Best fishing mods
Discussion in '3rd Gen. Tacomas (2016-2023)' started by radclerk1, Dec 12, 2021.
  1. Dec 12, 2021 at 4:33 PM
    radclerk1
    radclerk1 [OP] Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Favorite mods you’ve done to your truck for fishing. Post em up!
    Kolter45 likes this.
  2. Dec 12, 2021 at 4:55 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Gasoline
    Kolter45, kmorgan3 and Skydvrr like this.
  3. Dec 12, 2021 at 5:19 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Here are some of the things I have pictures of. But mostly mine revolves around being able to carry 2-3 kayaks, plus all gear in a fairly organized system. If its just me fishing, then I toss the kayak in the back, rods in the passenger seat, and tackle bag in the back seat. If its me and my fishing buddy, then rods go in the rack, bags go in the basket, and kayaks go under the rack.
    I also put in a reverse light on any time mod so that I can see the area behind the truck when loading our fishing gear at night.
    Electric wash down system (5 gallons) for spraying down the kayaks, boots, buckets, bait coolers, or what ever else got nasty while fishing.
    Rod rack, basket to hold plano totes of fishing gear (kayak fits under rack)
    Kayak paddle holder
    Overhead rack that fits 2 small tackle boxes in molle bags, also fits multiple 2 piece rods for roadside fishing anytime
    Kolter45, c_walters, Skydvrr and 2 others like this.
  4. Dec 12, 2021 at 5:42 PM
    Rollo67
    Rollo67 Well-Known Member
  5. Dec 12, 2021 at 5:58 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    now to get it wet..
    Montana_Actual likes this.
  6. Dec 12, 2021 at 6:19 PM
    5nahalf
    Erik
    Minnesota
    Forgot to mention for hard water season! I keep my ice sled, shelter, auger bit, and chisel in the bed of the truck. Then I just throw my bait bucket, rod bag, fish finder, and heater into the back seat. If its a lake that allows motorized vehicles, then I load my mini bike into the back of the truck next to my sled so I can tow the sled.
  7. Jan 22, 2022 at 7:23 PM
    Travace
    Travace Well-Known Member
    so this is just how i have to roll till i can do some of the things i want to do. on the list of things to do are.
    lighting
    long travel rod security
    stationary rod holding for active fishing.
    fish cleaning and storing.
  8. Jan 22, 2022 at 7:37 PM
    NightFly
    NightFly Active Member
    Montana
    2022 TRD OR MGM MT 2020 4Runner Venture 1979 Toyota Pickup 4x4
    Overhead rack that fits 2 small tackle boxes in molle bags, also fits multiple 2 piece rods for roadside fishing anytime..
    Where did you get this rack? Pretty neat.
  9. Jan 22, 2022 at 7:48 PM
    5nahalf
    Erik
    Minnesota
  10. Feb 26, 2022 at 9:14 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Not a Taco, but I figured you guys might like this anyway. :)
  11. Feb 26, 2022 at 9:21 PM
    bigbadbarty
    bigbadbarty Well-Known Member
    Granite Falls, WA
    2021 Tacoma OR DCLB
    Is that the Wavian Jerry Can Mount? How did you attach it to the front rail? I'm looking to do something just like that but the mounting points in the rack are way too low.
  12. Feb 26, 2022 at 9:23 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    My favorite fishing mod is hitching up the boat.
    kmorgan3, FishaRnekEd and Travace like this.
  13. Feb 27, 2022 at 4:12 PM
    5nahalf
    Erik
    Minnesota
    I got the smitty built can holder, and the sides of it just happen to let 1/4 square tube slide in. So using 1/4 square tube and some angle iron I welded up a little "fork" that holds it in place, then just bolted it to the header rail.
    Thatbassguy likes this.
  14. Feb 27, 2022 at 4:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    here's my favorite mod i built for the boat... tackle storage/set up table with vertical net storage
    Kolter45, TacX2, TartanEagle and 3 others like this.
  15. Feb 27, 2022 at 4:31 PM
    bigbadbarty
    Granite Falls, WA
    2021 Tacoma OR DCLB
    Gotcha. thanks for the info. I have Rotopax on the rack but I'm looking for something to hold an extra 5 gallons inside the bed just in case.
    Thatbassguy and 5nahalf[QUOTED] like this.
  16. Feb 27, 2022 at 4:48 PM
    5nahalf
    Erik
    Minnesota
    I found a picture that shows it better
  17. Feb 27, 2022 at 4:55 PM
    bigbadbarty
    Granite Falls, WA
    2021 Tacoma OR DCLB
    I like it. Seems like a simple and secure solution. Thanks for the extra pic.
  18. Feb 27, 2022 at 4:57 PM
    5nahalf
    Erik
    Minnesota
    Its super simple, and its held my can back there for awhile now. The nice thing is that the holder kinda floats and stays down with its own weight. It has about 1 inch of up and down movement, so I can pull the bed mat out or put it back in pretty easy.
  19. Feb 27, 2022 at 4:59 PM
    bigbadbarty
    Granite Falls, WA
    2021 Tacoma OR DCLB
    ah, so the square tube isn't welded. It has room to slide up and down a bit. Genius!!!!!!
  20. Feb 27, 2022 at 5:02 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    A hot shower setup. Right on the boat ramp, beside the truck. Then back into the boat and into the hammock. We fish to exhaustion. Being old farts we don't have the endurance we use to. A long, hot shower is soothing and recuperative. (This 16-gallon setup will allow an 12-1/2 minute HOT shower.) Currently putting the same hot shower experience that we enjoy in fish camp onto the side of the truck. Campsites are $35/night down here. We're cheap. We don't need no stinkin' campsite! Except for the water spigot located there. So...Stealth shower on the boat ramp after dark, cook a quick meal off the tailgate and into the hammock: 4:00am comes too quick!
    Shower enclosure: SHOWER ENSUITE / CHANGE ROOM - Drifta Camping & 4WD
    Water supply: NorthStar ATV Spot Sprayer — 16-Gallon Capacity, 2.2 GPM, 12 Volt | Northern Tool
    Heater: Amazon.com: Portable Propane Tankless Water Heater, 1.32GPM/5L Capacity, 6 in 1 Safety Function, 7 more Usage Scenarios, Easy to Install, Low Pressure Startup, White : Everything Else Fuckabuncha' black shower water bags! With this, fire it up and recirculate for 5-10 minutes to get the tank water up into the 70-ish degree range, then divert to the shower wand and it will put out heated water well into 120-degree+ steaming luxury. I've been using the 2.65gal/minute, bigger hot water heater I installed on a luggage cart for when we are in camp and on unlimited campsite water. Then you can sit in the shower tent and drink Bloody Marys and steam and soak for half an hour, or for as long as you want! Your home shower is 1.5 gal/minute. Can you imagine how much steam a 2.65gal/minute will generate in an enclosed shower tent? Compared to a home shower it is a deluge. And the hot water never runs out until you are out of propane. Hours. Yeah Baby! Putting a bilge pump on the boat trailer to push water forward to fill the tank when empty. Back down the ramp, trailer in the water, flip the switch and the tank fills up. When the overflow stream starts shooting out from under the driver's side fender well it's full. NEXT! My days of being grungy after fishing have been way behind me for twenty years.
    20220227 - North Star 16gal spray setup and Fouree 1.8gal per minute water heater.jpg
    Oh, almost forgot. Modify Front Runner's table carry bracket to fit that fish cleaning table the water tank is sitting on.
