Best guess for 2024 Tacoma SR MPG?
Discussion in '4th Gen. Tacomas (2024+)' started by bananaboat, Sep 1, 2023.
  1. Nov 29, 2023 at 4:45 AM
    #101
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    I totally nailed it! At least for the 278HP models: 19/24.
  2. Nov 29, 2023 at 8:59 AM
    #102
    bananaboat
    bananaboat [OP] Well-Known Member
    The subject was the Tacoma SR 4x2 and the correct answer would have been 20 city/26 highway.
    Phlogiston likes this.
  3. Nov 29, 2023 at 3:00 PM
    #103
    yota4life007
    yota4life007 Member
    I'm so stoked for this v4 for 50k with amazing mpg, great job Toyota
  4. Nov 29, 2023 at 3:32 PM
    #104
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Gen3TacomaOBX likes this.
  5. Nov 29, 2023 at 5:31 PM
    #105
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    He'll get back to you when he's patting himself on the back
  6. Dec 1, 2023 at 12:41 PM
    #106
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Welp I guess this partially explains the reason for the derated (software limited) SR model.
    [EDIT: removed my comment about mpg not being any better than the 3rd gen 4x4)
  7. Dec 1, 2023 at 12:56 PM
    #107
    ericin1984
    2023 TRD OR Auto
    I expected this. The 2024 is heavier and has a larger frontal area. More weight and more drag is countering whatever tiny gains could be had with the 2.4L turbo vs the old 3.5L V-6. Plus, you could see the writing on the wall with the 2023 Highlander 2.4L Turbo vs 2022 3.5L. User results of Fuelly show the 2.4L is getting worse real world MPG.
    auskip07 likes this.
  8. Jul 30, 2024 at 8:18 AM
    #108
    ChadVKealey
    ChadVKealey Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    I was thinking of replacing my 2017 SR5 in the next year with the 24 or 25 model, but seems like a step backward in economy. Driving from Philadelphia to Portland (Maine) yesterday I averaged ~27 mpg (according to the dash reading).
    Now, when towing (our scout troop trailer, ~3,500-4,000 lbs), I struggle to get 12 mpg on level highway. I can't imagine a 4 cyl turbo would be any better.
  9. Jul 30, 2024 at 8:26 AM
    #109
    Gen3TacomaOBX
    S
    If you can get 27 mpg out of your V6 then you're obviously great at slow controlled energy management. Knowing that I'd guess that you'd get better MPG with the 4 cylinder turbo because the issue with the NA V6 doesn't have enough ass (torque) to pull the 3500 lb trailer in high gear at speed.
    I'm a 3rd gen Tacoma fan BUT the new 4 cylinder turbo is likely to be an improvement in every way. I have a Bronco w/2.3 turbo that's got some Get-R-Done and imagine the Toyota 2.4 turbo will be even better.
  10. Jul 30, 2024 at 6:20 PM
    #110
    bananaboat
    Why do you think he has a v6, because you have one?
  11. Jul 31, 2024 at 6:27 AM
    #111
    Gen3TacomaOBX
    S
    Well since you asked like that...
    Perhaps because I didn't consider anyone would think the 2024 turbo 4 cylinder SR (derated to 228 hp and 243 ft lb torque) would be a step back from the N/A 4 cylinder (159 hp and 180 ft lb.)
  12. Jul 31, 2024 at 6:49 AM
    #112
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    My Fuelly average over five years is about 21.5 in my LB (with a cap) here in Wisconsin. From April to November I'm disappointed if I dont get 22 MPG per tank average in mixed driving. In winter, MPG is lower of course. The way I drive I am pretty sure I could milk 22-23 MPG average out of the new Tacoma. Maybe 25 out of the hybrid? I may never know since the latter does not come in a LB outside the Trailhunter trim :(
  13. Jul 31, 2024 at 7:19 AM
    #113
    Gen3TacomaOBX
    S
    What year do you have where the EPA estimate was 27 mpg highway? I ask because the EPA records appear to show that 21/25 was the highest for the 2nd gen years:
    Perhaps someone more knowledgeable can comment on whether the EPA 're-worked' their historical numbers due to the 2008 testing standard changes which lowered tests results by 1-2 mpg.
  14. Jul 31, 2024 at 12:39 PM
    #114
    bananaboat
    2006, 4 cylinder, 2 wd.
    Gen3TacomaOBX[QUOTED] likes this.
  15. Jul 31, 2024 at 12:43 PM
    #115
    bananaboat
    He said step back in economy, not power.
  16. Jul 31, 2024 at 12:55 PM
    #116
    Gen3TacomaOBX
    S
    Thanks. The 2006 2wd Toyota brochure indeed matches the numbers you mention 20/27.
    It's interesting that fueleconomy.gov (operating under the EPA) has different values:
  17. Jul 31, 2024 at 1:45 PM
    #117
    ChadVKealey
    Philadelphia, PA
    None (yet)
    Actually, I do. Stock 2017 SR5 V6 4WD DCSB with an ARE cap. Also, I use cruise control judiciously (when not towing) and on this trip had it set at 65 most of the way. The drive home (today), I averaged about 26, but traffic and road conditions were different. I do this trip twice a year and usually get about 26.
  18. Jul 31, 2024 at 2:09 PM
    #118
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    that sounds about right.
    A few weeks ago My wife and I did a short road trip, about 200 miles. On the highway i had CC set to 85mph for close to 150 of those miles, RPMs were about 2K at that speed. I averaged 25-26mpg. It was all flat with no real wind.
  19. Jul 31, 2024 at 2:17 PM
    #119
    bananaboat
    That's very surprising since no 2017 v6 4wd Tacoma is rated over 23 mpg highway according to the green vehicle guide Gen3TacomaOBX mentions. Most models are 20/21 highway.
    I occasionally get more than the EPA mileage rating when I have a tailwind and/or I'm going downhill. I have to go no more than 60 mph in normal conditions to get the EPA rating on my 4-cyl 2 wd Tacoma.
  20. Jul 31, 2024 at 4:17 PM
    #120
    ChadVKealey
    Philadelphia, PA
    None (yet)
    I might have also been drafting a bit off a few of the many tractor-trailers out there :devil:
