Best Hood Strut For 6MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 10ptXtreme, Oct 17, 2023.
  1. Oct 17, 2023 at 8:54 AM
    10ptXtreme
    10ptXtreme [OP] Well-Known Member
    NJ
    2020 DCSB TRD Sport Voodoo Blue
    So I'm familiar with several of the manufacturers of hood struts for our 3rd Gen - Redline Tuning, Spiker Engineering, and SokieTech. Which one of these works best for Tacoma's with the 6MT transmission? Or does it not matter? Your feedback is appreciated.
    David
    pastoreater likes this.
  2. Oct 17, 2023 at 9:01 AM
    Shellshock
    Iowa
    I had the redline ones on my truck
    oconnor likes this.
  3. Oct 17, 2023 at 9:18 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I don't understand the question; what does your transmission have to do with a hood strut? Is it Friday yet?
    cshrum, BillyE, kona61 and 12 others like this.
  4. Oct 17, 2023 at 9:23 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Different drive trains have different engine bay encumbrances. So what works in one may not work with others.
    OP, I'd stick with @RedlineTuning or @SpikerEng , as both have strut solutions that work with your truck.
    Neal4x4 and Irons like this.
  5. Oct 17, 2023 at 9:28 AM
    Horseshoez
    Dale
    Maryland
    Sorry, not buying; I seriously doubt there is any difference between an automatic Tacoma and a 6MT Tacoma when it comes to fender or hood or anything else in that region of the engine bay.
    J-Boy77, beergeek, Tacosha and 4 others like this.
  6. Oct 17, 2023 at 9:31 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Continue believing what you want. The MT and the AT have differences amongst them, and some accessories are not cross compatible. Fuse trays for example are different. Brake boosters, master cylinders, etc are different amongst models.
    timw1 likes this.
  7. Oct 17, 2023 at 10:21 AM
    Horseshoez
    Dale
    Maryland
    Those items are irrelevant when it comes to something like a hood strut. Yeah, I get it, my truck has three pedals under the dash, most only have two, but that in no way would change how the hood or fenders are set up.
  8. Oct 17, 2023 at 10:45 AM
    10ptXtreme
    NJ
    It has to do with where the struts attach in the engine bay compartment and accessories in the engine bay. But if you don't believe it's necessary, that's your opinion.
    David
  9. Oct 17, 2023 at 10:46 AM
    10ptXtreme
    NJ
    Do you have the 6MT transmission?
    David
  10. Oct 17, 2023 at 10:49 AM
    pastoreater
    pastoreater doesn't know
    M
    5g 4runner
    Thank you OP. Sometimes we'll never know unless we ask and talk about it.
  11. Oct 17, 2023 at 10:53 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It would matter if the left strut interfered with the fender mounted clutch reservoir on the manual OR/Pro. Shouldn't matter at all on a Sport since the clutch hydraulics on Sports pull from the brake res.
  12. Oct 17, 2023 at 10:58 AM
    pastoreater
    M
    5g 4runner
    I would love to see a build thread with an MT specific strut setup with something else using the space or clearance where the auto struts mount. I don't care which day it gets posted.
  13. Oct 17, 2023 at 11:02 AM
    Shellshock
    Iowa
  14. Oct 17, 2023 at 11:02 AM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Off road trim: you can add second battery in back of the engine bay on the left side of you when you face the engine behind the filter system.
    Sport trim, you can NOT add second battery in that spot but you can add dual batteries in same spot as factory battery placement. (but not sure about '24 models, I have not seen them in person yet)
    If you still don't believe, then go to the dealer and look at the trims.. open the hood and look at each model... you will see why.
    Bertw192 likes this.
  15. Oct 17, 2023 at 11:06 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Sokietech. No drilling and have worked great for multiple years on several 3rd gen Tacomas.
    Taco22trdor and 71tattooguy like this.
  16. Oct 17, 2023 at 12:23 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Early manuals need to space out the clutch fluid reservoir on the driver side. I switched over to the single Spiker setup (from the original 2 strut setup) because the driver side strut interfered with my Switch Pro mount.
    mtip and Bertw192 like this.
  17. Oct 17, 2023 at 12:38 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's a hood strut. It attaches to the hood and fender. Neither have anything to do with the transmission. Wait... "You need a new rear armrest? What transmission is in that Tacoma."
  18. Oct 17, 2023 at 12:46 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You guys are having a hard time with this concept...
    Yes, the hood struts will fit, regardless of transmission type, assuming OP doesn't have other underhood accessories that prohibit them. However, what I'm supporting is OP asking the question, as there are certain engine bay accessories that fit only and MT or AT.
    33yrsoftoys and Pscdouglas like this.
  19. Oct 17, 2023 at 12:50 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    No, they are not having a hard time with it. They are screwing with the OP and obviously you, just for the hell of it because, well, they can.
    timw1 and hiPSI like this.
  20. Oct 17, 2023 at 12:52 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Better get the HD strut to carry your big ass head you cool 6mt owner. Lol
