Best Headlight Replacement Bulb?
Discussion in 'Lighting' started by hotrod77, Nov 29, 2011.
  1. Oct 14, 2012 at 8:33 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Osram nightbreakers
  2. Oct 15, 2012 at 6:34 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
  3. Mar 15, 2014 at 4:17 PM
    catgrader
    catgrader Member
    jack
    maine
    should i buy the best bulbs at walmart at 45.00 pr. to replace factory bulbs on a 2012 tacoma? thanks, cat grader.
  4. Mar 15, 2014 at 8:57 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Funny that I saw this bumped today. I just replaced these bulbs in Feb, so looks like they lasted about 26 months. Both blew within 72 hours of each other.
    GsuEagle18 likes this.
  5. Mar 15, 2014 at 9:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Just go with the mid-scale Silverstars and keep a spare pair in the glovebox.
  6. Jan 5, 2015 at 7:08 PM
    EjF
    EjF You'll never make a saint of me
    Eddie
    Central, MA
    2015 Tacoma TRD Pro
    Roof Rack, Tubes, Truxedo LoProQ, Tints, Ziebart under coat & sound deadening, Truck Bet Mat, G-Tek Fab diamond plate sills
    last post on this topic was quite a while back... So giving it a bump in 2015.
    If you were to pick a replacement bulb over stock to have brighter/wider lighting what would it be, and why?
  7. Jan 5, 2015 at 8:45 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    The original bulbs in my truck were Osram made in Germany. When they died I put in the Sylvania Silverstars. They were brighter but one went out in less then 1 year and cost $40 a pair. I got in a minor wreck and both headlights were replaced with OEM Toyota that came with Osram bulbs. I had some wierd cracks form in the lens of one of the replacement assemblies but was able to pick up a pair of take off headlights and LED taillights from a 2009 for $200 in perfect condition with Osram bulbs included. I've been using the Osram bulbs from the various headlights as replacements but ran out and am now running 1 Osram and 1 Sylvania so I ordered a pair of Philips extreme power because they are supposed to be as bright as the Sylvanias and I found them for under $20 delivered to my door. At that price I'll be happy even if I only get a year out of them. That's my "what and why".
  8. Jan 6, 2015 at 4:42 AM
    EjF
    Eddie
    Central, MA
    2015 Tacoma TRD Pro
    Thanks for the input LJ, the stock bulbs just don't seem to have enough light (especially on high-beam on back roads) so I'm looking for the perfect replacements. I have read up on a bunch of light-bulb threads here at TW and it seems the trade off is bulb life. Now granted I don't drive a ton at night, but in the many Toyota's I have owned I have never replaced a headlight bulb. I guess I'll have to get used to it now when I select an upgrade.
  9. Jan 6, 2015 at 5:51 PM
    L J
    Illinois
    The difference between the OEM Osram and Sylvania silverstar bulbs is obvious. The Osram bulb is yellow and dim looking in comparison but lasts much longer. I'm waiting for the new bulbs to arrive and I plan to replace the Osram bulb first so I can turn them on before I finish the job to see the difference between the silverstar and the philips bulb. The headlights on these trucks leave much to be desired but I just can't justify spending $1000 on retrofit projector headlights.
  10. Jan 8, 2015 at 8:01 AM
    dandrilla
    dandrilla Member
    Dominic
    Seattle
    07 Double Cab LB 4x4
    3 inch lift, AM nerf bars, Plasti-dip badges, Areis bull bar, KC 6in spotlights, AM stereo + sub, AM high performance Halogen headlight bulbs
    EJF I just grabbed replacements for my headlights fogs and 2 aux lights for 15$ total from Amazon. None of them are the name brand bulbs that are mentioned in this thread. We'll see how long they last, but I figure its worth trying the cheaper ones to see if they will work before spending 40-50$ a pair for halogen bulbs
  11. Jan 8, 2015 at 11:31 PM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    I had Philips MotoVision bulbs that lasted about a year. But then again they were previously in my Civic for awhile.
    http://www.amazon.com/Philips-MotoVision-Motorcycle-Powersport-Replacement/dp/B001CB0362/ref=sr_1_1?ie=UTF8&qid=1420788122&sr=8-1&keywords=motovision+h4
    The beam hotspot on the road is longer than the stock bulbs. Despite the orange coating the beam color is whiter than stock. Brightness is about the same. Makes me wonder if it'll actually be brighter than stock if it didn't have the orange coating.
  12. Jul 6, 2015 at 10:26 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Just something to note... I looked at all four of the Sylvania bulbs today at an auto parts store. For those that don't know- the Sylvania Xtravision, silverstar, and silverstar ultra are all Osram bulbs. It is printed on the bulbs. The Sylvania "base" (cheapest of the four) didn't appear to be an Osram (it had a plastic end as opposed to metal like on the other three). Now I'm wondering if the stock bulb In my 2014 is actually the Xtravision (Osram is printed on it).
  13. Jul 7, 2018 at 8:15 PM
    PigSooieTacoma501
    PigSooieTacoma501 New Member
    Braden
    Little Rock, AR
    '15 Tacoma Access Cab SR5 4x4
    Thanks for all of the info. I just ordered the PIAAA Xtreme Whites headlight bulbs and fogs. Excited to get them and see the difference!
  14. Jul 7, 2018 at 10:28 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Pretty old thread, but FYI coated bulbs like PIAA Xtreme white put out less light than a stock uncoated bulb. The light is whiter, but not brighter.
    Norton likes this.
  15. Jul 8, 2018 at 6:41 AM
    #35
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Definitely an old thread. Lots of new products and info since then. In short, @crashnburn80 is spot-on.
    If you haven't already done so, @PigSooieTacoma501, recommend you check out the Ultimate headlight upgrade thread.
    crashnburn80[QUOTED] likes this.
