Best Dash Cam?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Moroney0500, Apr 28, 2022.
  1. Aug 28, 2023 at 3:18 PM
    #41
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Been testing the fitcamx 4k for a month with 128 GB card and rear camera. 5 minute install, no problems, and using latest ios app I actually like the software.
    Rear camera uses cheap standard off the shelf extension cables if needed.
  2. Aug 28, 2023 at 3:34 PM
    #42
    Buck Naked
    Buck Naked Active Member
    WA
    2023 TRD OR DCSB Manual Trans
    Burrrr[QUOTED] and tacoma_ca like this.
  3. Aug 29, 2023 at 8:51 AM
    #43
    Burrrr
    Burrrr Well-Known Member
    KY
    2017 DCSB TRD Sport
    All modifications below: FUNCTIONAL: LINE-X Undercoating Alu-Cab Contour Canopy ICON Stage 3 Suspension Kit (Tubular UCA) Prinsu Cab Rack Prinsu Top Rack (Mounted to Contour Canopy) Prinsu Rack 44" Side Rail WeatherTech DigitalFit Floor Liners (Front and Rear) Victory 4x4 Armrest Interior Molle Panel (VTCCIMP-3G-PC) Cali Raised Bed Molle System (Rear Panels; Both Sides) Vantrue N4 Pro 3-Channel Dash Camera (Hardwired) WHEELS/TIRES: SCS BR6 17x9" -38mm Nitto Ridge Grappler LT285/70R17 C 116/113Q LIGHTING: Diode Dynamics SS3 Max (Yellow SAE) Fog Lights Diode Dynamics Stage Series 30" Stealth Light Bar Kit (White; Driving Optic) Diode Dynamics SL2 Pro High Beam LED Lights Diode Dynamics 921 XPR LED Reverse Lights Diode Dynamics HP5 LED Map Light (x2) Diode Dynamics SMF2 LED Vanity Light (x4) Baja Designs LED Dome Light RovrLab Baja Designs Flush LED Dome Light Conversion AUDIO: Receiver/DSP: Sony XAV-9500ES Speakers (Powered by JL Audio JD400/4): Kicker Tweeters (Subaru Part # H631SFJ101) Kicker 46CSC6934 (Front Doors) Kicker 46CSC674 (Rear Doors) Subwoofer (Powered by JL Audio J2 500.1): JL Audio SB-T-TACDCG3/10TW3 (Stealthbox)
    True, but the license plate clarity of this one was far superior to the other ones tested. I'd say that's worth it for a little extra cost up-front.
    You can apply a $70 coupon before adding it to your cart and then use "HookUpN4p" for an extra $20 off. I ended up getting the cam and the CPL filter for $320 USD + tax.
    tacoma_ca likes this.
  4. Aug 29, 2023 at 5:31 PM
    #44
    TacoTaco-BurittoTaco
    TacoTaco-BurittoTaco Well-Known Member
    James
    Georgia
    2023 TRD Off-Road DCSB
    Stock
    Which filter did you get by the way?
  5. Aug 29, 2023 at 7:45 PM
    #45
    Burrrr
    KY
    2017 DCSB TRD Sport
  6. Sep 1, 2023 at 6:14 PM
    #46
    tacoma_ca
    Quick follow-up for Fitcamx 4k performance testing. I added the Garmin CPL filter and tested lic plate readability while driving directly into the sunset. The lens is apparently not centered well enough because the filter edge is visible on the left side of the frame and is fixed in place by a couple drops of Bondic adhesive. The attached image is extracted via VLC at 4k resolution as a typical example. In brief, it is not bad but is certainly not as good as the Vantrue license plate readability shown above.
    Also the camera image brightness is not adjusted after adding the filter so it is a bit dark, as expected.
    *edit: images seem to be downsampled before display by TW, originals are more clear*
  7. Sep 1, 2023 at 6:25 PM
    #47
    James
    Georgia
    Stock
    Helps me make a decision, appreciate the write up.
    Buck Naked and tacoma_ca[QUOTED] like this.
  8. Sep 3, 2023 at 10:49 AM
    #48
    Xbowguy
    Xbowguy Well-Known Member
    Jeff
    Pa
    2023 Tacoma 4x4 SR5 double Cab Barcelona Red
    What does this filter actually do ? My resolution looks good think.
  9. Sep 3, 2023 at 10:53 AM
    #49
    BlueRibbonRM
    BlueRibbonRM Well-Known Member
    2023 TRD OR
    Just installed my front 4k and rear setup, ordered from Amazon the rear is the full 360 updated version. Install was simple although I agree with the 2 common complaints which are tucking the wires up when putting the front camera in place and having way too much wire to the rear. So far very satisfied overall, will see how well it lasts in the long run.
    bigsmirt likes this.
  10. Sep 3, 2023 at 4:17 PM
    #50
    tacoma_ca
    In a couple sentences, circular polarized light does not have the variation in magnitude of the E and B fields of 'typical' light we are used to thinking about but instead the two fields rotate with constant phase in time. It's an orthogonal solution to the wave equation vs. linear polarized light which is what occurs upon reflection. CPL filters thus filter out nearly all sharp reflections, giving more contrast and less obfuscation based on reflections that mask detail.
    Xbowguy[QUOTED] likes this.
