Best DIY Rust Treatment
Discussion in 'Technical Chat' started by Gtech2, Jun 4, 2012.
What is the best Spray, Paint/Primer, method for spot treating rust?
Poll closed Jul 4, 2012.
  1. POR-15
    0 vote(s)
    0.0%
  2. Eastwood Encapsulator
    0 vote(s)
    0.0%
  3. Fluid Film
    0 vote(s)
    0.0%
  4. One Step
    0 vote(s)
    0.0%
  5. Dupli-Color, Rustoleum, Self Etching Primer etc.
    0 vote(s)
    0.0%
  6. Bedliner
    0 vote(s)
    0.0%
  7. WD-40
    100.0%
  8. Other
    0 vote(s)
    0.0%
  1. Jun 4, 2012 at 11:46 AM
    Gtech2
    Gtech2 [OP] Member
    Jimmy
    Southern California
    98 Limited 4x4
    Deckplate
    I've been searching and searching through the site reading threads on how some members have been dealing with rust but I'm still not sure which spray/paint/method/etc is the best for spot treating.
    I'm sure we've all been concerned with the rust issue especially 1st generation tacoma owners like myself. So I'd like to take a poll to settle this once and for all and determine the most successful way (besides buying a new truck :p) to deal with rust and ensure our trucks last a long time!
  2. Jun 4, 2012 at 5:10 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Ospho is good; it neutralizes the rust.
  3. Nov 17, 2012 at 12:37 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
  4. Nov 17, 2012 at 3:05 PM
    buzzed
    buzzed Active Member
    Ron
    Saint John, New Brunswick
    DCLB Silver Streak Mica
    Not for my Tacoma, as I think I'll send it to the professionals, but on an old Suzuki I'm trying to rebuild, I've been wondering what I could do to prevent rusties from coming back.
    A co-worker and I cleaned some 1" angle iron on a wire wheel/bench grinder and cut it into 4 pieces. We then sprayed on some aerosol products we had laying around:
    Rust Check (red can)
    Rust Check (green can - more waxy like Fluid Film)
    Fluid Film
    LPS#3
    We left them outside during some rainy weather. The Rust Check red piece was showing rust after 2 days. To my surprise, there was also rust forming on the Fluid Film piece within 2 weeks. After one month outside, the Rust Check green can and LPS#3 still looked the same as the day sprayed them. The LPS#3 felt "drier" than the Rust Check, but if you wiped it harder, it was oily underneath the "skin" that it has. However, I don't know how well it will "wick" into areas like some of the others.
    I doubt WD-40 would do much. It's more of a solvent, as far as I'm concerned.
    Used motor oil is terrible - maybe due to acids/comtaminants present? My Dad tried this on a new car (sprayed every fall) and it rusted out terribly. We figured it was the used oil.
    I doubt I'll ever purchase any "rubberised" undercoatings ever again. They just hold moisture, as far as I'm concerned. A good coat of paint brushed on would probably be better.
    I do have a spray can of Rustoleum Cold Galvanizing I'm going to try next. I don't know how well it will hold up, or whether you can put a topcoat on it.
    OP - sorry if this isn't much help, Just wanted you to know that there are others out there wondering the same thing as you.
    Ron
  5. Nov 26, 2012 at 7:33 PM
    koco
    Bay Area Ca.
    '01 Taco
    WD-40 is fish oil, and works pretty well on rust. A fishing boat captain discovered it by accidentally getting fish remnants on some rusty metal on his boat. The fish oil prevented rust for a long time. It is also the key ingredient in rustoleum's original formula.
    I know...it sounds fishy.
