best "economical" rear lift recommendations please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by masonGman, Oct 14, 2015.
  1. Oct 14, 2015 at 6:10 PM
    masonGman
    masonGman [OP] Well-Known Member
    I just installed the Rancho QUicklift to my 2006 Trd Prerunner double cab... love it! however now I really need to finish the rear.
    Please send me some recos for a good AAL or Block to finish the rear. Not sure where or what to get... and not spend a ton of cash.
    Thank in advance for the help
  2. Oct 14, 2015 at 7:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    How much height are you looking for? Icon/wheelers/Toytec progressive 3 leaf AAL is less expensive than a full spring pack and has a great ride. Basically the options in order of preference and quality go:
    Blocks<AAL<progressive AAL<full leaf pack.
    Hairy Taco likes this.
  3. Oct 15, 2015 at 3:46 AM
    masonGman
    I'm thinking I only need about 1 - 1.5" in the rear just to level it out.
  4. Oct 15, 2015 at 8:03 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    single leaf 1.5in AAL from wheelers is 75 bucks.
    I love my 2in single AAL it rides great.
    Lomez and JimboAnz like this.
  5. Oct 15, 2015 at 8:13 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Also did a single AAL, then added a 1" block to get my rake back :thumbsup: Works for me
    thecoz likes this.
  6. Oct 15, 2015 at 8:35 AM
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
    i went from a single AAL to Icon's 3 leaf pack- world of difference in ride quality. worth the extra $ in my opinion.
  7. Oct 15, 2015 at 12:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    And for the OP the Icon 3 leaf progressive AAL adds 1.5" rear lift. It is what I run as well.
  8. Oct 15, 2015 at 12:25 PM
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    Is the Icon 3 leaf progressive AAL appropriate for someone that does almost all their driving with an empty bed but on occasion takes a FULL camping load on Forest Roads, or on occasion tows utility trailer? Heavy coolers and tents add up quick.
    I would like an inch or so of everyday lift( very minimal), with a tangible but infrequent need to support an extra load without compromising daily comfort.
  9. Oct 15, 2015 at 12:47 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I guess it depends on what you define as full camping load. I load my truck with coolers and camping gear, military style deployment contrainer, shooting gear, tons of water, spare fuel and it handles the load better than stock on off road trails that are more challenging than FS roads. If you are towing a utility trailer with a heavy tongue weight or are loading the bed to near max GVW then you should leave the overload in the progressive AAL, which gives 2" of lift. With the overload removed it gives 1.5" and rides very well (better than stock IMO), while providing better handling of smaller/moderate loads.
    Lomez[QUOTED] likes this.
  10. Oct 15, 2015 at 1:06 PM
    nd4spdbh
    SoCal
    sounds like you would be better off with airbags.
    A progresive pack will not provide as much extra load handling compared to a single AAL.
  11. Oct 15, 2015 at 1:31 PM
    Lomez
    Lomez
    AZ
    I am thinking my use is too infrequent to install bags.
    I am not too smart and thought a prg pack would carry more load than a single AAL. Thanks for the correction.
  12. Oct 15, 2015 at 1:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The single AAL will carry more, but the ride unloaded will be noticeably worse.
  13. Oct 15, 2015 at 1:56 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    '06? Are the rear leaf springs original?
    If so, I would not add an AAL to them. Save your money and buy a replacement leaf pack.
  14. Oct 15, 2015 at 1:59 PM
    masonGman
    the rear leafs are under recall and I'm waiting on Toyota to replace them... supposedly in Dec/Jan timeframe. At least that's the plan : )
  15. Oct 15, 2015 at 3:04 PM
    nd4spdbh
    SoCal
    I definitely would not say worse. I LOVE the extra firmness the single 2in AAL in the rear of my truck with the 3+1 leaf pack provides. So to each their own.
    Lomez likes this.
  16. Oct 15, 2015 at 3:13 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Single leaf AAL here. I actually prefer the stiffer ride. A touch harsh when unloaded, but excellent when hauling loads of oak firewood. After three years, it still hasn't settled.
    Lomez likes this.
  17. Oct 15, 2015 at 3:16 PM
    Lomez
    Lomez
    AZ
    You left the overload in then? My 2015 has a 3 leaf spring with flat overload on the bottom.
  18. Oct 15, 2015 at 3:23 PM
    Maticuno
    2011 Suburban 2500
    To be perfectly clear, upgrading your leaf springs does not give you the ability to carry more load than the truck was designed and tested for. Without even discussing legal and safety ramifications, overloading the truck just because your springs carry the load better will add lots of undue stress on the rest of the vehicle including wheel bearings, bushings, diff gears, drive shaft, transmission, engine, brakes, etc. All the stiffer springs do is allow you to carry the maximum listed GVWR without bottoming out the rear end.
  19. Oct 15, 2015 at 3:27 PM
    nd4spdbh
    SoCal
    yes, so the original pack has 3 main leafs. the 2in single aal is just shorter in length than the 3rd leaf down so it fits perfect, then the overload below that.
  20. Oct 15, 2015 at 3:30 PM
    Lomez
    Lomez
    AZ
    And to be perfectly clear, I did not mention OVERloading.
