Best First Off-Road Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eric0947, Apr 17, 2013.
Whats the best mod?
Poll closed May 17, 2013.
  1. Tires
    134 vote(s)
    60.4%
  2. Skid Plates
    17 vote(s)
    7.7%
  3. Lift
    51 vote(s)
    23.0%
  4. Locker
    20 vote(s)
    9.0%
  1. Apr 18, 2013 at 9:33 PM
    #41
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    IMHO tires and skids together, tires to get you in and out and skids to keep everything in place and in one piece. If you opt for tires only - stick to the easy trails until you get your skids. By the way I own Bud Built skids and they are well made and fit up nicely.
  2. Apr 19, 2013 at 12:59 PM
    #42
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Do this!!!!
    If you go with stock size, you will only waste your money!!! this will give you a little extra height, and you don't rub at all!!!
    I have used stock and 265's, there is no problem with ABS/traction, etc...
    Also, 265's looks better when you are stock!
  3. Apr 19, 2013 at 1:03 PM
    #43
    theboy12
    theboy12 The Answer is 42, But What is the Question?
    Jon
    Redding, CA
    2005 Tacoma TRD Sport DCLB
    King 2.5 Remote Resi'sand rear 2.0s, Dakar Pack, TRD 1st Gen air intake, Stealth 6's wraped in DynaPro ATms 285/70R17s, SnugTop, ALL Pro Front bumper, Brute Fab HC Rear Bumper, Hella Black Magic Lights, Bedslide 1000
    Sometimes tiresize results in a need for lift. I had to lift first so my tires would fit. Why waste time buying tires and having them for 50k if your going to want bigger tires and will need a lift.
    2 cents,
    -Jon
  4. Apr 19, 2013 at 4:43 PM
    #44
    TanaTaco
    TanaTaco Well-Known Member
    James
    Montana
    05 TRD Offroad 4x4
    OME complete kit with dakars, LR UCAs, Seat covers, weathertechs, anytime foglight mod, ABS kill switch, locker anytime mod, powered sub, halos, leer topper, aux/ipod hookup.
    I got the goodyear wrangler authority's for my stock taco last week. 245/75/16 were $750 mounted and the 265/75/16 were only about $10 more a tire. They do awesome in every season and on/off road. I had them on my old T100 and absolutely loved them. Last week the day after I got them I went wheeling with a couple buddies, I made it further then the both of them. One was in a dodge cummins with brandnew 37" duratracs, the other was in a cherokee with 90% 33" cooper stt's. Granted the vehicle makes a big difference but they were all in aw at what the cheap tires could do.
  5. Apr 20, 2013 at 8:55 AM
    #45
    DevL
    DevL Well-Known Member
    Lifts of 3" and less have no impact on what tire fits without rubbing. It only changes the amount of compression needed to rub. If you have proper clearancing and cab mount chop you can fit a 285 width 33" tire the same as a lifted truck with no rubbing. Again, it is an often repeated falsehood on this forum that a lift makes room for larger tires. It does not. It can do the opposite and make rubbing more likely, but never makes extra room... ever. The way it can make rubbing more likely is via added caster with an after market UCA.
  6. Apr 20, 2013 at 5:52 PM
    #46
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Abs killswitch...........
  7. Apr 20, 2013 at 7:16 PM
    #47
    Large
    Large Red
    There is no tire & lift option, it's either, or. Tires are the by far better than a lift as a first Offroad mod, I already stated that 90 some off percent of the members do both at once before.
  8. Apr 20, 2013 at 11:21 PM
    #48
    dtmccray
    dtmccray Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    I have to go with rear locker. Doesn't matter what tires you have if you unload 1 front and 1 rear you are stuck. You should be able to find a wrecked trd and snag the rear fairly cheap. Next would be tires.
  9. Apr 20, 2013 at 11:34 PM
    #49
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    I put sliders on first- because I was stock height, I needed armor bad.
    Next was tires
    Followed by Rear Bumper & Suspension at the same time (I was rear ended- and they gave me a bunch of $$ to play with)
  10. Apr 21, 2013 at 7:53 PM
    #50
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    I put on sliders first, then lift, then beefed up skids, then finally tires. Now waiting for my rear plate bumper to arrive.
  11. Apr 22, 2013 at 12:06 PM
    #51
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
  12. Apr 22, 2013 at 1:24 PM
    #52
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I said lift, but def lift (5100's w/ aal or leaf pack) + tires [​IMG]
  13. Apr 23, 2013 at 2:20 PM
    #53
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Tires, Lockers, Sliders, Skids
    Armor doesn't make you more "capable" off road, just saves you from damage.
    Get tires and locked up then plate everything up, imo.
  14. Apr 23, 2013 at 7:26 PM
    #54
    walter
    walter Well-Known Member
    Inyo Face, Ca
    chicks dig the longbed
    4x4,fox co's,fox rear,265/75/16
    Moon visor, truck nuts, 265/75 tires and sliders
  15. Apr 23, 2013 at 8:55 PM
    #55
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Agreed.
  16. Apr 23, 2013 at 9:03 PM
    #56
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Why is recovery gear not as important as tires? You can always get far enough to be stranded, stock or not. You can't always get out, tires, lift, sliders, body armor, gears, lockers, etc. None of those help when the shiny side is down. Just wondering why recovery equipment isn't more of a concern.
  17. Apr 23, 2013 at 9:12 PM
    #57
    Boone
    Boone, NC
    Airbags deployed
    I thought we left this in another thread.............:anonymous:
  18. Apr 24, 2013 at 3:51 PM
    #58
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    The order I did mine & why
    Lift (room for larger better tires)
    Tires (33" BFG KM2s for better traction & ground clearence)
    Sliders & a full set of Skids (protect my sides & belly)
  19. May 9, 2013 at 11:08 PM
    #59
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Tires.
    No other mod is worth a shit if you can't even get traction.
  20. Aug 3, 2016 at 8:51 PM
    #60
    eric0947
    eric0947 [OP] Well-Known Member
    Chuck
    Phoenix, Arizona
    Alright, this is a old thread but I have some experience now and wanted to reply so hopefully newer folks can benefit. I ended up doing:
    1. Manual recovery gear (hi-lift, etc.)
    2. Skid plates
    3. Tires
    4. Locker
    5. Power recovery gear (winch)
    I realize everyone's got their opinion, but this order worked well for me.
    The truck is already very capable from the factory so recovery equipment and protection seemed like the best place to start. Why make it more capable without any method for recovery? You'll only be stuck further from help.
    Next I added more capability in the form of tires and a locker. Getting stuck once with this setup thought me that manual recovery equipment is a bare minimum and that powered equipment would be more practical so I finished up by adding a winch.
    In the future I might consider rock sliders and a lift. Lifts look cool, however unless you go big or go expensive you make sacrifices for minimal returns. For example, a spacer lift gives you 2 to 3 inches in the front but nothing (unless you go with bigger tires) in the rear. However it degrades ride quality, limits down travel, and increase wear and tear due to geometry changes.
    One last thought - this order allows the drivers skill to progress so that the trucks ability doesn't outpace him/her...which can lead to very bad things!
    This is just my opinion, please don't hate on me! :cheers:
    Chuck
