Best guess for 2024 Tacoma SR MPG?
Discussion in '4th Gen. Tacomas (2024+)' started by bananaboat, Sep 1, 2023.
  1. Sep 5, 2023 at 4:44 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    That van looks nice, not sure how reliable a rebaged Toyota is.
    I still want that RC Ranger. I can see it with an ARB commercial bull bar and Warn winch skid plates. OME MT64 suspension, a set of those bronze Bronco wheels from Ford, and some skinny MT Baja Boss tires. Front and rear air lockers if those are available.
  2. Sep 5, 2023 at 6:42 AM
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Probably no less reliable than a Toyota.
    That would be cool.
  3. Sep 5, 2023 at 8:54 AM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    Yes and no. Aerodynamic drag increases 4x with the doubling of speed…so speed is extremely relevant. Plenty of studies showing gas mileage dropping dramatically at anything over 55-60.
    My guess is non hybrid 4x4 tacos will get 1-2 mpg better than the outgoing model best case. And as Doug notes above, if you drive with a lot of skinny pedal as a lot of us will with more low end power on tap with the turbo, real world mpg will actually be worse.
    spittle8, oconnor and TDRDude like this.
  4. Sep 14, 2023 at 6:40 AM
    TDRDude
    TDRDude Active Member
    I think everyone figured out that going up hill or towing the turbos would kick in. As I said my friend's 2.7 F150 anything under 60 mph and it gets 28 mpg. Over that and it drops to like 18mpg. I also said I don't know exactly what speed turbos on Tacoma will kick in. You are saying that even at 100 mph they won't. whatever another post that defies physics and common sense.. I guess you also think larger tires won't kill mpg either then post everyday how you don't care about mpg.. lol
  5. Sep 19, 2023 at 4:22 AM
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    wow. I have a gen3, admittedly with large tires, and get 17mpg on a good day. 27mpg?! Wow.
  6. Sep 20, 2023 at 7:51 PM
    bananaboat
    bananaboat [OP] Well-Known Member
    What were the EPA fuel estimates for your truck? For mine, a 2006, it was 20 city/ 27 highway.
  7. Sep 26, 2023 at 9:36 AM
    Dosser
    Dosser New Member
    Brian
    Cincinnati, OH
    2023 Tacoma Trail Edition
    20mpg is my guess
  8. Sep 26, 2023 at 3:13 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The new Land Cruiser with the same engine is reportedly getting 27 MPG's. I'd still take that # with a grain of salt, since paper rarely matches real world. Also not sure if that's the hybrid or not. Interwebs is very vague.
  9. Sep 26, 2023 at 5:26 PM
    vtown
    CT
    Toyota also took that Land Cruiser 27 MPG tidbit down off the toyota website after all the yahoos went on and on about it all over YouTube. So yeah, major grain of salt.
    oconnor likes this.
  10. Sep 26, 2023 at 5:54 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    In my opinion, I think they're the true numbers (on paper) and it was just an accidental release into the wild. Wouldn't be the first time Toyota goofed like that. Hell, wouldn't even be the first time this year.
  11. Sep 26, 2023 at 6:04 PM
    vtown
    CT
    Yeah maybe. There is a chance that a hybrid model like the limited (or more likely the LC) could get or approach 27 mpg with the stock donut tires. The big tires on the pro or TH are going to knock it down a couple MPG. And there’s zero chance the non hybrid will get there.
  12. Sep 27, 2023 at 6:31 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    A turbo doesn't kick in based on speed. The turbo will spool up and provide power based off the amount of throttle.
  13. Sep 30, 2023 at 5:01 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Staying out of the Turbo on flat ground, I'd guess around 26 on stock tires.
  14. Oct 1, 2023 at 6:28 AM
    batacoma
    batacoma Truck Wars
    My experience with turbos mated to an auto is they like to be spooled, even if you aren't mashing the gas and the transmission shifts more smoothly with a little more rpm.
  15. Oct 1, 2023 at 7:26 AM
    #35
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    All of this is conjecture until the truck is released. 2024 is going to be a long wait.
  16. Oct 1, 2023 at 7:30 AM
    #36
    batacoma
    batacoma Truck Wars
    You can always guess what the first most popular mod will be? Raptor lights-or will that not be popular for the 4G.
    What will be the first recall? Waste gate issue-or something dumb like a seatbelt clip?
  17. Oct 1, 2023 at 2:27 PM
    #37
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Since the waste gate issue was apparently sorted out with a change of supplier, I’ll be it will be simple electronic stuff like most recalls these days
  18. Oct 1, 2023 at 3:21 PM
    #38
    batacoma
    batacoma Truck Wars
    No one will know until after the truck is on the road for sometime.
  19. Oct 1, 2023 at 3:24 PM
    #39
    OpeCity
    Long Beach, CA
    Sure, but there’s nothing inherent about wastegates that make them a likely failure point. It’s just what you heard about the tundra, so I’m correcting that info.
  20. Oct 1, 2023 at 3:29 PM
    #40
    batacoma
    batacoma Truck Wars
    Those were electronically controlled waste gates which are common on turbo charged engines, and you said you would expect simple electronic related recalls if any.
