Best door handle?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BarnBoy, May 19, 2018.
  1. May 28, 2018 at 6:40 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Motorcycle chain wax for lube but yea, about 15 bux.
  2. May 29, 2018 at 12:37 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    That will stay but it will be too sticky, bad choice unless you want a dirt/dust magnet, the grease spray won't attract dirt/dust like chain lube. He'd be better off dripping hot wax on said part that wouldn't attract as much, in fact toyota of Long Beach does this to all prerunner door hinges in Ca and they make a mess of the jamb. Plus the lubricant properties of chain wax are higher viscosity which will make the handle move slower than grease will.
  3. Nov 15, 2018 at 5:43 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Another vote for OEM, mine had a cracked brace for years and finally failed about 3 yrs ago. I bought an el cheapo replacement, it lasted exactly 2months and snapped one day when it was around -10F -truck and cab was warm and I didn’t yank on it or anything. Got to use the passenger door till early spring when it was warm enough to replace it with an OEM item.....
    But maybe down in the tropics it’s another story....
  4. Nov 15, 2018 at 7:35 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Sub tropics....
    I think the tropics are cooler.
  5. Nov 22, 2018 at 8:38 AM
    Arctic Taco
    Denali Park, Alaska
    Well it was a fine early fall day....
  6. Apr 2, 2021 at 11:06 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    Dorman door handles good price at Amazon.. ordered yesterday. Will post here if/when it fails
    https://www.amazon.com/dp/B00IWL097I/ref=cm_sw_r_cp_apa_glc_fabc_A7J35YG56P3NEKJE6HHF?_encoding=UTF8
  7. Apr 3, 2021 at 1:13 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    No, the tropics cover the latitudes north and south of the equator from the Tropic of Cancer to the Tropic of Capricorn. The most northern and southern latitudes where the sun reaches directly overhead zenith. The subtropics are just outside those areas and never see the sun directly overhead. It happens at the equator twice a year. None of the US is tropical(except Hawaii) but the all of the states up to latitude 35N have all or at least some portion in the sub tropical zone.
  8. Apr 3, 2021 at 1:48 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    If your handle broke there is a good chance other parts of the mechanism are getting stiff. Fix that and get everything smooth otherwise you'll keep replacing handles.
    I replaced mine and lubricated everything and it takes maybe 1/4 of the force to pull the door handle.
    Broken parts are often a symptom and not always the cause.
