Best economically priced 3" lift kit for 2011 DC PreRunner?
Discussion in 'Technical Chat' started by TacoTitan11, Dec 22, 2011.
  1. Dec 22, 2011 at 6:28 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    there is a lot of information out there on lift kits and just about everyone has an opinion on what works best. i am not an off-roader, just looking for 3" lift to put on bigger tires and rims. I would like it to be a comfy ride as well. Looking for some good feedback from all the experts on here. Keep in mind, mine is not a V6, it is a '11 4 cylinder double cab PreRunner Thank you.:help:
  2. Dec 22, 2011 at 6:31 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    5100s and an AAL should get your raise and a decent ride
  3. Dec 22, 2011 at 6:32 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    And if the 2.5" setting is a bit too stiff with stock coils then get eibachs springs and set the 5100s at 0.85". Folks say that rides wonderfully.
  4. Dec 22, 2011 at 6:32 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    what are 5100s and AAL ? sorry to sound ignorant....are they expensive?
  5. Dec 22, 2011 at 6:33 PM
    TexasTacoma37
  6. Dec 22, 2011 at 6:34 PM
    TexasTacoma37
  7. Dec 22, 2011 at 6:34 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    thank you for the links
  8. Dec 22, 2011 at 6:35 PM
    TexasTacoma37
    Lol <3
  9. Dec 22, 2011 at 6:36 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    ^^to that I'd add some OME 882s or Eibach coils for the comfy aspect.
    You may not reach 3" all the way however. If you use the aftermarket longer coils you don't have to preload them as much and you'll achieve a plusher ride as you can set the shocks to a lower notch.
  10. Dec 22, 2011 at 6:37 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    body lift for sure
  11. Dec 22, 2011 at 6:37 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    so much information. i feel overwhelmed
  12. Dec 22, 2011 at 6:42 PM
    memario1214
    Colton
    Missoula, MT
    What's your budget? That's the big question
  13. Dec 22, 2011 at 6:44 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    under $500 (not counting labor)
  14. Dec 22, 2011 at 6:45 PM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    5100's set at 2.5 and a 1.5 aal
  15. Dec 22, 2011 at 6:46 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    is that for front and back>?
  16. Dec 22, 2011 at 6:51 PM
    memario1214
    Colton
    Missoula, MT
    You will have Bilstein 5100 shocks in the front and the rest. The add a leaf goes into your leaf pack. The leaf lifts your rear end whereas the springs and shocks raise the front
  17. Dec 22, 2011 at 6:51 PM
    24medic
    24medic Member
    Kevin
    Nor cal
    05 Tacoma black 2.5 coil overs mb choas
    adjustable coil overs, mb choas, 265/74 16 wranglers intake, mag light ,
    Y not the ranco quick lift they r cheap and will give u 2.75 and if u add a spacer u can get higher
  18. Dec 22, 2011 at 6:54 PM
    memario1214
    Colton
    Missoula, MT
    Because its cheap stuff and rides like dog shit...
  19. Dec 22, 2011 at 6:58 PM
    TexasTacoma37
    They ride a lot worse than the 5100s because they are a twin-tube shock.
  20. Dec 22, 2011 at 7:07 PM
    24medic
    24medic Member
    Kevin
    Nor cal
    I thought ranco was a good brand.
