Best front brake pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waller24, May 23, 2010.
Which is the best brake pad?
Poll closed Jun 22, 2010.
  1. Green Stuff
    18 vote(s)
    19.4%
  2. Hawks
    24 vote(s)
    25.8%
  3. OEM
    39 vote(s)
    41.9%
  4. other
    12 vote(s)
    12.9%
  1. May 23, 2010 at 7:41 PM
    waller24
    waller24 [OP] Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    havent decided which are the best....
    ive heard some of the better pads are harder and can cause earlier rotor wear but I will let yall decide for me.
  2. May 23, 2010 at 9:46 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    I have used EBC green stuff pads with their drilled and sloted rotors on other truck and loved the setup. I am puttin the same setup on my truck soon.
  3. May 23, 2010 at 9:52 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    Never had to replace my pads or rotors yet. If i had to, i'd say hawks...
  4. May 24, 2010 at 6:58 AM
    waller24
    Alabama
    I have a winch and brushguard so I'm looking for something to hold up with the extra weight.
  5. May 24, 2010 at 7:04 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I have Hawk HPS pads, EBC Sport slotted/dimpled (not drilled) rotors, and Goodridge stainless steel lines and I'm very happy with the brake response. Stock brakes feel like you're stepping on dog shit IMO.
    Tatts521 likes this.
  6. May 24, 2010 at 7:07 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Dont believe the hype OEM Pads and Rotors are the bestest:thumbsup:
  7. May 24, 2010 at 10:44 AM
    Tacobullito
    Tacobullito Active Member
    Rick
    SoCal
    05 Double Cab 4.0 Liter V6
    Does your pads make alot of noise?. I heard from other that the HPS are loud. Thanks.
  8. May 24, 2010 at 1:13 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    question, do you guys with aftermarket pads/rotors still experience that clanking when you first apply the brakes in drive or reverse?
  9. May 24, 2010 at 1:16 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  10. May 24, 2010 at 1:18 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    sweet thanks. now im even more excited for my oem pads to wear out. maybe the rotors too :cool:
  11. May 24, 2010 at 3:57 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I doubt anyone has tested 5 or 6 different brake pads with their truck. So everyone is just going to recommend what they bought themselves
    vtown likes this.
  12. May 24, 2010 at 4:45 PM
    SManZ
    Fauquier County, VA
    Nope, no noise with the HPS pads.
    My g/f has Hawk HP Plus pads on her tC but she races the thing. On the street the HP Plus pads make a horrible scraping/squeaking noise thats supposedly normal. It goes away after the pads heat up. I wouldn't recommend HP Plus for the street, but HPS I've had on this truck and my prior 350Z with good results and no noise.
  13. May 24, 2010 at 4:45 PM
    SManZ
    Fauquier County, VA
    You'll be waiting a long time! Just trash the OEM pads and get new ones.
    Lol edit, just saw you have an '06 so maybe you're coming up on replacement anyway :)
  14. May 24, 2010 at 6:19 PM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    Well i only have 36k miles on it. Last time i rotated, back in january, i still had about half of my pads left. I want some new pads and rotors, but besides the annoying "clank", my pads are fine. So i reckon its a wait game.
  15. May 24, 2010 at 7:29 PM
    SManZ
    Fauquier County, VA
    Hmm...check the torque on your wheel lugs. When I changed rotors, I remember a clank noise the first time I braked hard. The rotor rotated slightly and the noise was caused by the leading edge of the holes in the rotor setting against the wheel studs. After it set I haven't heard it since. I think loose wheel lugs might not put enough pressure against the rotor to keep it from slopping back and forth when you backup and go forward?
  16. May 24, 2010 at 7:38 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    OEM = best quality
  17. May 25, 2010 at 7:35 AM
    jonny
    jonny Betty White Edition Heep ZJ
    is that what this is? i always thought it was my sway bar hittin my shock or something :laugh:
    good to know..
  18. May 25, 2010 at 8:11 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    It's the front brake design on our trucks. There's too much play in the pads where the pins slide through them, or you could say too much play in the pins themselves...depending on how you look at it. The pads will slide up or down and slam against the pins the first time you apply brakes after traveling in the opposite direction (going forward, stopping, putting it in reverse, then hitting the brakes for the first time in reverse will cause the clunk/ting/ding whatever you want to call it. Same then happens after going in reverse, then traveling forward and hitting the brakes the first time.).
  19. May 25, 2010 at 9:26 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    For cars, I have had great success with Axxis.
    MetalMasters are the shit, amazing performance with a lot of dust.
    Axxis Deluxe if you don't want to clean your wheels all the time.
    Remember, this is a truck, not a performance machine.
  20. May 25, 2010 at 10:49 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    x2!. i always thought i had a loose pad or something was actually wrong. technically something is loose but its not a big, big issue. though i would like to see that clank go away...:cool:
