Best headlight bulbs to get
Discussion in 'Lighting' started by BluTaco08, Jul 16, 2008.
  1. Jul 16, 2008 at 5:43 PM
    BluTaco08
    BluTaco08 [OP] I LiKe TaCos
    I would like to upgrade my exisiting bulbs to somethin either bright white or blue. Any suggestions on where to buy and what brand for the best performance ?
  2. Jul 16, 2008 at 5:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    probably find some nice hella bulbs or some nice piaa bulbs. to go a bit cheaper......get some sylvania silverstars.
  3. Jul 16, 2008 at 5:49 PM
    jizzam93
    jizzam93 Well-Known Member
    Kris
    H-Town, TX
    08 DC PreRunner SR5
    YES!!
    I just changed my headlight bulbs to Piaa's. Huge difference to stock, obviously. eBay has some good prices. They have extreme whites and some with a tint of blue.
  4. Jul 16, 2008 at 6:27 PM
    BluTaco08
    Thanks for the advice.
  5. Jul 16, 2008 at 6:35 PM
    BluTaco08
  6. Jul 16, 2008 at 7:41 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    Just my two cents. I have had after market bulbs in my acura and for some reason they always seemed to burn out fast. i would put them in and maybe 3 months in one would just burn out. I would just stick with the stock lights unless they have already burned out. i used piaa and they were thought to be good lights and they cost alot.
  7. Jul 16, 2008 at 7:47 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I run the Sylvania Silver Stars-they are fantastic-and add the class, not that annoying 'blue'. Really light up the place nicely-notable difference from stock. If ya dont want them to burn out early, take care not to touch them during installation!
  8. Jul 16, 2008 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Keep in mind, the PIAA's, and other tinted bulbs reduce the light out put. If you are looking for a brighter bulb, you will need a higher wattage. If its for looks, then disregard. :)
  9. Jul 16, 2008 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2! I have had good luck with Silver Star bulbs. :)
  10. Jul 16, 2008 at 7:50 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I learned the "no touchy" thing from this guy^^^^ and it does matter:D
  11. Jul 16, 2008 at 7:50 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Thats what I got in right now. No problems here.
  12. Jul 16, 2008 at 8:06 PM
    BluTaco08
    Sylvania Silverstars it is. Thanks a bunch!
  13. Jul 16, 2008 at 8:16 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    There ya go:) They're big enough that it should be very easy for you to handle them by their base and not touch the glass part:) Good luck! Come in here if ya got questions during the install-and let us know how you like them too!
  14. Jul 16, 2008 at 8:16 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    the hotter they are, it seems like the faster they burn out. Then again, I've heard good things about the silverstars.
    You could also look into getting some HIDs.
  15. Jul 16, 2008 at 8:29 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    x6-7 or 8 I lost track.... But is sounds like this is the winner (I also have these.)
  16. Jul 16, 2008 at 8:58 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Hope you have better luck than I have. Having them only last less than 6 months is not easy on the wallet. This isn't unusual, either, because I've seen the same over and over with many other folks. I do hear that the Ultra's are pretty good but I won't ever waste my money on them again.
  17. Jul 16, 2008 at 9:22 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Silverstars for me have been the biggest waste of money ever......I went through 3 sets in my '98 taco and 2 sets in my bimmer....And no I didn't touch them. So when I bought this truck I had to do something cause I like alot of light and the factory bulbs weren't doing it for me.....So I bought silverstar ultras for the headlights and regular silverstars for the fogs......the fogs burnt out in just over the 90 days autozone would warranty for and the ultras are still going. But I am not yet to say that they are great....PIAA's are great. HID's are great.. If you want great lighting call Matt at Um-nitza and he can hook you up with great lighting. I am new hear so I don't know if it is cool to link to sites if they don't sponsor, but if you want google um-nitza, get phone number, call, ask for Matt, tell him Brant sent you and he can hook you up. The new taco headlights are perfect for HID's.... Mine will be in soon.
    Mush Mouse likes this.
  18. Jul 16, 2008 at 9:23 PM
    BluTaco08
    I take back my previous post :eek:
  19. Jul 16, 2008 at 9:29 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    [​IMG][/url][/IMG]
    ^^^These are EuroDesignz Bulbs, I've had them for about 6-7months already and no problems whatsoever.....They do have a slight "blueish" tint to them......They also have a lifetime "replacement" warranty.
