airflow (and providing more air) probably makes the most difference.
  18. Oct 19, 2019 at 7:02 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2 ^
    I can't believe people are still running K&N's. When you can read a newspaper through your air filter, maybe, just maybe, your engine is eating a little more dirt than desirable..
    But as mentioned, if you can't fucking help yourself, buy the "sock." I believe they were branded as "Outerwears" by K&N when I was still chasing the dream.
  19. Oct 19, 2019 at 7:07 PM
    PhenixFord
    Randy
    Arkansas
    I think that's what we're trying to tell the OP. That, and the fact that a CIA "isn't" intended for fuel economy.
    Mr.Hustler likes this.
  20. Oct 19, 2019 at 7:10 PM
    PhenixFord
    Randy
    Arkansas
    Sorry, I'm bored and at work. Just trying to educate the OP. Maybe he can learn something about CIA's ??? :)
