Best Engine Oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmctri4, Jul 5, 2013.
  1. Jul 13, 2013 at 1:31 PM
    #41
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    My 2004 Grand Cherokee's recommended oil was 10W30, but that was also the last year they used those engines and it was designed in the 1950's! :)
  2. Jul 13, 2013 at 7:50 PM
    #42
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, 10w40 served my father quite well in the 60s and 70s.
    Modern engines are different. Maintenance intervals are longer, and tolerances are tighter.
  3. Jul 14, 2013 at 10:58 AM
    #43
    dlehmkuhl
    dlehmkuhl Active Member
    D
    Colorado
    '98 SR5 Stndrd Taco
    Coil over front suspension Blocked in rear
    I hear ya on that Rich fer sure. Tell ya what, I'll give 5-30 a chance when I do my full changover in the next couple months. I've always ran 10-30 with no issues and the Yota Tech I know says 10-30 is fine, but I'm always up for trying something new. Specially since the 5-30 full synthetic is gonna be better (imo) than the regular. Thanks man.
  4. Jul 14, 2013 at 11:05 AM
    #44
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    the one that gets changed at 5k miles
  5. Jul 22, 2013 at 1:54 PM
    #45
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I'm sold on Amsoil personally. I ran Mobil-1 from 5K-25K. At 25K I switched to Amsoil synthetic. At 30K I switched to Amsoil Super Synthetic and left the oil until 45K. I did change oil filter at 35K and 40K with Toyota filters. In a nutshell a 15K interval with a small boost of additional oil when changing filters.
    I don't recommend anybody go for 15K on a single oil filter but I'd be curious to see the test results afterwards. I think I should also reduce air filter interval from 15K to 7.5K.
    Sent the drain oil to Blackstone Labs for analysis. 1.8 TBN still. They suggested going another few thousand miles and re-testing. I didn't try the same test on a different brand, but no need. Kool aid was fully drank. I now have the full line of Amsoil products in my garage from gear oil to brake fluid to ATF to fuel stabilizer.
  6. Jul 22, 2013 at 2:51 PM
    #46
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Just courious as to why you didn't use the amsoil filter rated for 15K. You would have saved some cash over the long haul with the average cost on oem filters. One thing I have noticed with Amsoil filters they are heavy compaired to oem. I know it has to do with construction and amount of filter media.
  7. Jul 22, 2013 at 3:59 PM
    #47
    Ampo
    Ampo Well-Known Member
    12 SR5 4x4
    Those filters do have a heavy gauge housing to them and the over all construction and quality of materials is second to none. The filter media is a mesh reinforced high grade synthetic fiber that filters down to 20 microns, your not going to do better than that with out a bypass system but... the filter media area is quite small. I can't remember the actual square inch measurements (Chris 4x4 has a write up on it) but this filter has one of the smallest filtering media area in a oil filter especially when compared to those paper like filter media found in main stream products.
    So while you get the most efficient and effective filtering with the ea filter one has to wonder how dirty/clogged it gets once you go that many miles considering how small the filter media is. Perhaps this is why many AMSOIL users go with the OEM filter, for fear of losing a good flow due to a clogged up media. I'm using the ea filter myself but I don't want to run it that long either , maybe I'll cut one open after 7,500 and see how it looks, then I can see for myself how it's holding up.
  8. Jul 22, 2013 at 4:17 PM
    #48
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Shell rotella t6 full syn
  9. Jul 22, 2013 at 7:50 PM
    #49
    BUZZCUT
    Georgia
    I forgot about the write-up in the technical section. I think all filters should have a pin that pops when the filter goes into bypass. The diff pressure indicator would be worth it.
    If and I use the word if the filter does go into bypass you still get full flow. The insolubles would climb on the oil analasys. Post it up when you do this I would be very interested on your findings.
  10. Jul 22, 2013 at 9:18 PM
    #50
    penguins_cc
    Will
    Bellevue, WA
    ^^ This. I could not have said it nearly as eloquently, but what he said. After reading the Chris 4x4 write up and other threads, I felt better changing media every 5K. It would be interesting to compare the test results between the two different methods. Anybody doing the 15K with Amsoil 15K filter?
  11. Jul 22, 2013 at 9:49 PM
    #51
    mr2mki
    mr2mki Well-Known Member
    Here's the thing about Rotella... I used to use it in motorcycles. Why? Because it doesn't have "friction modifiers", which are the main reason you can't use car oil in a motorcycle- they kill the friction of your clutch, which shares oil with the engine.
    Point being, I'm hesitant to use Rotella in a car, because wouldn't you want lower friction?
  12. Jun 1, 2019 at 10:52 AM
    #52
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Royal purple or AMS oil 4.0 v6 what would you go with with?
  13. Jun 2, 2019 at 4:14 AM
    #53
    Anthony7516
    Anthony7516 I can not get a picture to up load here
    Queens ,NY
    14, Limited
    MOBIL 1 and stick with an OEM filter
  14. Jun 2, 2019 at 6:22 AM
    #54
    Clearwater Bill
    Billy
    Largo Florida
    Since Toyota doesn't make filters, do you have the scoop on who the low bidder was for the current contract?
  15. Jun 2, 2019 at 6:28 AM
    #55
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Neither
  16. Jun 2, 2019 at 6:50 AM
    #56
    Anthony7516
    Queens ,NY
    14, Limited
    Denso is making the Oil filters for Toyota .
    But after seeing that guy cut all of them open . I like the way the OEM filter is made .
  17. Jun 2, 2019 at 9:21 AM
    #57
    tacoma08brandon87
    brandon
    El Paso Texas
    TRD
    I always go with Toyota filters
    Rick's 2012 likes this.
  18. Jun 2, 2019 at 10:17 AM
    #58
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Filter wise l personally use Toyora filters. But l think as long as you change the oil and the filter regularly with the right viscosity oil for your climate, your good.
  19. Jun 2, 2019 at 11:21 AM
    #59
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    I like Fram oil filters by the case. Hand tighten/loosen.
  20. Jun 2, 2019 at 1:41 PM
    #60
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    i dont suppose you emptied the bed of that load of "insert heavy stuff here" did you?
