Best hard cover for 6ft tacoma around $1,000 or less that is somewhat water tight?
Discussion in 'Tonneau Covers, Caps and Shells' started by Cmf51600, Nov 4, 2020.
  1. Nov 4, 2020 at 12:30 PM
    Cmf51600
    Cmf51600 [OP] New Member
    Collin
    2021 tacoma trd off road 6ft in cement
    Whats the best hard cover out there that is not diamondback? Looking for something that is really water tight and can stand up to ohio snow
  2. Nov 4, 2020 at 12:33 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    None are 100percent water proof .. but a low max or back flip Will do a sufficient job .
    Leopard Print likes this.
  3. Nov 4, 2020 at 1:03 PM
    Leopard Print
    Leopard Print Well-Known Member
    I have a Lomax and love it. A tiny bit of water gets in when it rains, but it could be because of my installation.
    donp and CementMixr like this.
  4. Nov 4, 2020 at 3:00 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the forum from Eastern North Carolina.
    Extang Encore. It opens front or rear, can be removed without tools by one person in just a minute, and the front lock can be keyed the same as your ignition/door key.
    https://extang.com/encore-tonno
    I got mine from a local retailer for considerably less than MSRP.
    PilotguyPA28 likes this.
  5. Nov 4, 2020 at 6:33 PM
    Toy1985gc
    Toy1985gc Well-Known Member
    G
    2020 TRD Sport 4WD DCLB Tech Pckg Cement
    3 & 1 leveling kit 32 BFG KO's x17 Method Roost wheels/ TRD Skid
    I love my back flip! Had dealer include on deal. I think it cost them $850.As mentioned, none are 100% waterproof. Yet- the back flip has drainage tubes that diverts water away from bed. Also- another awesome feature is that it sits 100% flush- can’t even tell I have one . Love love my back flip. On my second gen- I had a tri fold - I think i paid 250 on Amazon and held up pretty good if you wana go cheap . Well spent 250 and had for like 4 years . Sold with my other truck . See pics of my back flip and tri fold .
    CaptainBart45 likes this.
  6. Nov 4, 2020 at 7:11 PM
    DeadeyeSkunk
    DeadeyeSkunk Member
    2017 TRD Off-Road V6 4x4 Double Cab AT
    Spend a bit more if you can and get a roll n lock unless security isn't an issue. Favorites seem to be Bakflip or Extang 2.0.
  7. Nov 4, 2020 at 8:04 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Bakflip for me. I have the G2 but I believe you may be able to get a MX-4 under 1,000, especially with the Black Friday etc coming up.
  8. Nov 5, 2020 at 6:12 AM
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
    I like that it locks and that you can open either end. I got the remote OEM lock for my tailgate so I don’t have a key for it. Not sure how I’d work that out.
  9. Nov 5, 2020 at 6:15 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've found the stock toyota cover pretty good so far, nearly zero leakage, plus it didn't cost anywhere close to $1,000.
    VaToy likes this.
  10. Nov 5, 2020 at 6:31 AM
    USATRDR8CR
    USATRDR8CR Well-Known Member
    Orange County, CA
    2018 MBM TRD OR DCLB
    I’ve previously owned the BakFlip MX4 and find that the fit and finish left something to be desired. Also, the securely of the cable pull release was easily overcome with a coat hanger
    I currently have the Leer HF350M. I like the look, quality and fit and finish.
    https://www.leer.com/tonneau-cover/hf350m
    Leer recently released a slimmer version (similar to the BakFlip MX4) which I also like.
    https://www.leer.com/tonneau-cover/h650m
    Both versions have pinch style release mechanism so it feels more secure. They’re pretty watertight if installed correctly using the supplied butyl(?) tape. Also, there is no drain hoses to mess.
    The_Devil likes this.
  11. Nov 5, 2020 at 6:33 AM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    I have the Bakflip G2. It has been pretty stellar so far, even in Seattle! The main area for water intrusion is from the wheelwell flipping water under the factory bedrail caps, which are not sealed.
  12. Nov 7, 2020 at 5:01 PM
    PEIHank
    PEIHank Active Member
    2018 TRD Sport
    I have the Leer HF650M and really like the look, quality and fit. I washed the truck today with a pressure washer and have minimal water inside bed. I did not install the supplied butyl tape or extra foam peices along the rails. Figured I'd wait to observe water tightness before I bothered with them.
    The only complaint I have thus far is the customer service. A couple of peices were either broken or missing when I received it. I have been trying to get replacements since July. Leer teels me they are having issues shipping to Canada - really???
  13. Nov 7, 2020 at 6:26 PM
    Naszero
    Naszero Well-Known Member
    2021 Cement DCSB TRD OR 4x4
    Your tailgate lock doesn't use the valet key that's built into your key fob?
  14. Nov 7, 2020 at 6:57 PM
    Wasatchrider
    Wasatchrider Well-Known Member
    this undercover came with my truck when I got it waterproof really no water can get in until you open it and you can stand in it and sleep on it with two people holds up to as much snow that will stack up 7F1AFA77-1529-45A1-8152-99073FA89F34.jpg
    CusterFan, FUN TACO and MSN88longbed like this.
  15. Nov 7, 2020 at 7:46 PM
    SamOfSteel
    SamOfSteel Well-Known Member
    Sam
    Cement 2018 Tacoma TRD OR
  16. Nov 7, 2020 at 7:48 PM
    PilotguyPA28
    Trip
    I found the key in the glove box. Guess the dealer put it in there. Yes I have a valet key, too.
  17. Nov 7, 2020 at 10:09 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Have the Lomax aluminum trifold works perfectly pretty water resistant. Well under $1000 takes 2 minutes to take it off or put it back on after first set up.
  18. Nov 7, 2020 at 10:17 PM
    Fire Chicken
    Fire Chicken Aka 'Panda Express'
    Charles
    2019 Tacoma TRD Off-road 4x4; 1979 Pontiac Trans Am WS6
    I put the mx4 on mine. I love the multiposotion and ease of removal. Sits very flush with the bed and looks great. I have been in a light hailstorm or two, while I have no dents on the body, there are some dings on the cover. I would definitely buy again.
    As far as opening with a coat hanger like someone else said, I am sure you could, but if someone wants in I would rather them slide that in than destroy the whole cover.
    CusterFan likes this.
  19. Nov 8, 2020 at 1:54 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Factory cover is the best for fit and finish. Looks great and a little adjustments mine barely leaks. It serves me well, I don't.carry anything back there as mine is more for.looks.
    Canadian Caber and zoo truck like this.
  20. Nov 8, 2020 at 6:19 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    Trouble shipping to Canada sounds like bullshit to me.
