Best Headlight Upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by wazzajohno, Jul 24, 2019.
  1. Jul 24, 2019 at 1:43 PM
    wazzajohno
    wazzajohno [OP] Member
    Warren
    2003 Tacoma Double Cab
    I recently added LED headlights on my 2003 double cab in the stock lenses. If I adjust the lights down the regular beams are an improvement but after driving modern cars even this upgrade has a lot to be desired. The high beams are not focused and seem to illuminate more like really bright fog lights closer and lower than the regular beams. Does anyone have any links to some parts that really work well in high and low beams?
  2. Jul 24, 2019 at 1:49 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Phillips X-Treme Vision H4's are what Im running.
  3. Jul 24, 2019 at 1:52 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
  4. Jul 24, 2019 at 1:57 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    to be photometrically and federally compliant, only OEM assemblies with recommended bulbs
    off reservation, who knows it's 99% garbage
    yes LED in a halogen socket is never going to produce the correct light and cutoffs.
  5. Jul 29, 2019 at 8:54 PM
    wazzajohno
    Warren
    I pulled out the LED bulbs and went back to the Osram. While they are not as bright as the LED they are much more focused and don't annoy other drivers so long as they are focused properly. I may add some additional lights for the dark forest roads. Thanks all!
  6. Jul 29, 2019 at 9:01 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    License2Ill, RysiuM and cruiserguy like this.
