Best deep cycle battery?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jermzfree, Jun 17, 2019.
  1. Jun 18, 2019 at 9:27 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is unnecessary if you adjust your charge voltage as mentioned in this thread below. If you do not adjust your charge voltage, then yes you should use an AGM battery maintenance charger. https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    Jermzfree[OP] likes this.
  2. Jun 18, 2019 at 9:32 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  3. Jun 18, 2019 at 9:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, this was a 1st Gen thread, didn’t notice you were 3rd Gen. 3rd Gen does not have the plug and play voltage booster option.
    Grossomotto[QUOTED] likes this.
  4. Jun 18, 2019 at 10:01 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    People complain about a lot of things. If you listen to them, you wouldn't have bought your 3rd Gen Tacoma.
    You say the complaints started when they moved production to Mexico... well guess where many of the 3rd Gen Tacomas are built.
    Optima has been the longest, most tested, highest selling AGM battery for years. The complaints really started when other AGM options began really hitting the market and people who think they are cool by going with the next new fangled battery because newer ... better... Mexico.
  5. Jun 18, 2019 at 10:47 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I bet you know someone with a welder... It doesn't take much welding at all.
    And for me... wrenching on my truck isn't work :)
    Jermzfree[QUOTED][OP] likes this.
  6. Jun 18, 2019 at 11:47 PM
    tony2018
    tony2018 Well-Known Member
    optimas are for pussies!!!:crapstorm:
    Luv my yota likes this.
  7. Jun 19, 2019 at 8:46 PM
    Jermzfree
    Jermzfree [OP] Well-Known Member
    Jeremy
    97 Tacoma 2.7 liter regular cab
    None
