Best deep pitch exhaust?
Discussion in 'Performance and Tuning' started by jmay56, Oct 18, 2024.
  1. Oct 18, 2024 at 10:05 AM
    jmay56
    jmay56 [OP] Member
    2017 White Trd Off-road
    What is the best deep pitch tacoma exhaust that ( I know is going to sound like a bumblebee no matter what) is on the market ( make it specific Im new to the exhaust world).
  2. Oct 18, 2024 at 12:31 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    TRD exhaust is what I run as well as a lot of others on here. I think Borla is a little deeper and sounds nice too!
  3. Oct 18, 2024 at 12:34 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Don't bother. No cat back exhaust is going to make your truck sound good. I think the only pro for the TRD exhaust is looks and that its stainless. This is just my opinion of course :D
    truckmike26, Jakerou and Veet-88 like this.
  4. Oct 18, 2024 at 12:49 PM
    eurowner
    eurowner Duke Sky
    Scoty
  5. Oct 18, 2024 at 1:16 PM
    Disgruntled Scientist
    Disgruntled Scientist Active Member
    '22 4x4 V6 DCSB TSS Barcelona Red
    6112/5160, 3L AAL, 4.88 F&B E-Lockers, OTT
    I tried a few different configurations of exhaust before I settled on a Black Widow Venom 300 muffler, a Vibrant Ultra-Quiet resonator, and a URD Y-pipe. Has a deep tone and not too loud for my taste. This setup is definitely not as "bumblebee" as the other configurations I tried.
    BullComa4.0L likes this.
  6. Oct 18, 2024 at 1:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is your goal noise or do you hope for performance?
    TRD has a nice (to me) sound.
    Chew likes this.
  7. Oct 18, 2024 at 1:22 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  8. Oct 18, 2024 at 1:29 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This isn't a very deep sounding engine, but I'm very happy with my MF Overland and Borla Y-pipe combo. No drone but the truck sounds tougher, like it should. The Borla did more to deepen the sound than the MF did I think, but I also did the Y-pipe second so I am unsure the tone difference it would have made with the stock catback. The Y did make the sound a little deeper though (a little closer to the 4.0l) and lowered the already minimal drone as the flow rate slowed down when removing that bottleneck under the transfer case (sounds a couple hundred rpm lower than it did before the Y, if that makes sense). I also noticed I picked up some decent top end after swapping the Y in, again likely due to removing that big restriction.
    Everyone's preferences are different though. This truck won't sound like a v8 regardless of what you do, but you will be significantly happier with whatever you end up with so long as the exhaust terminates after the rear axle. Any exhaust that dumps under the cab will drone like crazy.
  9. Oct 18, 2024 at 4:20 PM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    Buy a tundra with the v8. lol.
  10. Mar 18, 2025 at 8:31 AM
    Will@Stillen
    Will@Stillen Active Member
    Will
    2nd Gen Tacoma
  11. Mar 18, 2025 at 8:54 AM
    nuSchule
    nuSchule Well-Known Member
    NC
    URD Y-pipe to TRD rear section and I'm extremely happy with it. Echoing other posts that it's not going to sound much deeper, but will sound slightly louder and a bit more throaty in the mid-high RPM range without being obnoxious.
  12. Apr 2, 2025 at 10:37 AM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    Most V6 engines are difficult to not make sound like an old man's GMC Safari.
  13. May 6, 2025 at 9:05 PM
    stielinc
    stielinc Well-Known Member
    I'm very picky about aftermarket exhaust (both looks and sound). I have the Borla CB and am very happy with it
