Best front axles for Bilstein 6100 3” lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eclearcreek, May 1, 2025.
  1. May 1, 2025 at 5:55 PM
    Eclearcreek
    Eclearcreek [OP] New Member
    Bill
    Seaside, OR
    2005 4X4 Tacoma
    Upgraded 9” stereo, front and rear Bumpers, 3” lift, and 33s on black rims
    I recently had the front end of my 05 Toyota Tacoma rebuilt, also added a 3 inch lift with the bilstein 6100 kit. I’m going to replace the front axles and need to know what are the best axles for this type of lift.
  2. May 1, 2025 at 6:04 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    OEM is by far the best.
    If you over lift the truck you will go through boots quickly.
  3. May 1, 2025 at 6:07 PM
    Eclearcreek
    Bill
    Seaside, OR
    2005 4X4 Tacoma
    Thank you I like sticking with OEM just thought I would ask to see if anyone had some ideas or thoughts on this.
  4. May 2, 2025 at 11:59 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Rebuild your OEM axles with extended boots.
  5. May 2, 2025 at 3:47 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    CVJ axles; rebuilt OEM axles.
  6. May 2, 2025 at 3:55 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    As long as your in there might think about doing the ecgs bushing mod.
