Best Headlights for Halogen Housing?
Discussion in 'Lighting' started by ChiefBreezy, Sep 27, 2019.
  1. Sep 27, 2019 at 11:10 AM
    ChiefBreezy
    ChiefBreezy [OP] Member
    East TN
    2023 Lunar Rock Tacoma TRD Sport
    Ceramic Windshield Tint 5-inch Tube Step Running Boards Factory Toyota Bed Cover Black Tacoma Tailgate Inserts
    One of my headlights has went out, so I am curious as to what I should go with for replacements. Your suggestions would help out a lot.
  2. Sep 27, 2019 at 1:53 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Extensive testing and data backed recommendations here:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    Stock wattage:
    -Philips Racing Vision +150 - Best low beam, though blue coating over high beam filament reduces high beam performance
    -GE Xenon +120 - Best low beam without reduced performance high beam
    High wattage:
    -Osram Superbright 100/90w - Requires standalone harness, very bright low beam and massively bright high beam
    -IPF 4x4 Fatboy 60/80w - Does not require a harness, very bright low beam, stock output high beam. Bulbs are expensive.
    All the details with measured lux output in the linked thread charts. With your 2006, be sure your headlight assemblies are in good shape, if not consider replacing with OEM for best performance. Links also provided in the thread.
