best front lift under >500?
Discussion in 'Suspension' started by achirdo, Jun 27, 2010.
  1. Jun 27, 2010 at 3:12 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i currently have a 3" spacer for my front end...didnt really research all the negatives of this lift and now regret it. i do occasional offroading and run the truck pretty hard. i DO NOT have the money for coilovers so dont tell me to do that. i was thinking about replacing the fron spacers with a OME 884 coil and maybe billy 5100s? will this give me the 3" of lift back and not give me any kind of problem off roading? i currently have trailmaster ssv shocks in the back with a 2" block (gonna get new leafs eventually). The OME set up is the best for the money correct?
  2. Jun 27, 2010 at 3:13 PM
    achirdo
    Adam
    North DFW
    or will the spacers be fine for another year or 2 and i should just save for the spindle lift? or could can i put the 4" spindles on along with this OME set up later one down the road?
  3. Jun 27, 2010 at 3:15 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    maybe billy 5100s with OME 885s with a AAL :notsure:
  4. Jun 27, 2010 at 3:17 PM
    achirdo
    Adam
    North DFW
    so this set up will give me a lot less of a risk of breaking something off road than with a spacer right?
  5. Jun 27, 2010 at 3:18 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    yes you can get ome now and add spindles later...but you will have 7" of lift
  6. Jun 27, 2010 at 3:22 PM
    achirdo
    Adam
    North DFW
    will a new leaf pack and that 2" block be enough to make the truck not look retarded? and i would have to get what later on? longer break lines, longer steering colum? anything else? would UCAs be neccesary?
  7. Jun 28, 2010 at 9:44 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Save your money and buy the full OME lift. Its not that much trust me. Cheaper than spindles and way better than spacers. I'm like you, young and in high school. I have summer job and only get $160 every 2 weeks but I will soon have enough to make the next step. Think about it, its gonna cost around $2000 after lift tires UCA and all that stuff, but thats still feasable
