Best HD fan clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by cr500taco, Jun 12, 2013.
  1. Jun 12, 2013 at 2:52 PM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    K&N intake.
    I want to replace my stock fan clutch on my '97 3.4L 4WD with a HD fan clutch for towing. What do you guys recommend?
  2. Jun 12, 2013 at 7:43 PM
    Mr.Jack
    Mr.Jack Active Member
    Wilmington, NC
    The Black Pearl
    Remote Start, 4 Hella Lights, Brush Guard, Grey Wire
    I just replaced my fan clutch and the guy I trust at advanceauto said that there was only one type of fan clutch for my taco. I believe the brand I got was"Imperial" and cost 120$. It was stamped "made in U.S.A." which is nice. Im not sure if anyone else has found any other clutch that works. If you have an automatic, I would suggest an aftermarket transmission cooler to help with towing.
    I've been tinkering with the idea of a transmission cooler with an electric fan mounted somewhere besides in front of the truck to keep the heat from transferring back into the condenser and radiator. I don't think anyone has done that yet.
  3. Jun 12, 2013 at 8:39 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    Thanks for the input. I do have an auto trans and I am going to be getting a trans cooler for it, as well for towing.:thumbsup:
  4. Jun 13, 2013 at 10:26 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Just my two cents...my OEM cooling setup (including the clutch fan) has worked flawlessly in every situation I've had it in. Towing my boat in heat, up long hills, off-road in heat, stop and go traffic in extreme heat, you name it. The stock temperature gauge never moves past 9 o'clock.
    Of course I have a manual transmission, but the cooling system on our Tacomas seems to have plenty of reserve cooling and I don't plan to do anything with mine unless something fails.
    It is fun to tinker though...:D
  5. Jun 13, 2013 at 4:39 PM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    If you have the green banded clutch you could upgrade to the oem orange one that's supposed to be for towing.
  6. Jun 13, 2013 at 5:38 PM
    Gooch
    Orange County CA
    Mine's green, but I won't upgrade until/if it fails. I'm cheap.
  7. Jun 13, 2013 at 6:50 PM
    ARB1977
    ARB1977 You done messed up a-a-ron
    North Texas
    15 DCSB Prerunner 4.0L
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Your coolant temps aren't going to drop just because you have a HD clutch. All it means is the fan stays engaged longer. If you want to lower your coolant temps 13-15 degrees take the factory thermostat and turn the jiggle valve to the 6 o'clock position. I do have the HD clutch on mine and before the touching the thermostat the temps were 203. Now it's 188-190 degrees.
  8. Jun 13, 2013 at 8:40 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    Thanks I have towed with mine, even during the summer and haven't had any issues with it, either. It's just a precautionary, I am going to be changing out my radiator and figured I will change out the fan clutch at the same time.
  9. Jun 13, 2013 at 8:42 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    That's my understanding, but I haven't looked at mine, yet. But I'm pretty sure it has the green. I will double check it just in case. Is the OEM the only HD fan clutch available?
  10. Jun 13, 2013 at 8:44 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    I am not concerned with my coolant temp dropping. I am happy where it's at.
  11. Jun 14, 2013 at 9:49 AM
    Gooch
    Orange County CA
    Not a bad 'preventative maintenance' move if the part isn't too expensive.
  12. Jun 14, 2013 at 12:54 PM
    Dirty Pool
    Dirty Pool HOUSE OF BLUE LIGHTS
    59.4 Miles, 56.67*NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, Both 31" MTZ's and 33" Toyo's, 01 Center console, Map lights, Disraeli gears
    GREEN hub is OEM heavy duty. It came with the towing package and several other packages/trim levels. Most Tacos have the green hub.
    ORANGE hub is "standard".
    Yes, I am positive.
  13. Jun 14, 2013 at 2:19 PM
    Gooch
    Orange County CA
    Good to know!
  14. Jun 14, 2013 at 6:19 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    That is exactly the reason why I want to get a HD clutch.
  15. Jun 14, 2013 at 7:38 PM
    Gorillazrus
    01 Prerunner SR5
    Thanks for the correction :thumbsup:
  16. Jun 17, 2013 at 10:00 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    btt to see if anyone else has anymore info.
  17. Jun 27, 2013 at 10:33 AM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    I haven't verified the band color on my fan clutch, yet. But, I think I am going to swap it out regardless, because as far as I know, it's the original clutch and my truck has almost 300,000 miles on it.
    I went to the dealership to check on the price on the HD fan clutch option and they had only one fan clutch listed for my truck. The lady who helped me couldn't tell me anything about it, so right now, I am guessing that it's the standard duty clutch. Does anyone have the part number for the HD fan clutch?
  18. Aug 7, 2013 at 8:24 PM
    cr500taco
    D
    Northridge
    4WD
    K&N intake.
    Just an update. I bought the oem fan clutch from the dealer and the band is green!
